battery power regulator
Old July 30th 11, 02:18 AM posted to rec.aviation.soaring
Darryl Ramm
Default battery power regulator
On 7/29/11 4:51 PM, Tony V wrote:
With modern avionics/electronics you really should not need this. Modern
radios, transponders, etc. have built in switch mode power supplies that
effectively do the same as this device does, but usually more
efficiently.
Thanks, Darrell. The reason that I ask is that after flying for a few
hours with a new 9Ahr battery, the LCDs on my radio (Dittel FSG71M)
blank out when I transmit - which gets out OK. Other than the radio, I'm
only running a Cambridge 302 and an iPaq.
Tony V.
Its hard to see what would be drawing so much power to drop the Dittel
below its speced operating voltage. There was a recall/repair on some of
these radios but I though that only affected the RF board, not sure that
could affect the display like this but I don't know. Was yours affected?
- check here http://www.cumulus-soaring.com/dittel.htm Other Dittel
users can comment if they ever see this display problem at reasonable
supply voltages. I've never owned a Dittel radio.
I'd want to check that the 9Ah battery is not faulty or not getting
fully charged (the charger may be faulty or incorrectly sized etc),
something else/hidden is drawing power or the Ditel has a problem.
It would be nice to do a discharge test on the battery after charging it
as you normally would and see exactly what power it is storing. You can
do this maually but much easier with a discharge tester like the West
Mountain Radio CBT III. Improper charging is not an uncommon
problem-check your charger is the right type, and sized for the battery
and if it has indicators for charge/complete or float stage do they show
as expected (and you still need to leave the battery on charge for many
hours after that to top up the last ~10% or so). But if you can't do
that at least measure the current your equipment is drawing and measure
the voltage under load (all avionics on and transmit key pressed) when
the Ditel starts misbehaving. I have numbers for common toys including
the C302 etc. in slides at http://www.darryl-ramm.com/glider-batteries
I think the radios are speced down to 9V and may work even lower, and
with your setup just should not have problem after only a few hours.
You would not be the first person to have something hidden behind the
panel that is consuming power. Some PDAs can suck interesting amounts of
power ( transponder) esp. if they have a large Li extended battery
packs that are connected to the ship when discharged. A poorly designed
PDA chargers might be very inefficient (but most are not). Still noe of
these alone would really explain this. Maybe you have several things
goign on. Certainly measure the current draw with everything turned on
and see if it makes sense with what is in my slides. Also measure the
current of each device.
Darryl
Old August 1st 11, 03:58 AM posted to rec.aviation.soaring
John Derosa
Tony,
I am with Darryl on this, with your seemingly modern electronics and a new
9AH battery, you "should not be having a problem". But of course you do
apparently seem to be having an problem. I say apparently as you say your
Dittel display disappears when you transmit but it still "... gets out
OK...". This seems like a problem with your radio, not with your battery
or wiring. But here are some other ideas.
What is the gauge of your wiring from the battery to your instrument panel?
If you are using small gauge wiring, and drawing considerable amps when
transmitting, then the voltage can drop considerably between the battery
and your radio. I use 12ga wiring. 14ga generally works just fine.
Anything smaller and you are throwing away voltage, which we glider pilots
cannot afford. So measure the voltage of your power system at the radio
when you hit the transmit key. If the voltage drops considerably (i.e.
from 12.5VDC to 11.5VDC) then you either have a wiring/connection issue or
your battery is bad. BTW: Only use Tefzel wiring in aircraft:
http://wingsandwheels.com/tefzel_coa...kers_louds.htm.
Battery Testing - Testing your batteries each year is a good idea. Darryl
mentions a very nice battery tester which does a quick job of determining
good from bad. Unfortunately, it costs $150 which is a bit steep for a
once a year effort. So here is my (slow) poor man battery testing method
that should not cost more than $10-$15:
http://aviation.derosaweb.net/#batterytest
Good luck.
Enjoy, John DeRosa
johnatderosaweb.com
Old August 1st 11, 04:23 AM posted to rec.aviation.soaring
Tony V
On 7/31/2011 10:58 PM, John Derosa wrote:
Tony,
or wiring.
So it appears. When it happened again today, I switched the 302 to the
battery voltage screen and when I was transmitting (with the blank LCD
display), the 302 was registering 11.6 volts. So, it appears that I have
a radio or wiring problem.
I will be checking the wiring to the radio very closely.
This is nice. I typically test by putting a 1 Amp load on the battery
(using a 1156 automotive light bulb). My charger is an
accumate(http://www.accumate.com/612/), which IMHO is quite good.
Thanks for the advice!
Tony, LS6-b "6N"
Old August 1st 11, 05:33 AM posted to rec.aviation.soaring
Darryl Ramm
Tony,
new
or wiring.
panel?
pilots
issue or
Tony, LS6-b "6N"
It actually has to be _really_ thin wire to drop significant voltage at
transmit current draws (because that current is just not that high -
with modern radios typically about a bit over 1 - 1.5 amp @ ~12VDC
transmit draw, say worse case 2 A all up, you can draw that through 10
feet of 24 AWG wire (finer than you should find in a glider) and only
drop around 0.25 volt. So its worth checking the wiring and using
heavier wiring can be good practice, but thickness of wiring causing
this problem is kinda unlikely.
One thing I would look out for if the wiring seems suspect is corrosion.
Especially hidden behind heat shrink tubing and inside poorly made crimp
connection. So if you can't sort anything else out carefully inspect
connectors. Sometimes it hides in places like inline fuse housings and
their connections etc.
But overall I'm also suspecting your radio. It also may be worth
thinking if this effect is temperature dependent (happens after the
radio bakes in the sun for a while?). I've seen LCD displays exhibit all
sorts of weird problems when they get hot enough.
Darryl
Old August 2nd 11, 06:04 AM posted to rec.aviation.soaring
jim wynhoff
Tony,
new
or wiring.
panel?
pilots
issue or
Tony, LS6-b "6N"
Darryl- Hide quoted text -
- Show quoted text -
My FSG -2T did the same thing out of the box. This was with a new 14v
10ah battery, and 14 ga wire. Dittel acknowledged it was defective
and repaired it free of charge.
Old August 2nd 11, 03:11 PM posted to rec.aviation.soaring
Westbender
Are you using circuit breakers instead of fuses? That might be worth
looking into. Breakers will cause a slight drop in voltage, but maybe
you have a bad one causing a larger problem.
Old August 2nd 11, 11:57 PM posted to rec.aviation.soaring
Tony V
I have a 5 Amp fuse at the battery and 2 Amp fuses on the panel for the
individual components. Hans makes a very good case for checking the
wiring. :-)
Tony
Old August 2nd 11, 09:33 PM posted to rec.aviation.soaring
weersch[_2_]
It is unbelievable what crappy electrical installations you can find
in gliders.
In my 1997 ship, somebody installed a 25 wire printer cable as a power
and signalling backbone under the seatpan.
Nice to be able to disconnect the panel at the DB25 connector if
needed, but...
I had continuous problems with my voltage dropping off soon after
launch to something like 11 Volts and my Dittel FSG71M starting to
blink.
I also ran a Terra250 and GPSMAP195 continuously.
After the batteries tested good on capacity, I checked the wiring in
more detail.
My ship has 3 battery positions (front, main and tail)
They were clever enough to combine 3 strands of the printer cable for
the positive terminal of each battery position.
I could not believe my eyes when I found out that they were running
ALL ground (power and signalling) through a single strand of the 25
wire printer cable.
If I were religious, I would have thanked God that the whole thing did
not go up in fire in flight.
My first project was to install a new separate power and ground
backbone with 12AWG Tefzel.
After that my power supply has been rock steady and pushing the PTT
button has hardly any effect.
Last winter I have replaced all of the remainder of the printer cable
(signalling) with Tefzel.
In the mean time also power hogs like the Terra has been replaced by a
Trig and the GPSMAP195 by a Ipaq310.
Then there is the never ending saga about batteries.
There are 2 use modes that substantially shorten the life time/
capacity of a battery (holds for most battery chemistries, but
particularly Lead Acid)
- Deep discharge
- Over charge
Most common glider batteries (like the PowerSonic 7AH) are completely
empty at 10.5 Volts at usual glider current draw (~1-2 Amps).
See the PowerSonic spec sheet.
Discharging to 9 Volts (at 1-2 Amps) is just damaging the battery.
With a reasonable AC mains charger like a Battery Tender or similar
2/3 stage charger, over-charging should never be a problem.
However, unregulated solar panel charging is a shortcut to premature
end of life for the battery.
As always on this forum, there are a hundred different opinions and a
lot of yelling about who is right or wrong.
I try to speak only about my personal approach and leave decision
making to the reader.
My approach is KISS.
I have plenty of battery capacity on board.
I have a good fat power supply (and ground) backbone in star
configuration.
I switch all 3 batteries in parallel.
I have no need for elaborate wiring schemes for switching of batteries
or separate batteries for separate equipment like transponder
I don't deep-discharge batteries (below 12 Volts) to prolong life time
of the batteries.
I have no need for voltage converters to try to maintain 12 volts from
a battery that is already empty (and damage the battery by doing so).
I charge all batteries immediately after each flight. Each battery on
a separate Battery Tender.
The FSG71M, Trig, LNAV, Ipaq310, Etrex are running happily and I am
sure the PowerFlarm will soon join without any problem.
Works well for me, but if you want to follow a different approach,
that is fine too.
Hans Van Weersch
Old August 3rd 11, 04:53 AM posted to rec.aviation.soaring
Morgans[_4_]
- Deep discharge
- Over charge
My experience has been that leaving one sit around in a discharged condition
will kill one permanently dead, just as quick as the other two reasons
listed above.
-- Jim in NC
Old August 3rd 11, 09:58 PM posted to rec.aviation.soaring
Tony V
Is anybody *really* buying the 7AH battery? For just a little more
money, you can get a 9AH battery with the same size and shape -
http://www.voltdepot.com/product/27042.html
Tony
http://home.comcast.net/~verhulst/SOARING
Oshkosh Camping - Battery Power Tom McQuinn Owning 3 June 11th 07 12:19 AM
Power setting table and best economy/best power... xerj Piloting 29 October 20th 05 02:44 AM
$15 Regulator for Onboard PC Jim Vincent Soaring 0 July 14th 05 06:46 PM
battery charger to get through Piper power port? Kyler Laird Owning 16 March 20th 05 12:08 AM
Rectifier/Regulator Bill Home Built 0 November 13th 04 04:54 PM
