On Aug 22, 8:47*am, John Cochrane
wrote: A little rudder to help the turn along, a little back stick because we're not as high as we thought, and in the glider goes. I can't help but wonder how many fewer people would ever have the idea to try the above if it hadn't been suggested to them by their instructor's patter during training. |
On Aug 21, 10:27*pm, Bruce Hoult wrote:
On Aug 22, 8:47*am, John Cochrane wrote: A little rudder to help the turn along, a little back stick because we're not as high as we thought, and in the glider goes. I can't help but wonder how many fewer people would ever have the idea to try the above if it hadn't been suggested to them by their instructor's patter during training. What!!! Are you ou are suggesting that there are instructors out there who advocate raising the nose and over ruddering in the pattern! ? Cookie |
On Aug 23, 12:10*am, Cookie wrote:
On Aug 21, 10:27*pm, Bruce Hoult wrote: On Aug 22, 8:47*am, John Cochrane wrote: A little rudder to help the turn along, a little back stick because we're not as high as we thought, and in the glider goes. I can't help but wonder how many fewer people would ever have the idea to try the above if it hadn't been suggested to them by their instructor's patter during training. What!!! *Are you ou are suggesting that there are instructors out there who advocate raising the nose and over ruddering in the pattern! * ? "suggesting" is literally "putting the thought into your mind" It is not the same as advocating. Someone can be saying "don't do this" while you're thinking "wtf? I'd have never thought of trying to 'help' a turn with rudder!" And there it is. The thought is now in your mind, ready to recall goodness knows when under stress, when that thought would never otherwise have entered your head. |
On Aug 21, 9:27*pm, Bruce Hoult wrote:
On Aug 22, 8:47*am, John Cochrane wrote: A little rudder to help the turn along, a little back stick because we're not as high as we thought, and in the glider goes. I can't help but wonder how many fewer people would ever have the idea to try the above if it hadn't been suggested to them by their instructor's patter during training. I don't think any instructor suggests this sort of thing actively. Instructors try to remove these bad thoughts and unconscious habits, and sometimes are not able completely to do so. Becoming an instructor has been a great learning experience, as I have been able to see these things happen. You can have a student with great coordination and glidepath control at altitude, and who can explain everything perfectly on oral quizzing. Then, things get a little tight in the pattern, like he's too close and too low. His attention gets focused elsewhere and stress goes up, and next thing you know the yaw string is right over to the side on base to final and he wants to pull the stick back. Instructing makes you a better pilot: If he can do this, I can do it too, and helping the student avoid the bad thought patterns helps the instructor as well Tom Knauff has been very insightful on this. It's not bad ideas put there by instructors. It's subconscious bad ideas that only bubble to the surface in times of stress and attention focused elsewhere. And detecting these, giving students experiences with high stress situations, purging the bad thoughts, and all of this safely, is quite hard. John Cochrane |
On Aug 23, 1:50*am, John Cochrane
wrote: You can have a student with great coordination and glidepath control at altitude, and who can explain everything perfectly on oral quizzing. Then, things get a little tight in the pattern, like he's too close and too low. His attention gets focused elsewhere and stress goes up, and next thing you know the yaw string is right over to the side on base to final and he wants to pull the stick back. That's another one which I've asked about here before, but no one has ever answered. Around here we have ridges and students are very likely to have quite a bit of practice at doing well-banked coordinated turns while a lot closer to the ground than normal base-to-final turns, in the presence of considerable wind drift, groundspeed higher than airspeed (approaching the ridge from upwind) etc. Is there correlation between screwed-up base to final turns and flatland fliers? |
On Aug 22, 8:34*pm, Bruce Hoult wrote:
On Aug 23, 1:50*am, John Cochrane wrote: You can have a student with great coordination and glidepath control at altitude, and who can explain everything perfectly on oral quizzing. Then, things get a little tight in the pattern, like he's too close and too low. His attention gets focused elsewhere and stress goes up, and next thing you know the yaw string is right over to the side on base to final and he wants to pull the stick back. That's another one which I've asked about here before, but no one has ever answered. Around here we have ridges and students are very likely to have quite a bit of practice at doing well-banked coordinated turns while a lot closer to the ground than normal base-to-final turns, in the presence of considerable wind drift, groundspeed higher than airspeed (approaching the ridge from upwind) etc. Is there correlation between screwed-up base to final turns and flatland fliers? Quite possibly. Mountain pilots know they can't trust the horizon so they learn to control pitch attitude with airspeed and bank with rate of turn. Mountain flying requires a bit of instrument skills. I've ridden with pilots who were trying to keep their wings parallel to sloping ground and point their nose at mountain peaks. Airports like Leadville and Teluride in Colorado are notorious for inducing false attitude illusions. Taking this a bit further into the technical - I've set up turn-to- final stall/spin scenarios while practicing stalls at altitude. The result is almost always a wing drop followed by a spiral dive. The glider is designed to resist spinning so it recovers from the incipient spin on it's own it the first eighth of a turn leading to a spiral dive. If the student applies spin recovery control inputs in a spiral dive, it gets VERY "interesting". This has led me to wonder if some so called "stall/spin" accidents are really mis-handled spiral dive recoveries. Maybe we should take a careful look at what we are teaching. |
On Tuesday, August 23, 2011 12:32:43 PM UTC-4, Bill D wrote:
If the student applies spin recovery control inputs in a spiral dive, it gets VERY "interesting". This has led me to wonder if some so called "stall/spin" accidents are really mis-handled spiral dive recoveries. Maybe we should take a careful look at what we are teaching. That's how an Eta was destroyed during spin testing IIRC... |
On Aug 24, 4:32*am, Bill D wrote:
On Aug 22, 8:34*pm, Bruce Hoult wrote: On Aug 23, 1:50*am, John Cochrane wrote: You can have a student with great coordination and glidepath control at altitude, and who can explain everything perfectly on oral quizzing. Then, things get a little tight in the pattern, like he's too close and too low. His attention gets focused elsewhere and stress goes up, and next thing you know the yaw string is right over to the side on base to final and he wants to pull the stick back. That's another one which I've asked about here before, but no one has ever answered. Around here we have ridges and students are very likely to have quite a bit of practice at doing well-banked coordinated turns while a lot closer to the ground than normal base-to-final turns, in the presence of considerable wind drift, groundspeed higher than airspeed (approaching the ridge from upwind) etc. Is there correlation between screwed-up base to final turns and flatland fliers? Quite possibly. *Mountain pilots know they can't trust the horizon so they learn to control pitch attitude with airspeed and bank with rate of turn. *Mountain flying requires a bit of instrument skills. Hmm. I don't think that's true, at least for me. You don't need an actual horizon, all you need is something far enough away that if it moves in the canopy it's because the aircraft attitude changed. It doesn't even have to be straight ahead -- well out to the side is fine. Even with a true horizon available, you're only using the horizon for short term attitude stability and cross-referencing it to something else (wind noise, control feel, airspeed indicator) to calibrate what attitude you should be holding. I've had the very interesting experience of flying with a friend doing overnight freight runs in small turboprops (e.g. Cessna Caravan). When you're ostensibly flying on instruments and using the artificial horizon for attitude control, it's quite astounding how much difference there is between having even two or three external points of light from stars or farmhouses and not having them. When you're deep in IMC in the middle of nowhere you are working very very hard. When you have even the slightest external references that you may not even be consciously aware of it gets 10x easier. Your theory sounds more appropriate for people flying in severe haze or cloud. |
On Aug 22, 8:47*am, John Cochrane wrote: A little rudder to help the turn along, a little back stick because we're not as high as we thought, and in the glider goes. I can't help but wonder how many fewer people would ever have the idea to try the above if it hadn't been suggested to them by their instructor's patter during training. I'm with JJ on this topic. I find it incredible that just about every glider with retractable gear has a gear warning alarm to keep from damaging the gelcoat or a couple of layers of carbon on the belly, but we don't have an "Open Spoiler" alarm to prevent someone from dying on tow.. |
On 8/22/2011 9:12 AM, Mike wrote:
On Aug 21, 10:27 pm, Bruce wrote: On Aug 22, 8:47 am, John wrote: A little rudder to help the turn along, a little back stick because we're not as high as we thought, and in the glider goes. I can't help but wonder how many fewer people would ever have the idea to try the above if it hadn't been suggested to them by their instructor's patter during training. I'm with JJ on this topic. I find it incredible that just about every glider with retractable gear has a gear warning alarm to keep from damaging the gelcoat or a couple of layers of carbon on the belly, but we don't have an "Open Spoiler" alarm to prevent someone from dying on tow.. I think a "open spoiler on tow" is a great idea, and I've had one for several years, as do some other people. If you have a Cambridge 302 vario, it's easy to add one, especially if it's already used for your gear warning. Operation is simple: if your spoilers are still unlocked as the airspeed increases past ~25 knots, you get an audible warning. It works for towed gliders and motorgliders, using the same gear and spoiler switches used for the gear warning - no changes in wiring needed. Perhaps even better than a warning device is one that prevents them from opening in the first place. DG gliders can do a retrofit of the "Piggot hook" that prevents the spoilers from opening if they are left unlocked. Get the info from DG. Many gliders (at least experimental licensed ones) can be easily fitted with a similar device. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
Glider fatality in Idaho | Hellman | Soaring | 9 | August 23rd 09 02:15 PM |
Anyone here know Driggs, Idaho (DIJ) | Bob Chilcoat | Piloting | 2 | June 23rd 06 11:46 PM |
Mackay, IDAHO | [email protected] | Soaring | 0 | May 6th 06 01:29 AM |
Soaring on Idaho Public TV | Wayne Paul | Soaring | 4 | February 5th 05 04:14 PM |
helicopter crash in Idaho | Bill Chernoff | Rotorcraft | 0 | April 29th 04 05:49 PM |
