On Wed, 25 Feb 2004 19:56:47 GMT, "Doug \"Woody\" and Erin Beal"
wrote: On 2/25/04 7:23 AM, in article , "Keith Willshaw" wrote: I've got time in lots of jets with autothrottles, so spare me the preaching to the choir. I bring up the autothrottle issue on the Airbus because of their famous mishap with a jet that turned out to be the "world's most expensive chainsaw" a few years back. That same throttle automation was responsible for a Russian Airbus doing a wingover about 10 years ago too. IIRC the first incident you mentioned occured during an airshow where the autothrottle had been disengaged so the pilot could get closer to teh edge of the envelope (too close as it turned out). To me, the no-greater-than-60-degrees-AOB feature on the A320 is disturbing. The pre-supposition by the folks at Airbus seems to be that the pilot needs to be kept in a box because he's incapable of staying there on his own. Err, I'm not sure of your point here. If the pilots are good enough to avoid 60 degree AOB (Angle of Bank I assume), then what does it matter if the computer would stop them going faster? And if they aren't that competent, then the computer should damn well stop them playing silly buggers. This is the same issue IMO as the G limits built into the FBW software on most modern aircraft. Some pilots I've spoken to (specifically F-16 drivers) object to a computer telling them they can't pull that much g *if they have to* in a life or death situation. Other point out that if they did exceed the limits they'd likely pull of the wings, blow a few blood vessels, or flame out - possibly all 3, and if the computer stops them doing that, that's fine by them. AS for the current approaches by Boeing and Airbus, I was under teh impression that with the latest Boeing products (777 and 737NG) they are virtually indistinguishable to Airbus in their treatmetn of pilots as system managers, simply becasue the computers do a better job of keeping on time and min fuel consumption, and money's what the game's about. Peter Kemp --- Peter Kemp Life is short - drink faster |
![]() "Peter Kemp" wrote in message ... On Wed, 25 Feb 2004 19:56:47 GMT, "Doug \"Woody\" and Erin Beal" wrote: On 2/25/04 7:23 AM, in article , "Keith Willshaw" wrote: I've got time in lots of jets with autothrottles, so spare me the preaching to the choir. I bring up the autothrottle issue on the Airbus because of their famous mishap with a jet that turned out to be the "world's most expensive chainsaw" a few years back. That same throttle automation was responsible for a Russian Airbus doing a wingover about 10 years ago too. IIRC the first incident you mentioned occured during an airshow where the autothrottle had been disengaged so the pilot could get closer to teh edge of the envelope (too close as it turned out). The envelope for that A-320 was to land, or go around. What the pilot did was way out of the envelope. |
"Tarver Engineering" wrote...
The envelope for that A-320 was to land, or go around. What the pilot did was way out of the envelope. Let's see... You say the "envelope... was to land, or go around" According to the ASN Accident Description, "Go-around power was added at 14.45:35" The pilot elected one of the 2 options you stated were part of the "envelope" Then you say the go-around "was way out of the envelope." That makes no sense! |
![]() "John R Weiss" wrote in message news:S08%b.58709$4o.76896@attbi_s52... "Tarver Engineering" wrote... The envelope for that A-320 was to land, or go around. What the pilot did was way out of the envelope. Let's see... You say the "envelope... was to land, or go around" As defined by the POH; it is why the pilot went to jail. According to the ASN Accident Description, "Go-around power was added at 14.45:35" The pilot was past the end of the runway by then and into an unmapped part of the A-320's flight control system. |
According to the ASN Accident Description, "Go-around power was added at 14.45:35" The pilot was past the end of the runway by then and into an unmapped part of the A-320's flight control system. What is "an unmapped part of the A-320's flight control system" supposed to mean?!? Just prior to the pilot adding go-around power, the airplane was in an aerodynamic regime that had been encountered many times previously -- airspeed between stall and Vref, with a slight rate of descent (approx 375 fpm, from last datapoint), engines at idle. How could it be that the flight control system was "unmapped" in that aerodynamic regime?!? I am quite certain that the A-320's certification included slow flight and approaches to stalls, and that its flight control system is well able to handle them. I suppose this is an addendum to your claims in another thread that If your F-105 is capable of doing something inside its flight envelope, it is normal operation. and An example of an abnormal operation is the cobra manouver, as the flight controls are altered from normal operation. and Nope, the operator's handbook describes the flight envelope. I don't think you have a clue as to what a flight envelope really is! |
John R Weiss wrote:
"Tarver Engineering" wrote... snip An example of an abnormal operation is the cobra manouver, as the flight controls are altered from normal operation. and Nope, the operator's handbook describes the flight envelope. I don't think you have a clue as to what a flight envelope really is! John, you're statement above implies that 'he who must not be named' has a clue about something. Do you wish to rephrase? ;-) Guy |
![]() "Guy Alcala" wrote in message . .. John R Weiss wrote: "Tarver Engineering" wrote... snip An example of an abnormal operation is the cobra manouver, as the flight controls are altered from normal operation. and Nope, the operator's handbook describes the flight envelope. I don't think you have a clue as to what a flight envelope really is! John, you're statement above implies that 'he who must not be named' has a clue about something. Do you wish to rephrase? ;-) That would be a fact. |
"Guy Alcala" wrote...
John, you're statement above implies that 'he who must not be named' has a clue about something. Do you wish to rephrase? ;-) I'm giving him the benefit of the doubt -- he might have a clue about digital metric altimeters or something similar... |
"Tarver Engineering" wrote... According to the ASN Accident Description, "Go-around power was added at 14.45:35" The pilot was past the end of the runway by then and into an unmapped part of the A-320's flight control system. What is "an unmapped part of the A-320's flight control system" supposed to mean?!? Just prior to the pilot adding go-around power, the airplane was in an aerodynamic regime that had been encountered many times previously -- airspeed between stall and Vref, with a slight rate of descent (approx 375 fpm, from last datapoint), engines at idle. How could it be that the flight control system was "unmapped" in that aerodynamic regime?!? I am quite certain that the A-320's certification included slow flight and approaches to stalls, and that its flight control system is well able to handle them. I suppose this is an addendum to your claims in another thread that If your F-105 is capable of doing something inside its flight envelope, it is normal operation. and An example of an abnormal operation is the cobra manouver, as the flight controls are altered from normal operation. and Nope, the operator's handbook describes the flight envelope. I don't think you have a clue as to what a flight envelope really is! Sure he does, he thinks it's the little envelope they give you with your boarding pass. Dan, U. S. Air Force, retired |
"B2431" wrote...
I don't think you have a clue as to what a flight envelope really is! Sure he does, he thinks it's the little envelope they give you with your boarding pass. Actually, in context, it's more accurately the envelope with all the flight documentation that the FO turns into Ops after each leg. |
"C-175 SoCal Beware" Original Poster Replies | Bill Berle | Aviation Marketplace | 8 | July 8th 04 07:01 AM |
More LED's | Veeduber | Home Built | 19 | June 9th 04 10:07 PM |
Replace fabric with glass | Ernest Christley | Home Built | 38 | April 17th 04 11:37 AM |
RAN to get new LSD class vessel to replace 5 logistic vessels ... | Aerophotos | Military Aviation | 10 | November 3rd 03 11:49 PM |
Air Force to replace enlisted historians with civilians | Otis Willie | Military Aviation | 1 | October 22nd 03 09:41 AM |
