On Sep 6, 3:47*pm, Walt Connelly Walt.Connelly.
wrote: There appears to be some disagreement with the comments that this collision occurred in a thermal. *Found the following comments online regarding this accident. From Fun Junkie: This was a tragic ACCIDENT, nothing more. Having reviewed the gps logs of each gliders flight path and the video of the collision, there are two things that need to be cleared up. First, neither glider was in a thermal so the discussions about that are pointless. Second, neither glider was "show boating" or doing anything unsafe at the time of the collision, or prior to it. They were simply flying in an area they knew very well and have flown hundreds of times before. On this particular flight they happened to be flying in the same geographical area but approaching from opposite directions. Both gliders were in essentially level flight and at the same altitude. For whatever reason... they simply did not see each other in sufficient time to avoid a collision. Gliders approaching each other at the same altitude are very difficult to see and close on each other very quickly. As a friend and fellow pilot of both Keith and Ray, I will miss them dearly and offer my sincerest condolences to their families and friends. This was simply a very tragic accident between two pilots who took flying safety very seriously. End of comments Amazing how often the facts of the case take a long time to become clear. *The idea that they were not in a thermal makes more sense to me. Walt -- Walt Connelly quite frankly this is what really scares the **** out of me, and pardon my french...................but I can't tell you how many times I've lost track of my flying buddies only to have them appear where I did not expect them. and this is with constant radio contact and position reports. anyone that tells you a proper scan will always save the day is dreaming.................it will work until the day it doesn't and then dog help us. Brad |
A PowerFlarm might have prevented this accident. I am getting one.
Mike Green On 9/6/2011 7:40 PM, Brad wrote: On Sep 6, 3:47 pm, Walt ConnellyWalt.Connelly. wrote: There appears to be some disagreement with the comments that this collision occurred in a thermal. Found the following comments online regarding this accident. From Fun Junkie: This was a tragic ACCIDENT, nothing more. Having reviewed the gps logs of each gliders flight path and the video of the collision, there are two things that need to be cleared up. First, neither glider was in a thermal so the discussions about that are pointless. Second, neither glider was "show boating" or doing anything unsafe at the time of the collision, or prior to it. They were simply flying in an area they knew very well and have flown hundreds of times before. On this particular flight they happened to be flying in the same geographical area but approaching from opposite directions. Both gliders were in essentially level flight and at the same altitude. For whatever reason... they simply did not see each other in sufficient time to avoid a collision. Gliders approaching each other at the same altitude are very difficult to see and close on each other very quickly. As a friend and fellow pilot of both Keith and Ray, I will miss them dearly and offer my sincerest condolences to their families and friends. This was simply a very tragic accident between two pilots who took flying safety very seriously. End of comments Amazing how often the facts of the case take a long time to become clear. The idea that they were not in a thermal makes more sense to me. Walt -- Walt Connelly quite frankly this is what really scares the **** out of me, and pardon my french...................but I can't tell you how many times I've lost track of my flying buddies only to have them appear where I did not expect them. and this is with constant radio contact and position reports. anyone that tells you a proper scan will always save the day is dreaming.................it will work until the day it doesn't and then dog help us. Brad |
On Sep 6, 8:10*pm, Mike I Green wrote:
A PowerFlarm might have prevented this accident. *I am getting one. Mike Green On 9/6/2011 7:40 PM, Brad wrote: On Sep 6, 3:47 pm, Walt ConnellyWalt.Connelly. *wrote: There appears to be some disagreement with the comments that this collision occurred in a thermal. *Found the following comments online regarding this accident. *From Fun Junkie: This was a tragic ACCIDENT, nothing more. Having reviewed the gps logs of each gliders flight path and the video of the collision, there are two things that need to be cleared up. First, neither glider was in a thermal so the discussions about that are pointless. Second, neither glider was "show boating" or doing anything unsafe at the time of the collision, or prior to it. They were simply flying in an area they knew very well and have flown hundreds of times before. On this particular flight they happened to be flying in the same geographical area but approaching from opposite directions. Both gliders were in essentially level flight and at the same altitude. For whatever reason... they simply did not see each other in sufficient time to avoid a collision. Gliders approaching each other at the same altitude are very difficult to see and close on each other very quickly. As a friend and fellow pilot of both Keith and Ray, I will miss them dearly and offer my sincerest condolences to their families and friends. This was simply a very tragic accident between two pilots who took flying safety very seriously. End of comments Amazing how often the facts of the case take a long time to become clear. *The idea that they were not in a thermal makes more sense to me. Walt -- Walt Connelly quite frankly this is what really scares the **** out of me, and pardon my french...................but I can't tell you how many times I've lost track of my flying buddies only to have them appear where I did not expect them. and this is with constant radio contact and position reports. anyone that tells you a proper scan will always save the day is dreaming.................it will work until the day it doesn't and then dog help us. Brad As I have reported here before, I had a close head-on with a fellow club member a couple of years ago. We were flying in opposite directions along a cloudstreet and were in radio contact. I suddenly saw a flash of orange ahead and slightly to my right, so I instinctively climbed and banked left. My colleague passed not fifty feet under my right wing and he never even saw me. One of the few times that anti-collision markings helped (my glider has none). A review of our GPS traces showed us closing at a speed of over 200 mph (300 feet per second) and the time between seeing a head-on glider and impact was barely sufficient to react. Electronic countermeasures are the only solution. Mike |
![]() Quote:
Mid airs have always been my biggest source of fear in soaring. I get upset with myself everytime I notice a Cessna after it has already passed me! I watched a Challenger pass by once at the same altitude and thought to myself that I would have 0 chance avoiding a head on with a jet. I`m borderline obsessive with keeping track of every other glider in the air and I`m still surprised how many times I loose people and find them again much closer than expected. Matt |
I have a transponder, PCAS and FLARM on order. Last spring I added a
BRS, its amazing how much the BRS makes me feel secure. They have been successfully deployed as low as 260 feet. Cheers, JJ Oh, yeah, I also have a radio............and I use it when running under a cloud street as in "JJ just turned Hayfork and is southbound at16". |
And, speaking of jets...
Years ago, while climbing above the Black Forest Glider Port at about 11,000 MSL (4,000 AGL), I noticed a tiny spot on the horizon to the south. On the next turn, I saw the B-757 maneuvering to avoid a collision with me! I was thankful that those guys had their heads outside the cockpit and saw me because I had no chance to avoid a collision. I always wondered why the FAA routed airliners traveling between Colorado Springs (COS) and Denver (DEN) directly over our small airpark at 11,000' MSL. And to bore everyone further - back in the late 70s, and before knowing anything about gliders, I was flight engineer on a B-727 on a leg between DEN (the old Stapleton airport) and COS. Our clearance took us directly down the ramparts of the Front Range and the captain said, "Let's see how fast this baby will go!". We were cruising at 350 KIAS at 11,000 MSL right over prime glider territory! I don't recall the season and I've always wondered if there were any gliders there at the time... "Matt RX" wrote in message ...[color=blue][i] Mike the Strike;782551 Wrote: On Sep 6, 8:10*pm, Mike I Green wrote: A PowerFlarm might have prevented this accident. *I am getting one. Mike Green As I have reported here before, I had a close head-on with a fellow club member a couple of years ago. We were flying in opposite directions along a cloudstreet and were in radio contact. I suddenly saw a flash of orange ahead and slightly to my right, so I instinctively climbed and banked left. My colleague passed not fifty feet under my right wing and he never even saw me. One of the few times that anti-collision markings helped (my glider has none). A review of our GPS traces showed us closing at a speed of over 200 mph (300 feet per second) and the time between seeing a head-on glider and impact was barely sufficient to react. Electronic countermeasures are the only solution. Mike Report on CBC radio this morning indicated that the Canadian Rockies Soaring Club had just ordered FLARM for all their gliders prior to the accident.... Unforunatley not installed in time. Not sure if the gliders involved were club ships. I met Keith Watson a few weeks ago when he dropped by the club I fly with and we talked for quite some time while I was working on my LS-3. Nice guy and I was sadened to hear about the accident. Mid airs have always been my biggest source of fear in soaring. I get upset with myself everytime I notice a Cessna after it has already passed me! I watched a Challenger pass by once at the same altitude and thought to myself that I would have 0 chance avoiding a head on with a jet. I`m borderline obsessive with keeping track of every other glider in the air and I`m still surprised how many times I loose people and find them again much closer than expected. Matt -- Matt RX |
On Sep 8, 8:01*am, "Dan Marotta" wrote:[color=blue][i]
And, speaking of jets... Years ago, while climbing above the Black Forest Glider Port at about 11,000 MSL (4,000 AGL), I noticed a tiny spot on the horizon to the south. *On the next turn, I saw the B-757 maneuvering to avoid a collision with me! *I was thankful that those guys had their heads outside the cockpit and saw me because I had no chance to avoid a collision. I always wondered why the FAA routed airliners traveling between Colorado Springs (COS) and Denver (DEN) directly over our small airpark at 11,000' MSL. And to bore everyone further - back in the late 70s, and before knowing anything about gliders, I was flight engineer on a B-727 on a leg between DEN (the old Stapleton airport) and COS. *Our clearance took us directly down the ramparts of the Front Range and the captain said, "Let's see how fast this baby will go!". *We were cruising at 350 KIAS at 11,000 MSL right over prime glider territory! *I don't recall the season and I've always wondered if there were any gliders there at the time... "Matt RX" wrote in message ... Mike the Strike;782551 Wrote: On Sep 6, 8:10*pm, Mike I Green wrote: A PowerFlarm might have prevented this accident. *I am getting one. Mike Green As I have reported here before, I had a close head-on with a fellow club member a couple of years ago. *We were flying in opposite directions along a cloudstreet and were in radio contact. *I suddenly saw a flash of orange ahead and slightly to my right, so I instinctively climbed and banked left. *My colleague passed not fifty feet under my right wing and he never even saw me. *One of the few times that anti-collision markings helped (my glider has none). *A review of our GPS traces showed us closing at a speed of over 200 mph (300 feet per second) and the time between seeing a head-on glider and impact was barely sufficient to react. Electronic countermeasures are the only solution. Mike Report on CBC radio this morning indicated that the Canadian Rockies Soaring Club had just ordered FLARM for all their gliders prior to the accident.... Unforunatley not installed in time. Not sure if the gliders involved were club ships. I met Keith Watson a few weeks ago when he dropped by the club I fly with and we talked for quite some time while I was working on my LS-3. Nice guy and I was sadened to hear about the accident. Mid airs have always been my biggest source of fear in soaring. I get upset with myself everytime I notice a Cessna after it has already passed me! I watched a Challenger pass by once at the same altitude and thought to myself that I would have 0 chance avoiding a head on with a jet. I`m borderline obsessive with keeping track of every other glider in the air and I`m still surprised how many times I loose people and find them again much closer than expected. Matt -- Matt RX- Hide quoted text - - Show quoted text - Dan, I assume you were not flying with a transponder at that time, but flying with one now. Since I started flying with transponders I never saw an airliner too close, and I am flying in some of the most busy airspaces in the US (Bay Area and Reno). But transponder wouldn't have saved those folks. Flarm could. How tragic. Ramy |
Yes, I'm flying with a transponder now and I see a lot of arriving and
departing traffic to ABQ. As you noted, they don't seem too close so I guess it's working! "Ramy" wrote in message ... On Sep 8, 8:01 am, "Dan Marotta" wrote:[color=blue][i] And, speaking of jets... Years ago, while climbing above the Black Forest Glider Port at about 11,000 MSL (4,000 AGL), I noticed a tiny spot on the horizon to the south. On the next turn, I saw the B-757 maneuvering to avoid a collision with me! I was thankful that those guys had their heads outside the cockpit and saw me because I had no chance to avoid a collision. I always wondered why the FAA routed airliners traveling between Colorado Springs (COS) and Denver (DEN) directly over our small airpark at 11,000' MSL. And to bore everyone further - back in the late 70s, and before knowing anything about gliders, I was flight engineer on a B-727 on a leg between DEN (the old Stapleton airport) and COS. Our clearance took us directly down the ramparts of the Front Range and the captain said, "Let's see how fast this baby will go!". We were cruising at 350 KIAS at 11,000 MSL right over prime glider territory! I don't recall the season and I've always wondered if there were any gliders there at the time... "Matt RX" wrote in message ... Mike the Strike;782551 Wrote: On Sep 6, 8:10*pm, Mike I Green wrote: A PowerFlarm might have prevented this accident. *I am getting one. Mike Green As I have reported here before, I had a close head-on with a fellow club member a couple of years ago. We were flying in opposite directions along a cloudstreet and were in radio contact. I suddenly saw a flash of orange ahead and slightly to my right, so I instinctively climbed and banked left. My colleague passed not fifty feet under my right wing and he never even saw me. One of the few times that anti-collision markings helped (my glider has none). A review of our GPS traces showed us closing at a speed of over 200 mph (300 feet per second) and the time between seeing a head-on glider and impact was barely sufficient to react. Electronic countermeasures are the only solution. Mike Report on CBC radio this morning indicated that the Canadian Rockies Soaring Club had just ordered FLARM for all their gliders prior to the accident.... Unforunatley not installed in time. Not sure if the gliders involved were club ships. I met Keith Watson a few weeks ago when he dropped by the club I fly with and we talked for quite some time while I was working on my LS-3. Nice guy and I was sadened to hear about the accident. Mid airs have always been my biggest source of fear in soaring. I get upset with myself everytime I notice a Cessna after it has already passed me! I watched a Challenger pass by once at the same altitude and thought to myself that I would have 0 chance avoiding a head on with a jet. I`m borderline obsessive with keeping track of every other glider in the air and I`m still surprised how many times I loose people and find them again much closer than expected. Matt -- Matt RX- Hide quoted text - - Show quoted text - Dan, I assume you were not flying with a transponder at that time, but flying with one now. Since I started flying with transponders I never saw an airliner too close, and I am flying in some of the most busy airspaces in the US (Bay Area and Reno). But transponder wouldn't have saved those folks. Flarm could. How tragic. Ramy |
Transponders are not a magic shield.
I fly with a Mode S transponder in the busy Philadelphia / New York airspace. I often see airliners diverting course to go around me (particularly commuters), but then there was the Southwest 737 that flew 300 feet directly over me. I was thermalling at 5700, he was straight and level at 6000. Gliders in this area have a discrete transponder code, and we know from conversations with ATC that they're keeping track of us specifically as glider traffic. So, I know for certain that (1) the Southwest pilot was aware of me (long before I was aware of him), and (2) he was also aware that I was a glider. I'm not standing on principle here, if I'd seen him sooner I would have quit thermalling and flown 90 degrees to his track while losing altitude (quickly). But it was a hazy day, I was thermalling, he was doing 250 kts, and I just flat didn't see him until he was about a mile away. Moral - keep a good lookout, amd remember that stuff can happen in spite of a transponder... -John On Sep 8, 1:56 pm, Ramy wrote: Since I started flying with transponders I never saw an airliner too close, and I am flying in some of the most busy airspaces in the US (Bay Area and Reno). |
Exporting a glider to/import a glider into Germany | Pete Smith[_2_] | Soaring | 1 | August 8th 08 09:33 AM |
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider | [email protected] | Soaring | 5 | November 19th 06 11:08 PM |
shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 02:05 PM |
First Glider | Jeff Runciman | Soaring | 44 | October 4th 04 04:58 PM |
Looking for first glider | Jeff Runciman | Soaring | 17 | September 8th 04 08:29 PM |
