link.net... 54-60 mHz carrier at 55.125 (55.125 * 2) + (2 * 10.7) = 131.65 (55.125 * 2) + 10.7 = 120.95 76-82 mHz carrier at 77.125 (77.125 * 2) - (2 * 10.7) = 132.85 225.525 (digital? ham repeater?) - 77.125 - (2 * 10.7) = 127.00. Just playing... If it's intermittent then are there any ham repeaters or other comms repeaters in the area? And, two, a 'directional' antenna. If an AM radio station was causing the problems and you wanted to know which mast was causing it, you could tune in the ADF and see where the needle points! :-) If the source is outside the plane, you're conclusively dealing with front end overload intermodulation interference. Unless you're getting in-band interference from outside the plane, such as harmonics, intermod from rusty bolts or other transmitters as others have mentioned, etc. If that's the case: 1) high-Q bandpass filtering, to eliminate the out-of-band interference sources. wouldn't work. I'd say it was worth a try first though, relatively easy to stick in-line with an antenna and it would get rid of most of the out of band signal straight off. Not to leave the filter there but just as a trial to see if the interference is in-band or out-of-band. Paul |
