On 08/09/2011 12:58 AM, Rob Cluxton wrote:
Dave wrote: I find it odd that there's no posts regarding the first-time use of PowerFlarm in a US contest. Surely they're all flying with them. It works well. It does use up the batteries quickly though. 6 hours is about all I've gotten out of it so far. Hi Rob, I've heard there are issues with limited range (500meters) and interference with both CAI and LX instruments. Both my GPS antenas (LX and EW) are on my glare shield and do not interfere with each other but from the reports I have heard I am concerned that putting my PowerFlarm on the glare shield will not work. Where are your GPS antenas located? 30cm away from GPS antennas AND the compass is not realistic in most gliders... Thanks for any info you may have, Luke |
For what it’s worth, I had interference it seemed with a Flarm GPS
aerial too close to my Volkslogger. I then put the Flarm GPS aerial on my headrest instead of the top of the instrument panel coaming, and that fixed it. On my Flarm (small Swiss type, not PowerFlarm), the GPS aerial came with a long lead so it was easy to do that. Chris N I've heard there are issues with limited range (500meters) and interference with both CAI and LX instruments. Both my GPS antenas (LX and EW) are on my glare shield and do not interfere with each other but from the reports I have heard I am concerned that putting my PowerFlarm on the glare shield will not work. Where are your GPS antenas located? 30cm away from GPS antennas AND the compass is not realistic in most gliders... Thanks for any info you may have, Luke |
On 08/09/2011 4:59 PM, Chris Nicholas wrote:
For what it’s worth, I had interference it seemed with a Flarm GPS aerial too close to my Volkslogger. I then put the Flarm GPS aerial on my headrest instead of the top of the instrument panel coaming, and that fixed it. On my Flarm (small Swiss type, not PowerFlarm), the GPS aerial came with a long lead so it was easy to do that. Chris N I've heard there are issues with limited range (500meters) and interference with both CAI and LX instruments. Both my GPS antenas (LX and EW) are on my glare shield and do not interfere with each other but from the reports I have heard I am concerned that putting my PowerFlarm on the glare shield will not work. Where are your GPS antenas located? 30cm away from GPS antennas AND the compass is not realistic in most gliders... Thanks for any info you may have, Luke Thanks Chris |
On 8/9/2011 1:01 PM, Luke wrote:
On 08/09/2011 12:58 AM, Rob Cluxton wrote: Where are your GPS antenas located? 30cm away from GPS antennas AND the compass is not realistic in most gliders... How can the compass interfere with the GPS signal? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl |
On 08/09/2011 5:42 PM, Eric Greenwell wrote:
On 8/9/2011 1:01 PM, Luke wrote: On 08/09/2011 12:58 AM, Rob Cluxton wrote: Where are your GPS antenas located? 30cm away from GPS antennas AND the compass is not realistic in most gliders... How can the compass interfere with the GPS signal? I'm not sure but here is a quote from the manual: "The PowerFLARM® and any associated aerials should be located as far away as possible -- at least 30 cm (1 ft) -- away from any other GPS aerial and the magnetic compass." Luke |
At 21:48 09 August 2011, Luke wrote:
On 08/09/2011 5:42 PM, Eric Greenwell wrote: On 8/9/2011 1:01 PM, Luke wrote: On 08/09/2011 12:58 AM, Rob Cluxton wrote: Where are your GPS antenas located? 30cm away from GPS antennas AND the compass is not realistic in most gliders... How can the compass interfere with the GPS signal? I'm not sure but here is a quote from the manual: "The PowerFLARM� and any associated aerials should be located as far away as possible -- at least 30 cm (1 ft) -- away from any other GPS aerial and the magnetic compass." Luke You guys ARE joking, right?? Cookie |
away as possible -- at least 30 cm (1 ft) -- away from any other GPS aerial and the magnetic compass." Luke You guys ARE joking, right?? Cookie No one is joking but it is very disturbing to be told about this installation constraint after having placed an order and sent in a payment. The constraint, if complied with, will make it almost impossible to fit the unit in a glider equipped for contest flying. Andy |
Andy Durbin wrote:
"The PowerFLARM� and any associated aerials should be located as far away as possible -- at least 30 cm (1 ft) -- away from any other GPS aerial and the magnetic compass." Luke You guys ARE joking, right?? Cookie No one is joking but it is very disturbing to be told about this installation constraint after having placed an order and sent in a payment. The constraint, if complied with, will make it almost impossible to fit the unit in a glider equipped for contest flying. Andy This should not surprise anybody and I can think of a lot more to be "highly disturbed" about in life than this. C'mon we really are not whining about this are we? You cannot undo the laws of electrodynamics. The compass is going to be affected by components in the PowerFLARM and by electrical currents. Cautious advice like this from a vendor is entirely appropriate for a device that might well get put up on a glareshield near the compass in a certified (even IFR) aircraft. Now why is it a worry? How many of us rely on our compasses? To high accuracy? The manual is just providing a suitable caution and covering FLARM's ass. What is actually much more important is the correct installation with respect to the antennas being free of conductive obstructions/surfaces as the manual warns. Still I just know we'll stumble across these units and antennas buried behind panels with owners unsure why they don't work properly. Darryl |
At 20:18 10 August 2011, Darryl Ramm wrote:
This should not surprise anybody and I can think of a lot more to be "highly disturbed" about in life than this. C'mon we really are not whining about this are we? You cannot undo the laws of electrodynamics. The compass is going to be affected by components in the PowerFLARM and by electrical currents. Cautious advice like this from a vendor is entirely appropriate for a device that might well get put up on a glareshield near the compass in a certified (even IFR) aircraft. Now why is it a worry? How many of us rely on our compasses? To high accuracy? The manual is just providing a suitable caution and covering FLARM's ass. What is actually much more important is the correct installation with respect to the antennas being free of conductive obstructions/surfaces as the manual warns. Still I just know we'll stumble across these units and antennas buried behind panels with owners unsure why they don't work properly. Darryl Who said anyone was "highly disturbed"? I didn't. Can you cite any other GPS based gliding equipment that requires the GPS antenna to be installed more than 30cm from any other GPS antenna? I don't give a rat's arse about the compass but I do care that my other GPS receivers (currently 3 of them behind or on the panel) continue to work and there are reports from Uvalde of interference to other GPS based equipment. Sure FLARM is covering their arse. If there are problems of interference with other equipment the first question will be "Did you meet the antenna separation requirements?" Why would anyone buy a piece of equipment knowing that they could not meet the installation requirements? Why would anyone build equipment with strict antenna separation requirements and then make the radiating antenna non removable thus preventing it's relocation? PowerFLARM has to work with closer antenna separation that 30cm. If it cannot, it needs a design change. If it can, the user manual needs to be revised. Andy |
PowerFLARM at Uvalde | Paul Remde | Soaring | 19 | August 1st 11 05:52 AM |
Status PowerFLARM for USA | Andrzej Kobus | Soaring | 0 | May 17th 11 10:21 PM |
PowerFlarm rentals | Lee[_11_] | Soaring | 20 | November 22nd 10 09:23 PM |
PowerFLARM | Paul Remde | Soaring | 9 | November 6th 10 04:30 AM |
PowerFLARM | Greg Arnold[_2_] | Soaring | 6 | November 2nd 10 09:32 AM |
