For three years, it might be worth taking your glider with you! This
may not apply to Antarctica, Iraq, or a few other places. Since you used the term fibreglass, perhaps it's not registered Experimental, so easy to register elsewhere. If you must leave your glider behind, coat the lift pins, spar pins, L'Hotelliers, etc with a rust inhibitor like LPS-3 or Boeshield. I've had decent luck using a modified "mole chaser" to keep out rodents. Remove the device from it's original housing, mount it in a project box with a voltage regulator on the incoming power. Use a 12V glider battery and a solar panel to keep the thing running. Leave it somewhere in the trailer that will resonate nicely. Waxing is good. Don't forget the trailer. Or you could lease it to the fellow a few threads ago... Jim |
F-15s Preparing | Canuck[_3_] | Aviation Photos | 0 | December 17th 08 02:41 AM |
hx 4700 storage | John Galloway[_1_] | Soaring | 3 | May 16th 07 07:11 PM |
preparing for commercial oral and practical | gatt | Piloting | 42 | May 16th 07 12:56 PM |
Preparing for a XC : Bathroom Breaks | TF | Piloting | 98 | February 7th 07 07:19 AM |
103 Storage | BTIZ | Soaring | 3 | November 18th 03 12:47 AM |
