A bungee cord can be attached to the air brake handle and the other end
attached to a forward location. This will keep the air brakes closed even though they are not locked. I have used this system on several gliders. At 21:47 22 August 2011, Eric Greenwell wrote: On 8/22/2011 9:12 AM, Mike wrote: On Aug 21, 10:27 pm, Bruce Hoult wrote: On Aug 22, 8:47 am, John Cochrane wrote: A little rudder to help the turn along, a little back stick because we're not as high as we thought, and in the glider goes. I can't help but wonder how many fewer people would ever have the idea to try the above if it hadn't been suggested to them by their instructor's patter during training. I'm with JJ on this topic. I find it incredible that just about every glider with retractable gear has a gear warning alarm to keep from damaging the gelcoat or a couple of layers of carbon on the belly, but we don't have an "Open Spoiler" alarm to prevent someone from dying on tow.. I think a "open spoiler on tow" is a great idea, and I've had one for several years, as do some other people. If you have a Cambridge 302 vario, it's easy to add one, especially if it's already used for your gear warning. Operation is simple: if your spoilers are still unlocked as the airspeed increases past ~25 knots, you get an audible warning. It works for towed gliders and motorgliders, using the same gear and spoiler switches used for the gear warning - no changes in wiring needed. Perhaps even better than a warning device is one that prevents them from opening in the first place. DG gliders can do a retrofit of the "Piggot hook" that prevents the spoilers from opening if they are left unlocked. Get the info from DG. Many gliders (at least experimental licensed ones) can be easily fitted with a similar device. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On 8/22/2011 9:12 AM, Mike wrote: On Aug 21, 10:27 pm, Bruce Hoult wrote: On Aug 22, 8:47 am, John Cochrane wrote: A little rudder to help the turn along, a little back stick because we're not as high as we thought, and in the glider goes. I can't help but wonder how many fewer people would ever have the idea to try the above if it hadn't been suggested to them by their instructor's patter during training. I'm with JJ on this topic. I find it incredible that just about every glider with retractable gear has a gear warning alarm to keep from damaging the gelcoat or a couple of layers of carbon on the belly, but we don't have an "Open Spoiler" alarm to prevent someone from dying on tow.. I think a "open spoiler on tow" is a great idea, and I've had one for several years, as do some other people. If you have a Cambridge 302 vario, it's easy to add one, especially if it's already used for your gear warning. Operation is simple: if your spoilers are still unlocked as the airspeed increases past ~25 knots, you get an audible warning. It works for towed gliders and motorgliders, using the same gear and spoiler switches used for the gear warning - no changes in wiring needed. Perhaps even better than a warning device is one that prevents them from opening in the first place. DG gliders can do a retrofit of the "Piggot hook" that prevents the spoilers from opening if they are left unlocked. Get the info from DG. Many gliders (at least experimental licensed ones) can be easily fitted with a similar device. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz A bungee cord can be attached to the air brake handle with the other end fastened to a forward location. This will keep the air brakes closed even though they are not locked. I have used this system on several gliders. Don, 70 |
![]() At 21:47 22 August 2011, Eric Greenwell wrote: On 8/22/2011 9:12 AM, Mike wrote: On Aug 21, 10:27 pm, Bruce Hoult wrote: On Aug 22, 8:47 am, John Cochrane wrote: A little rudder to help the turn along, a little back stick because we're not as high as we thought, and in the glider goes. I can't help but wonder how many fewer people would ever have the idea to try the above if it hadn't been suggested to them by their instructor's patter during training. I'm with JJ on this topic. I find it incredible that just about every glider with retractable gear has a gear warning alarm to keep from damaging the gelcoat or a couple of layers of carbon on the belly, but we don't have an "Open Spoiler" alarm to prevent someone from dying on tow.. I think a "open spoiler on tow" is a great idea, and I've had one for several years, as do some other people. If you have a Cambridge 302 vario, it's easy to add one, especially if it's already used for your gear warning. Operation is simple: if your spoilers are still unlocked as the airspeed increases past ~25 knots, you get an audible warning. It works for towed gliders and motorgliders, using the same gear and spoiler switches used for the gear warning - no changes in wiring needed. Perhaps even better than a warning device is one that prevents them from opening in the first place. DG gliders can do a retrofit of the "Piggot hook" that prevents the spoilers from opening if they are left unlocked. Get the info from DG. Many gliders (at least experimental licensed ones) can be easily fitted with a similar device. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz A bungee cord can be fastened to the air brake handle with the other end fastened to a forward location. This will keep the air brakes closed even though they are not locked. I have used this system on several gliders. |
On Aug 22, 2:47*pm, Eric Greenwell wrote:
I think a "open spoiler on tow" is a great idea, and I've had one for several years, as do some other people. If you have a Cambridge 302 vario, it's easy to add one, especially if it's already used for your gear warning. Is that a configuration option on the 302? I have the gear warning but don't recall a dive brake warning menu item. If it's not available on the 302 how do you get an electronic airspeed input? 9B |
On 9/7/11 9:38 PM, Andy wrote:
On Aug 22, 2:47 pm, Eric wrote: I think a "open spoiler on tow" is a great idea, and I've had one for several years, as do some other people. If you have a Cambridge 302 vario, it's easy to add one, especially if it's already used for your gear warning. Is that a configuration option on the 302? I have the gear warning but don't recall a dive brake warning menu item. If it's not available on the 302 how do you get an electronic airspeed input? 9B It is a standard feature of the Cambridge 302. Details are hidden away in the C302 manual in a section deviously titled "The Airbrake and Landing Gear Warning Switches" :-) But you are throwing all this out for an LX9000 and presumably LX varios.... Darryl |
Glider fatality in Idaho | Hellman | Soaring | 9 | August 23rd 09 02:15 PM |
Anyone here know Driggs, Idaho (DIJ) | Bob Chilcoat | Piloting | 2 | June 23rd 06 11:46 PM |
Mackay, IDAHO | [email protected] | Soaring | 0 | May 6th 06 01:29 AM |
Soaring on Idaho Public TV | Wayne Paul | Soaring | 4 | February 5th 05 04:14 PM |
helicopter crash in Idaho | Bill Chernoff | Rotorcraft | 0 | April 29th 04 05:49 PM |
