XC Soaring camps
Old August 24th 11, 04:09 PM posted to rec.aviation.soaring
John Cochrane[_2_]
Default XC Soaring camps
Then there is the old fashioned way. With an ASW19, 100 hours, a
license, a bronze badge (which means you know how to thermal) and
power experience (which means you know how to navigate and use
airspace)... just go! All of the rest of us got going in cross country
by simply looking at a map, picking a simple course to some nearby
airports, and going. Sure, it was slow the first time.
Is there nobody flying XC at your club to talk to? Just ask for some
advice on the simplest triangle. If not, pick a better club!
Instruction, camps, and contests will all be more fruitful once you've
been out a few times. You have to go do it, get some sense of visual
navigation and thermaling and gliding, before you can really benefit
from camps and such. The camps will tell you to go faster, to stop
taking every thermal. You can't really take that advice until you've
been out a few times. Go when you're at a plateau.
You really only get good at cross country by going every weekend. And
it really is a self-taught exercise. A little instruction here and
there can help a lot, but 99% of learning to fly cross country is,
read all the material on the ground, then go try it out in the air. By
yourself.
John Cochrane
Old September 15th 11, 05:22 AM posted to rec.aviation.soaring
Tom Serkowski
yourself.
As others have said, most of us "old timers" (I started in 1973) did it
all solo. After several years, I hooked up with a Janus owner and flew
as co pilot in numerous contests. I still recall the first few flights
were HUGE eye-openers for me and my XC technique.
So my suggestion is to go fly dual XC with an EXPERIENCED pilot. One or
two flights of a few hundred km will provide all the incentive and
observed skills you'll need for a long time to come.
It's also a lot easier to get even the most aloof pilot to critique your
performance, no matter how bad, than to talk to someone with no
perceived common ground. So just go fly, then talk about it at the end
of the day with those guys who flew hundreds to your tens of kilometers.
Launch first, act as sniffer, then when the "big dogs" climb through
you and take off, try to follow. Maybe you'll keep up to the next
thermal, maybe not. Then, at the end of the day, ask what they were
thinking when they left you in the dust. Next time, you'll keep up for
2 thermals, etc...
This is also the perfect way to learn at a contest. Start early, then
latch onto each pilot for a few minutes as they overtake you. Most will
be happy to share decisions made while sharing your airspace. BUT
REMEMBER to fly your own flight at YOUR comfort level. Don't do
anything that makes you uncomfortable, and be sure to maintain
situational awareness as you follow.
-Tom
Feedback needed on Advanced Soaring Made Easy book for Soaring Magazine review Paul Remde Soaring 1 April 14th 11 03:57 AM
US Internment camps to be built by an Israeli company [email protected] Naval Aviation 0 March 8th 05 11:24 PM
Year 2005 US Team Sponsered Camps Orion Kingman Soaring 3 January 9th 05 07:31 PM
Soaring Server/Worldwide Soaring Turnpoint Exchange back online John Leibacher Soaring 0 June 21st 04 05:25 PM
