Etiquette in a Thermal
Old August 1st 11, 08:18 PM posted to rec.aviation.soaring
Chip Bearden[_2_]
Default Etiquette in a Thermal
One of the most dangerous times is not IN the thermal, but getting
there. When you're focused intently on the 3 gliders at the same level
you want to join, it's easy to miss the guy who's ALSO approaching the
same thermal from a slightly different angle. I've got a nice near
miss [as opposed to a bad near miss] in the flight logs from a
nationals where a high-time professional pilot type slid smoothly into
a crowded thermal...and completely missed me coming in from an angle
about 30 degrees off his. That the "miss" was literal and not just
figurative was because I saw him coming and pulled up and over him as
he bored into the thermal like a laser beam, merging neatly with the
crowd there.
Keep scanning, even--especially--as you get close to the thermal.
There's a pretty good chance that anyone else approaching the thermal
at the same time is focused intently on the gaggle, not on the gliders
coming into it. This is especially true locally and pre-start when
gliders are milling about but the incident I mentioned occurred on
course when one pilot found a good thermal close to a gaggle and
multiple gliders converged on him from several directions.
Chip Bearden
ASW 24 "JB"
USA
Old August 2nd 11, 03:37 PM posted to rec.aviation.soaring
tstock
Wonderful.. have learned quite a bit from this discussion. Thanks.
Old August 5th 11, 05:37 AM posted to rec.aviation.soaring
noel.wade
I had a couple of people blast into the middle of my thermal and/or
dive for my thermal and pull up right in front of me at Logan this
year, and it was _not_ fun. I subscribe to the method that John
describes, and really wish that more people would do it:
Aim for a point *outside* the current thermal and you will often find
that you come closer in to it than you expect. Stay far enough
outside that other gliders are not afraid to continue their circle
(turning inside you), then as one comes past you try to duck in and
match his/her circle - you'll find yourself often at their 8-10
o'clock.
A couple of other thoughts about thermal etiquette:
1) For god's sake, BANK the glider! Haven't guys like Moffatt and
Striedeck been preaching this for decades?? Don't the contest results
over the last umpteen years show that people who climb the best end up
with the highest speeds and the farthest distances? Find the core and
get in it. If the thermal is narrow, get that ship up at a 45-50
degree bank. If you sense that the core is to the inside of your
current circle, try to get into it and stay in it! If you nurse a
shallow bank around the outer fringes, everyone is going to outclimb
you and wind up right on your ass. This is not safe for them or for
you.
2) Turning inside one glider is NOT the same thing as turning inside
several gliders at once. I mentioned this at Logan, but there was a
day when at least 4 gliders were stacked up behind a guy doing lazy 20-
degree-bank turns and we were all looking for an opening to pass him.
I was very cautious, and finally made a strong move to the inside.
But the guy behind me had gotten impatient with me and decided to try
to cut inside of BOTH of us. I'd already initiated my turn and was
watching the glider on the outside, when my peripheral vision caught a
wingtip skip coming from behind me and towards my canopy. Suffice it
to say, it was not a happy moment! Especially since the guy on the
outside was disappearing below my canopy-rail and I didn't have many
"outs" with a guy inside of me and a guy outside of me. Luckily the
pilot on the inside realized the issue and pulled hard; but it was
close for a moment there!
Bottom-line: With other gliders in the vicinity, you need to be both
considerate and vigilant.
--Noel
Old August 9th 11, 04:20 AM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Thank you all for your input. For some reason I saw no responses to this post until tonight. Something must have been wrong with the site but I have found this information most helpful.
Now....... If I can just find some gliders in a thermal.
Walt
Thermal Forcasting -Thermal index gldrgidr Soaring 6 November 27th 10 10:26 PM
Dumping ballast in a gaggle, bad etiquette or poor sportsmanship? chris Soaring 4 May 1st 06 04:56 AM
Etiquette for posting items For Sale in R.A.S. TTaylor at cc.usu.edu Soaring 0 February 20th 06 04:10 AM
Thermal Data Files Thermal Mapping Project Australia Mal Soaring 0 December 2nd 05 11:14 PM
Aero Retrieval Etiquette Ray Lovinggood Soaring 0 September 22nd 03 03:20 AM
