The rudder waggle signal does not work
On Tuesday, July 26, 2011 4:09:10 AM UTC-7, wrote:
Do you do a pre take off check list? Yes Do you "close and lock" ths spoilers as part of your pre take off check list? No. I use the spoilers to maintain rope tension and prevent over-running it if the tow pilot takes up slack a bit too fast. I then use it on my ship to help with aileron control at low speed, as do many others. There are many nuances to glider operations, so one solution does not fit all situations. What does work is currency, maintaining situational awareness, and not performing *immediate* programmed responses. ALWAYS think before you act. If pulling the release immediately after a wave-off will put me in danger, then I may just delay the release if I believe the tow pilot is in less danger than I am. Not all emergency responses can be pre-programmed, just ask an Airbus pilot. -Tom |
On Jul 26, 10:46*pm, 5Z wrote:
On Tuesday, July 26, 2011 4:09:10 AM UTC-7, wrote: Do you do a pre take off check list? Yes Do you *"close and lock" ths spoilers as part of your pre take off check list? No. *I use the spoilers to maintain rope tension and prevent over-running it if the tow pilot takes up slack a bit too fast. *I then use it on my ship to help with aileron control at low speed, as do many others. There are many nuances to glider operations, so one solution does not fit all situations. What does work is currency, maintaining situational awareness, and not performing *immediate* programmed responses. *ALWAYS think before you act. *If pulling the release immediately after a wave-off will put me in danger, then I may just delay the release if I believe the tow pilot is in less danger than I am. *Not all emergency responses can be pre-programmed, just ask an Airbus pilot. -Tom Right...we already covered this....so your hand is already on the spoiler....so you're gonna close the spoiler when necessary....and you're not gonna do the whole tow with spoiler open! Cookie |
Let me try to make my point a little clearer.
Glider pilots are divided in opinion and react to an accident like this one with two distinct ways of thinking.... If seems most on this group react in an emotional way: "Oh, that was terrible, oh if only (fill in blank) they would be alive today.....Oh, we have to come up with some new regulations, some new mandates, some new training methods, the FAA and SAA oughtta do something......lets add a new layer of technology (radio)..... that 'll save the next guy....." I make it a habbit of reading about glider accidents.......Purely for selfish reasons....(well not totally selfish, also to teach my students and friends) I want to figure out what happened to those poor fellows, and make sure it doesn't happen to me....I like to learn from the mistakes of others (especially when it comes to fatal mistakes). So I have read about several "pull the release instead of closing the spoiler" incidents over the years.....some having bad outcome... So what am I gonnn do so that this doesn't happen to me?..... For me, instead of reaching "outside" as suggested by most guys on this group....I reach "inside".... What can "I" do......not what can "somebody else" do? (I take responsibility for my safety) I then imediately "go back to basics"....what was I taught and what I learned over the years.... In this case I come up with some simple remedies which will prevent the problem.....100% Preflight inspection with checklist Pre take off checklist Keep hand near / on spoiler handle Cockpit management Situational awareness (poor climb rate) Know the signals Formulate an emergency plan for "this" flight See....two completly different ways of thinking...about safety... Cookie |
Quote:
A certain Airbus pilot certainly showed the value of years of training and wide experience when he used the benefits of that preparatory work to step outside the pre-programmed/trained response and deviate from the engine out checklist to fire up the APU. Made a good difference to that outcome Cheers Colin |
Similar Threads | ||||
The rudder waggle signal does not work | Pat Russell[_2_] | Soaring | 99 | August 2nd 11 02:16 PM |
The rudder waggle signal does not work | 5Z | Soaring | 0 | July 23rd 11 06:24 AM |
Rudder waggle | toad | Soaring | 33 | November 21st 07 05:44 AM |
DG Rudder AD - DONE! - Notes from my work | ContestID67 | Soaring | 0 | March 30th 06 07:36 PM |
CH Rudder pedals, why don't they work | wan2fly99 | Simulators | 2 | January 12th 06 12:30 PM |
