Revisiting the Cambridge Model 20 OLC failures...
Old September 18th 11, 04:49 PM posted to rec.aviation.soaring
Westbender
Default Revisiting the Cambridge Model 20 OLC failures...
On Sep 15, 11:23*pm, Westbender wrote:
On Sep 12, 10:53*am, "Dan Marotta" wrote:
Same here, though I've only had one. *It validated on the first try (after
running the batch file).
"Westbender" wrote in message
Last two flight logs validated fine without issue. Not sure if
something changed with the OLC flight log validator. Hopefully it's
fixed.
Three in a row! It's looking more and more like the problem was fixed.
Yay!
Hmmm.... I see there's a couple of recent failures by other pilots
submitting logs from legacy Cambridge recorders. Looks like the
problem is not solved.
Old September 19th 11, 02:38 PM posted to rec.aviation.soaring
Dan Marotta
I submitted a log from a Model 20 yesterday and it went through perfectly
first time. Previously, I've had to submit the same log three times for it
to be accepted.
On Sep 15, 11:23 pm, Westbender wrote:
On Sep 12, 10:53 am, "Dan Marotta" wrote:
Same here, though I've only had one. It validated on the first try
(after
fixed.
Yay!
Cambridge GPS NAV Model 20 with S NAV Leigh Soaring 0 March 21st 08 07:58 PM
Cambridge GPS-Nav Model 20 Fred[_4_] Soaring 16 March 2nd 08 10:11 PM
Cambridge Model 20 to OLC Bubba Soaring 6 June 22nd 06 08:45 PM
Cambridge Model 20 to OLC Bubba Soaring 0 June 12th 06 02:30 PM
Buy -- Model 20 Cambridge GPS John Murphy Soaring 0 March 24th 05 02:32 AM
