It is unbelievable what crappy electrical installations you can find
in gliders. In my 1997 ship, somebody installed a 25 wire printer cable as a power and signalling backbone under the seatpan. Nice to be able to disconnect the panel at the DB25 connector if needed, but... I had continuous problems with my voltage dropping off soon after launch to something like 11 Volts and my Dittel FSG71M starting to blink. I also ran a Terra250 and GPSMAP195 continuously. After the batteries tested good on capacity, I checked the wiring in more detail. My ship has 3 battery positions (front, main and tail) They were clever enough to combine 3 strands of the printer cable for the positive terminal of each battery position. I could not believe my eyes when I found out that they were running ALL ground (power and signalling) through a single strand of the 25 wire printer cable. If I were religious, I would have thanked God that the whole thing did not go up in fire in flight. My first project was to install a new separate power and ground backbone with 12AWG Tefzel. After that my power supply has been rock steady and pushing the PTT button has hardly any effect. Last winter I have replaced all of the remainder of the printer cable (signalling) with Tefzel. In the mean time also power hogs like the Terra has been replaced by a Trig and the GPSMAP195 by a Ipaq310. Then there is the never ending saga about batteries. There are 2 use modes that substantially shorten the life time/ capacity of a battery (holds for most battery chemistries, but particularly Lead Acid) - Deep discharge - Over charge Most common glider batteries (like the PowerSonic 7AH) are completely empty at 10.5 Volts at usual glider current draw (~1-2 Amps). See the PowerSonic spec sheet. Discharging to 9 Volts (at 1-2 Amps) is just damaging the battery. With a reasonable AC mains charger like a Battery Tender or similar 2/3 stage charger, over-charging should never be a problem. However, unregulated solar panel charging is a shortcut to premature end of life for the battery. As always on this forum, there are a hundred different opinions and a lot of yelling about who is right or wrong. I try to speak only about my personal approach and leave decision making to the reader. My approach is KISS. I have plenty of battery capacity on board. I have a good fat power supply (and ground) backbone in star configuration. I switch all 3 batteries in parallel. I have no need for elaborate wiring schemes for switching of batteries or separate batteries for separate equipment like transponder I don't deep-discharge batteries (below 12 Volts) to prolong life time of the batteries. I have no need for voltage converters to try to maintain 12 volts from a battery that is already empty (and damage the battery by doing so). I charge all batteries immediately after each flight. Each battery on a separate Battery Tender. The FSG71M, Trig, LNAV, Ipaq310, Etrex are running happily and I am sure the PowerFlarm will soon join without any problem. Works well for me, but if you want to follow a different approach, that is fine too. Hans Van Weersch |
"weersch" wrote
Then there is the never ending saga about batteries. There are 2 use modes that substantially shorten the life time/ capacity of a battery (holds for most battery chemistries, but particularly Lead Acid) - Deep discharge - Over charge Most common glider batteries (like the PowerSonic 7AH) ---------------------------------------------------------------------- My experience has been that leaving one sit around in a discharged condition will kill one permanently dead, just as quick as the other two reasons listed above. -- Jim in NC |
On 8/2/2011 11:53 PM, Morgans wrote
Most common glider batteries (like the PowerSonic 7AH) Is anybody *really* buying the 7AH battery? For just a little more money, you can get a 9AH battery with the same size and shape - http://www.voltdepot.com/product/27042.html Tony http://home.comcast.net/~verhulst/SOARING |
![]() Is anybody *really* buying the 7AH battery? For just a little more money, you can get a 9AH battery with the same size and shape - http://www.voltdepot.com/product/27042.html ----------------------------------------------------------------------- It seems to me that the 7AH used to be the most readily available and economical, but as of late, the other sizes are easy to get and economical. I suppose the internet market is mainly responsible for that phenomenon. -- Jim in NC |
On Aug 3, 7:11*pm, "Morgans" wrote:
Is anybody *really* buying the 7AH battery? For just a little more money, you can get a 9AH battery with the same size and shape -http://www..voltdepot.com/product/27042.html ----------------------------------------------------------------------- It seems to me that the 7AH used to be the most readily available and economical, but as of late, the other sizes are easy to get and economical. I suppose the internet market is mainly responsible for that phenomenon. -- Jim in NC I and a couple of colleagues have found the commonly-used push-on battery connectors are often a source of high contact resistance that can be solved by soldering them. Mike |
Oshkosh Camping - Battery Power | Tom McQuinn | Owning | 3 | June 11th 07 12:19 AM |
Power setting table and best economy/best power... | xerj | Piloting | 29 | October 20th 05 02:44 AM |
$15 Regulator for Onboard PC | Jim Vincent | Soaring | 0 | July 14th 05 06:46 PM |
battery charger to get through Piper power port? | Kyler Laird | Owning | 16 | March 20th 05 12:08 AM |
Rectifier/Regulator | Bill | Home Built | 0 | November 13th 04 04:54 PM |
