Air Force uniform prototype makes debut
Old February 21st 04, 04:02 AM
BUFDRVR
Why do you start #4 & #5 first?
The sequence is; #4 then #5, then the rest. You could use #3 or #6 to start as
well, I'm guessing they just picked #4 because they needed to pick an inboard
engine and #4 was the closest to the watchful eyes of the Aircraft Commander
(I'm not really sure why they picked #4 out of the 4 they could have?)
You want to use inboard engines because the bleed air manifold connecting to
the outboard engines is only designed to have cooled air blown into it, not hot
air out of it. Basically, if you start #8, then run up #8 to start the rest,
you can over temp the "plumbing" leading from the #8 engine. Same is true for
#1, #2 and #7. On occasions, the manifold for one of the outboard engines will
stick open after the switch has been placed to CLOSED and either during the
anti-ice check, or initial takeoff you'll get a manifold overheat light. The
bad part is, you have no idea which engine and have to go through a little
"trial and error" to figure out which engine is the criminal. On takeoff the
light comes on immediately upon turning the air conditioning on (somewhere
prior to 10,000').
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips
everyone on Bear Creek"
Old February 21st 04, 04:22 AM
Bob McKellar
prior to 10,000').
BUFDRVR
So all the engines are all "plumbed" together? As long as one of the 8 is running,
you can send "starting air" to the others (within the limits you mentioned.)?
Starting is all with bleed air, no electric motors?
Given all this complexity, why was an APU not fitted? It would not seem to add
much to the plumbing. Is this due to the general plan of a large AFB with lots of
handy ground techs and their equipment running around?
Bob McKellar
Old February 21st 04, 02:02 PM
BUFDRVR
Yes.
Yes.
The starters ("spark") are DC, but initial engine rotation is provided by bleed
air.
Are there any jets built before 1962 that have APUs? Did the Comet have an APU?
If the answer is yes to either of those, my only guess would be, to save
weight, they did without the APU. Hell, they took the G model's and H model's
ailerons off to save weight.
BUFDRVR
Old February 22nd 04, 01:21 AM
Bill and Susan Maddux
there is another way to start the engines as well. the Starter cartridges
placed in the engine starter fires from battery power and propels the
engines to motor up. it was use on alerts. and a bitch to clean up after an
exercise. we would put two on # 4 & #5 engines for a normal alert status,
and a cart in all eight engines for a quick start alert.
"BUFDRVR" wrote in message
Yes.
mentioned.)?
Yes.
bleed
air.
APU?
model's
BUFDRVR
harelips
Old February 22nd 04, 04:54 AM
BUFDRVR
I was actually lucky enough to get to do an 8 engine cart start one afternoon.
ACC was testing new respirators for the crew chiefs, so they picked my jet to
load 8 carts on. It was very cool and I was very surprised at the amount of
smoke, it seemed much more than four times what I was used to.
BUFDRVR
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Highest-Ranking Black Air Force General Credits Success to Hard Work Otis Willie Military Aviation 0 February 10th 04 11:06 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
Air Force Uniform Envy Thomas Schoene Military Aviation 35 August 11th 03 02:04 AM
Air Force unveils new uniform plan Otis Willie Military Aviation 1 August 9th 03 08:32 AM
