Ann Welch, a many time steward at WGC s , always warned against setting G
and R tasks due to the risk of collision; one nearly got me; about 3 secs warning. If you are running a cloud street, use the L/R lift indications to turn slightly; no longer will you be a "stationary" speck to the other pilot and the wing movment will make you easier to see. A climbing turn is even better. John F Although the encoder/altimeter weren't formally checked during the biannual transponder check, the technician did me a favor and quickly checked the correspondance at 0, 5000, 10000 and 20000 feet - they were OK. I also routinely check the transponder altitude reading against my alitimeter during each flight. So I'm pretty sure that's all OK. As for your suggestion about chatting with ATC, that didn't happen. -John On Sep 9, 6:48 pm, Darryl Ramm wrote: John So my very next thought was has the encoder/altimeter system been tested recently? A standard biannual transponder check for a non-IFR aircraft does not include a check of the altimeter/altitude encoder system, it just includes RF tests--a fairly useless throwback to the days of much less reliable traveling wave tube based transponders. The tests on first install does include altimeter/encoder tests. I've seen quite a few owners assume that the encoder/altimeter is being tested, but unless you've made arrangement with the test provider this just usually won't be done for these subsequent checks. A simple test is to compare the altimeter (when set to 29.92"Hg) and what the TT21 display says for the altitude. But that does not exclude problems like the static line being disconnected behind the panel or contaminated with water etc. If this had happened to me and I'm sure my transponder was working I'd probably contact the ATC/approach folks and have a chat - this just should not happen with a TCAS II equipped 737. Unfortunately we don't have Mode-S RA downlink really used in the USA. When used (like more widely in Europe) that provides ATC controllers with direct visibility to RA events in their airspace. Darryl |
John F,
I understand your cloud street advice, but don't understand "G and R tasks". Would you please elaborate? In the case I was describing, I was in a house thermal 3 miles from my home field, gaining altitude prepatory to starting a TAT. We get fairly frequent turboprop commuter aircraft running between 4000 to 6000 feet from NW to SE (and vice versa) close to that area (they're the ones I described as changing course to avoid us gliders), but no one could recall ever seeing a jet airliner that low going from SW to NE. It was a strange situation, made worse by him apparently not detecting me via TCAS or knowing of me via ATC - and of course, me not seeing him until he was way too close! -John On Sep 10, 9:33 am, John Firth wrote: Ann Welch, a many time steward at WGC s , always warned against setting G and R tasks due to the risk of collision; one nearly got me; about 3 secs warning. If you are running a cloud street, use the L/R lift indications to turn slightly; no longer will you be a "stationary" speck to the other pilot and the wing movment will make you easier to see. A climbing turn is even better. John F |
[quote=jcarlyle;782917]John F,
I understand your cloud street advice, but don't understand "G and R tasks". Would you please elaborate? I would think 'Goal and Return' aka Out and Return Colin |
Exporting a glider to/import a glider into Germany | Pete Smith[_2_] | Soaring | 1 | August 8th 08 09:33 AM |
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider | [email protected] | Soaring | 5 | November 19th 06 11:08 PM |
shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 02:05 PM |
First Glider | Jeff Runciman | Soaring | 44 | October 4th 04 04:58 PM |
Looking for first glider | Jeff Runciman | Soaring | 17 | September 8th 04 08:29 PM |
