On Sep 22, 2:54*pm, Brad wrote:
On Sep 22, 11:41*am, T8 wrote: On Sep 22, 1:14*pm, Brad wrote: Can someone familiar with the HP series of aircraft give me some info regarding the landing gear shock strut charging process? I am about ready to install it and need info on fluid type, amount and charging. Thanks, Brad N599GK Not an HP-18 strut, I hope. *I must have rebuilt mine a dozen times. Usually on great soaring days when it went flat on the way out to the line. *Just weld the ef'fing thing. *Or cut off a couple well chosen lengths of broom handle to fill the space. *The basic problem with the 18 strut was no bearing surface and no way to maintain alignment. When compressed, it would end up rubbing metal on metal inside the cylinder, it would gall, the galled surface would then make short work of the o-rings. You filled each leg with enough auto tranny fluid to reach the piston at full extension (rusty memory -- maybe 3" in ea leg), assemble, then charge from N2 bottle (best) or cessnoid type strut pump borrowed from spam-can mechanic. *It takes several hundred psi. *On the third rebuild, go find a broom that needs a shorter handle. -Evan Ludeman / T8 guys, it IS an HP-18 strut...................is this typical of all HP-18 struts? dealing with a low tire is one thing, dealing with a defective strut is another, especially on good soaring days! Brad Take a look at how the thing is built. Ask yourself what prevents metal/metal contact in the cylinder bore. In my case I think the piston (the very end, just past the o-ring groove) is what chewed up the cylinder bores. I remember trying to use a brake cylinder hone to clean things up. It might have helped a little. My ship may have had some gear alignment issues that pushed it over the edge. Obviously, it worked fairly well for others. I've seen other HPs with flat struts over the years. If I were doing it over again, I really would weld the sucker (make certain you get the alignment exactly right). Who needs a shock strut when you land at 30 mph? |
On Sep 22, 12:30*pm, T8 wrote:
On Sep 22, 2:54*pm, Brad wrote: On Sep 22, 11:41*am, T8 wrote: On Sep 22, 1:14*pm, Brad wrote: Can someone familiar with the HP series of aircraft give me some info regarding the landing gear shock strut charging process? I am about ready to install it and need info on fluid type, amount and charging. Thanks, Brad N599GK Not an HP-18 strut, I hope. *I must have rebuilt mine a dozen times.. Usually on great soaring days when it went flat on the way out to the line. *Just weld the ef'fing thing. *Or cut off a couple well chosen lengths of broom handle to fill the space. *The basic problem with the 18 strut was no bearing surface and no way to maintain alignment. When compressed, it would end up rubbing metal on metal inside the cylinder, it would gall, the galled surface would then make short work of the o-rings. You filled each leg with enough auto tranny fluid to reach the piston at full extension (rusty memory -- maybe 3" in ea leg), assemble, then charge from N2 bottle (best) or cessnoid type strut pump borrowed from spam-can mechanic. *It takes several hundred psi. *On the third rebuild, go find a broom that needs a shorter handle. -Evan Ludeman / T8 guys, it IS an HP-18 strut...................is this typical of all HP-18 struts? dealing with a low tire is one thing, dealing with a defective strut is another, especially on good soaring days! Brad Take a look at how the thing is built. * Ask yourself what prevents metal/metal contact in the cylinder bore. *In my case I think the piston (the very end, just past the o-ring groove) is what chewed up the cylinder bores. *I remember trying to use a brake cylinder hone to clean things up. *It might have helped a little. *My ship may have had some gear alignment issues that pushed it over the edge. *Obviously, it worked fairly well for others. *I've seen other HPs with flat struts over the years. *If I were doing it over again, I really would weld the sucker (make certain you get the alignment exactly right). Who needs a shock strut when you land at 30 mph? I'm leaning more and more for a rigid strut..............instead of welding, I like the idea of a broom handle/wooden dowel, that's technology I can appreciate! Brad |
On Sep 22, 12:30Â*pm, T8 wrote: On Sep 22, 2:54Â*pm, Brad wrote: On Sep 22, 11:41Â*am, T8 wrote: On Sep 22, 1:14Â*pm, Brad wrote: Can someone familiar with the HP series of aircraft give me some info regarding the landing gear shock strut charging process? I am about ready to install it and need info on fluid type, amount and charging. Thanks, Brad N599GK Not an HP-18 strut, I hope. Â*I must have rebuilt mine a dozen times. Usually on great soaring days when it went flat on the way out to the line. Â*Just weld the ef'fing thing. Â*Or cut off a couple well chosen lengths of broom handle to fill the space. Â*The basic problem with the 18 strut was no bearing surface and no way to maintain alignment. When compressed, it would end up rubbing metal on metal inside the cylinder, it would gall, the galled surface would then make short work of the o-rings. You filled each leg with enough auto tranny fluid to reach the piston at full extension (rusty memory -- maybe 3" in ea leg), assemble, then charge from N2 bottle (best) or cessnoid type strut pump borrowed from spam-can mechanic. Â*It takes several hundred psi. Â*On the third rebuild, go find a broom that needs a shorter handle. -Evan Ludeman / T8 guys, it IS an HP-18 strut...................is this typical of all HP-18 struts? dealing with a low tire is one thing, dealing with a defective strut is another, especially on good soaring days! Brad Take a look at how the thing is built. Â* Ask yourself what prevents metal/metal contact in the cylinder bore. Â*In my case I think the piston (the very end, just past the o-ring groove) is what chewed up the cylinder bores. Â*I remember trying to use a brake cylinder hone to clean things up. Â*It might have helped a little. Â*My ship may have had some gear alignment issues that pushed it over the edge. Â*Obviously, it worked fairly well for others. Â*I've seen other HPs with flat struts over the years. Â*If I were doing it over again, I really would weld the sucker (make certain you get the alignment exactly right). Who needs a shock strut when you land at 30 mph? I'm leaning more and more for a rigid strut..............instead of welding, I like the idea of a broom handle/wooden dowel, that's technology I can appreciate! Brad Brad, Give me a call. My cell # is in my Facebook profile. -- Android Usenet Reader http://android.newsgroupstats.hk |
![]() I'm leaning more and more for a rigid strut..............instead of welding, I like the idea of a broom handle/wooden dowel, that's technology I can appreciate! Brad I would avoid this if possible. Or at least try it the oil 1st. True for 99 landing out of 100 it will be fine. But that one time you drop in in from about 4 feet or have land in a rough feild. You will appreciate the suspension. They obviously can work well. I haven't had my HP16T struts apart for at least 5 years. I charged them to about 400psi then which is just enough to begin to compress them when fully loaded. I did hone them with a brake hone and install X style O-rings then. They are still holding very close to the original charge I put into them 5 years ago. Brian |
On Sep 22, 12:33*pm, Brad wrote:
I'm leaning more and more for a rigid strut... I strongly recommend against. The rigid gear will apply much stronger impulses into the structure that supports the undercarriage pivots. The landing gear support structure is not sized for that. As others noted, it will work fine until that landing when it doesn't, and then it will be messy. The Schreder oleo strut gear is about the best bang for the buck and for the pound there is in energy storage (springiness) and shock absorption. When properly assembled and maintained, it is trouble-free for decades at a time. The parts are either off-the-shelf items, or things that any decent A&P or TIG welder can fotch up in an afternoon. As others note, there are good and bad examples in the field. On the leaky ones I've seen, it's been because things are bent or misaligned so that the pistons are pre-loaded against the sides of the cylinders, causing scoring and galling. It's easy to know when its set up right; when the system is assembled sans O-rings the pistons slide in and out of the cylinders with no appreciable drag. Also, you must check the condition of the restraint cable at each annual inspection for fraying or broken strands. Thanks, Bob K. |
On Sep 22, 3:29*pm, Bob Kuykendall wrote:
On Sep 22, 12:33*pm, Brad wrote: I'm leaning more and more for a rigid strut... I strongly recommend against. The rigid gear will apply much stronger impulses into the structure that supports the undercarriage pivots. The landing gear support structure is not sized for that. As others noted, it will work fine until that landing when it doesn't, and then it will be messy. The Schreder oleo strut gear is about the best bang for the buck and for the pound there is in energy storage (springiness) and shock absorption. When properly assembled and maintained, it is trouble-free for decades at a time. The parts are either off-the-shelf items, or things that any decent A&P or TIG welder can fotch up in an afternoon. As others note, there are good and bad examples in the field. On the leaky ones I've seen, it's been because things are bent or misaligned so that the pistons are pre-loaded against the sides of the cylinders, causing scoring and galling. It's easy to know when its set up right; when the system is assembled sans O-rings the pistons slide in and out of the cylinders with no appreciable drag. Also, you must check the condition of the restraint cable at each annual inspection for fraying or broken strands. Thanks, Bob K. Thanks all for the tip, Wayne, I'll give you a call later this afternoon. I just installed the landing gear and retract system in the HP-24, I did hit the valve with 120 PSI of O2 and it is holding just fine, no fluid in yet. I am tending to think Bob is right and I'll go ahead and just go with the shock strut as intended, the gear was holding pressure after I salvaged it from an HP-18 a few years ago, and that was after the -18 sat in the trailer for a few decades............I made the mistake of un-screwing the valve w/o bleeding it first...............luckily my face wasn't over the valve, and the ceiling in my shop still has a reminder of what fluid under pressure does when it is allowed to escape! Brad PS..................the HP-24 is all painted now...................anyone seeing it will be required to not look too closely at the fuselage, that was a real bugger to sand flat. |
On Sep 22, 5:29*pm, Brad wrote:
On Sep 22, 3:29*pm, Bob Kuykendall wrote: On Sep 22, 12:33*pm, Brad wrote: I'm leaning more and more for a rigid strut... I strongly recommend against. The rigid gear will apply much stronger impulses into the structure that supports the undercarriage pivots. The landing gear support structure is not sized for that. As others noted, it will work fine until that landing when it doesn't, and then it will be messy. The Schreder oleo strut gear is about the best bang for the buck and for the pound there is in energy storage (springiness) and shock absorption. When properly assembled and maintained, it is trouble-free for decades at a time. The parts are either off-the-shelf items, or things that any decent A&P or TIG welder can fotch up in an afternoon. As others note, there are good and bad examples in the field. On the leaky ones I've seen, it's been because things are bent or misaligned so that the pistons are pre-loaded against the sides of the cylinders, causing scoring and galling. It's easy to know when its set up right; when the system is assembled sans O-rings the pistons slide in and out of the cylinders with no appreciable drag. Also, you must check the condition of the restraint cable at each annual inspection for fraying or broken strands. Thanks, Bob K. Thanks all for the tip, Wayne, I'll give you a call later this afternoon. I just installed the landing gear and retract system in the HP-24, I did hit the valve with 120 PSI of O2 and it is holding just fine, no fluid in yet. I am tending to think Bob is right and I'll go ahead and just go with the shock strut as intended, the gear was holding pressure after I salvaged it from an HP-18 a few years ago, and that was after the -18 sat in the trailer for a few decades............I made the mistake of un-screwing the valve w/o bleeding it first...............luckily my face wasn't over the valve, and the ceiling in my shop still has a reminder of what fluid under pressure does when it is allowed to escape! Brad PS..................the HP-24 is all painted now...................anyone seeing it will be required to not look too closely at the fuselage, that was a real bugger to sand flat. I really don't know the HP gear but I thought I'd throw in the idea that motorcycle "monostrut" rear suspension cartridges are available in a wide range of sizes and weight carrying capacity. They are a complete package of spring and air/oil damper. One of them might work well for a glider wheel. |
On Sep 22, 8:29*pm, Bill D wrote:
I really don't know the HP gear but I thought I'd throw in the idea that motorcycle "monostrut" rear suspension cartridges are available in a wide range of sizes and weight carrying capacity. *They are a complete package of spring and air/oil damper. *One of them might work well for a glider wheel. Jack Laister used motorcycle coilover dampers in a couple of his designs, notably including the LP-15 Nugget. I thought about doing something similar, but it required more vertical space or more swept volume than I was willing to sacrifice. The HP-18 gear is an off-the- shelf solution that has worked well for me in the past, and for which I have the parts and tooling. Thanks, Bob K. |
On Sep 22, 6:29*pm, Bob Kuykendall wrote:
It's easy to know when its set up right; when the system is assembled sans O-rings the pistons slide in and out of the cylinders with no appreciable drag. My ship would have failed that test. By the time I'd noticed this (I was the third owner), the damage to the oleo cylinder was done and I didn't really have a clue as to how about putting it right. It's awfully hard to make holes that are in the wrong place go away so you can start over. -Evan Ludeman / T8 |
![]() Brad Take a look at how the thing is built. Ask yourself what prevents metal/metal contact in the cylinder bore. In my case I think the piston (the very end, just past the o-ring groove) is what chewed up the cylinder bores. I remember trying to use a brake cylinder hone to clean things up. It might have helped a little. My ship may have had some gear alignment issues that pushed it over the edge. Obviously, it worked fairly well for others. I've seen other HPs with flat struts over the years. If I were doing it over again, I really would weld the sucker (make certain you get the alignment exactly right). Who needs a shock strut when you land at 30 mph? Brad, You keep the dirt out with a set of BMX bike fork bellows. The oil is Honda SS-7 5W. Wayne -- Android Usenet Reader http://android.newsgroupstats.hk |
Gear up series - what happened?? | Terry M[_3_] | Aviation Photos | 1 | April 19th 07 03:35 AM |
A Jet Blue Aircraft Landing with Sideway Landing-Gear | Lufthansi | Piloting | 18 | July 19th 06 05:13 AM |
A Jet Blue Aircraft Landing with Sideway Landing-Gear | Hansi | Instrument Flight Rules | 1 | July 17th 06 04:01 AM |
Info needed for SH3 | Gralmk | Naval Aviation | 7 | March 24th 04 07:18 AM |
Wanted- 20 series Learjet main landing gear | DANIEL R. KARSHIN | Aviation Marketplace | 0 | July 28th 03 04:55 PM |
