![]() "John R Weiss" wrote in message news:j1f%b.60182$4o.83386@attbi_s52... "Tarver Engineering" wrote... According to the ASN Accident Description, "Go-around power was added at 14.45:35" The pilot was past the end of the runway by then and into an unmapped part of the A-320's flight control system. What is "an unmapped part of the A-320's flight control system" supposed to mean?!? Airbus hadn't programmed their A-320 to do what the operator commanded. Just prior to the pilot adding go-around power, the airplane was in an aerodynamic regime that had been encountered many times previously -- airspeed between stall and Vref, with a slight rate of descent (approx 375 fpm, from last datapoint), engines at idle. How could it be that the flight control system was "unmapped" in that aerodynamic regime?!? That is a good question. I am quite certain that the A-320's certification included slow flight and approaches to stalls, and that its flight control system is well able to handle them. Then you have departed from reality. |
What is "an unmapped part of the A-320's flight control system" supposed to mean?!? Airbus hadn't programmed their A-320 to do what the operator commanded. Hmmm... I suspect that when the pilot added go-around power, he commanded the airplane to provide maximum lift/minimum sink while the engines spooled up. As far as we can tell, the flight control system responded properly, providing max lift without stalling. It is not the job of the flight control system to map trees, but the trees in the flight path interrupted the plan... I am quite certain that the A-320's certification included slow flight and approaches to stalls, and that its flight control system is well able to handle them. Then you have departed from reality. I see... Now you imply that either the A-320 certification did NOT include slow flight and approaches to stalls, or that it was certified despite its failure to demonstrate the required controllability in those regimes. Anyone have the coordinates of reality? I need to punch them into the FMS-CDU tomorrow... |
"Tarver Engineering" wrote:
"John R Weiss" wrote in message news:j1f%b.60182$4o.83386@attbi_s52... "Tarver Engineering" wrote... According to the ASN Accident Description, "Go-around power was added at 14.45:35" The pilot was past the end of the runway by then and into an unmapped part of the A-320's flight control system. What is "an unmapped part of the A-320's flight control system" supposed to mean?!? Airbus hadn't programmed their A-320 to do what the operator commanded. Just prior to the pilot adding go-around power, the airplane was in an aerodynamic regime that had been encountered many times previously -- airspeed between stall and Vref, with a slight rate of descent (approx 375 fpm, from last datapoint), engines at idle. How could it be that the flight control system was "unmapped" in that aerodynamic regime?!? That is a good question. I am quite certain that the A-320's certification included slow flight and approaches to stalls, and that its flight control system is well able to handle them. Then you have departed from reality. Jesus Christ John, this is ridiculous...I've read a lot about this accident and agree with the consensus that the a/c did all any a/c could have done given the parameters this not too bright bulb asked it to do. How in hell could the system have done more than, as JW explained, hold the AoA at the max lift point just short of stall while the autothrottle system applied max power and everyone was waiting with bated breath for the engines to spool up. Would you have preferred that the pilot have been able to manhandle the AoA higher almost certainly stalling the wings?. Maybe if you were a magician like Marron you could have changed the Angle of Incidence therefore giving the wings 'more lift'?... snort -- -Gord. |
"Tarver Engineering" wrote in message ...
The pilot was past the end of the runway by then and into an unmapped part of the A-320's flight control system. bwahahahhahahahhahhahahhhahahhahhahahahahahhahahah ahahahahahahha every ****ing aircraft goes past the end of a runway. its called takeoff |
running with scissors wrote:
every ****ing aircraft goes past the end of a runway. its called takeoff Heh. The high-performance types often don't cross the far-end threshold during takeoff. I remember one time 10,000 feet over Sherman field, looking straight down at the midpoint... -- John Miller Email address: domain, n4vu.com; username, jsm I have ways of making money that you know nothing of. -John D. Rockefeller |
John Miller wrote in message ...
running with scissors wrote: every ****ing aircraft goes past the end of a runway. its called takeoff Heh. The high-performance types often don't cross the far-end threshold during takeoff. I remember one time 10,000 feet over Sherman field, looking straight down at the midpoint... ahh but in tarverworld past the end the runway is an unmapped part of the A-320's flight control system. |
"John R Weiss" wrote in message news:S08%b.58709$4o.76896@attbi_s52...
"Tarver Engineering" wrote... Since my servers seldom get me all the newsgroup messages and Google.groups can't seem to find the begining of this thread, please allow me to ask a question and pose some answers. And I apologize if any of this has been discussed previously. From the bits I have read subsequent to John's message above, I assume we are discussing the A-320 crash at Habshiem. If so, let me present some information relevant to the discussion, as I have not read anything as yet that indicates any of the posters knows much if anything about Airbus flight control systems. I do believe I am qualified to speak on the subject as I teach A-330 systems, which has a flight control system identical to the A-320. The A-320 which crashed into the trees in France was performing a fly-by demonstration, by a line pilot, not an Airbus test or demo pilot. The profile was to fly by at 500 feet. The aircraft was below 100 feet. This is significant to the incident (and not just because that is where we find trees). In the Airbus the computers have a group of flight control protections collectively known as "Laws". In Normal Law there is a low-speed, high AOA protection known as Alpha-Floor. Alpha-Floor is reached somewhere below Vls (the lowest speed the aircraft will fly with autopilot/autothrust on and sidestick in neutral), and prior to Alpha-Max (maximum AOA). At Alpha-Floor the autothrust commands TOGA power, and regardless of how much you pull back on the sidestick, the aircraft will not decelerate below Alpha-Max. It will just mush along at TOGA power until it runs out of gas or the pilot lowers the nose to accelerate. The problem is, Alpha-Floor is not available between 100' and touchdown - otherwise you could never land! The pilot was expecting Alpha-Floor, but being too low, it did not happen. By the time he realized his error, he applied power, but it was too late. You can, in fact, hear the engines spooling up just prior to his impact with the trees in the video we show in class. The aircraft performed as it should have. The pilot simply did not have an adequate understanding of his aircraft for the manuver he was doing. He also failed to follow the script. Two things the French apparently frown upon, expecially when used in combination. Lesson: if you don't fully understand your aircraft, it can reach out and bite you someday. John Alger A-330 Flight Crew Training Instructor Former rides: TA-4J, A-7E, EC-130Q and P-3B |
![]() "John Alger" wrote in message m... "John R Weiss" wrote in message news:S08%b.58709$4o.76896@attbi_s52... "Tarver Engineering" wrote... Since my servers seldom get me all the newsgroup messages and Google.groups can't seem to find the begining of this thread, please allow me to ask a question and pose some answers. And I apologize if any of this has been discussed previously. From the bits I have read subsequent to John's message above, I assume we are discussing the A-320 crash at Habshiem. If so, let me present some information relevant to the discussion, as I have not read anything as yet that indicates any of the posters knows much if anything about Airbus flight control systems. I do believe I am qualified to speak on the subject as I teach A-330 systems, which has a flight control system identical to the A-320. The A-320 which crashed into the trees in France was performing a fly-by demonstration, by a line pilot, not an Airbus test or demo pilot. The profile was to fly by at 500 feet. The pilot was making a scheduled revenue flight with passengers and came up with the low slow fly by all on his own. The aircraft was below 100 feet. This is significant to the incident (and not just because that is where we find trees). In the Airbus the computers have a group of flight control protections collectively known as "Laws". In Normal Law there is a low-speed, high AOA protection known as Alpha-Floor. Alpha-Floor is reached somewhere below Vls (the lowest speed the aircraft will fly with autopilot/autothrust on and sidestick in neutral), and prior to Alpha-Max (maximum AOA). At Alpha-Floor the autothrust commands TOGA power, and regardless of how much you pull back on the sidestick, the aircraft will not decelerate below Alpha-Max. It will just mush along at TOGA power until it runs out of gas or the pilot lowers the nose to accelerate. The low fly by was not an A-320 flight mode. The problem is, Alpha-Floor is not available between 100' and touchdown - otherwise you could never land! The pilot was expecting Alpha-Floor, but being too low, it did not happen. By the time he realized his error, he applied power, but it was too late. You can, in fact, hear the engines spooling up just prior to his impact with the trees in the video we show in class. That is what I have been attempting to communicate to Weiss. The aircraft performed as it should have. The pilot simply did not have an adequate understanding of his aircraft for the manuver he was doing. He also failed to follow the script. Two things the French apparently frown upon, expecially when used in combination. Yes. It is not just the French that believe the POH is part of the Type Certificate for an airplane. Lesson: if you don't fully understand your aircraft, it can reach out and bite you someday. Weiss is in danger every time he flys then. |
"John Alger" wrote in message m... "John R Weiss" wrote in message news:S08%b.58709$4o.76896@attbi_s52... "Tarver Engineering" wrote... Since my servers seldom get me all the newsgroup messages and Google.groups can't seem to find the begining of this thread, please allow me to ask a question and pose some answers. And I apologize if any of this has been discussed previously. From the bits I have read subsequent to John's message above, I assume we are discussing the A-320 crash at Habshiem. If so, let me present some information relevant to the discussion, as I have not read anything as yet that indicates any of the posters knows much if anything about Airbus flight control systems. I do believe I am qualified to speak on the subject as I teach A-330 systems, which has a flight control system identical to the A-320. The A-320 which crashed into the trees in France was performing a fly-by demonstration, by a line pilot, not an Airbus test or demo pilot. The profile was to fly by at 500 feet. The pilot was making a scheduled revenue flight with passengers and came up with the low slow fly by all on his own. nope. it was a revenue flight. though the pilot was requested to do the low fly past by AF. |
"John Alger" wrote...
The A-320 which crashed into the trees in France was performing a fly-by demonstration, by a line pilot, not an Airbus test or demo pilot. The profile was to fly by at 500 feet. The aircraft was below 100 feet. This is significant to the incident (and not just because that is where we find trees). In the Airbus the computers have a group of flight control protections collectively known as "Laws". In Normal Law there is a low-speed, high AOA protection known as Alpha-Floor. Alpha-Floor is reached somewhere below Vls (the lowest speed the aircraft will fly with autopilot/autothrust on and sidestick in neutral), and prior to Alpha-Max (maximum AOA). At Alpha-Floor the autothrust commands TOGA power, and regardless of how much you pull back on the sidestick, the aircraft will not decelerate below Alpha-Max. It will just mush along at TOGA power until it runs out of gas or the pilot lowers the nose to accelerate. The problem is, Alpha-Floor is not available between 100' and touchdown - otherwise you could never land! The pilot was expecting Alpha-Floor, but being too low, it did not happen. By the time he realized his error, he applied power, but it was too late. You can, in fact, hear the engines spooling up just prior to his impact with the trees in the video we show in class. From what you say here, it does not appear autothrottle was engaged (which also correlates with other descriptions I've read) -- apparently, the pilot manually moved the throttles from idle to Max. Is this true? Is Alpha-Max the stall AOA, or something less? Is there any "emergency override" that will engage the autothrottle when approaching Alpha-Max? |
"C-175 SoCal Beware" Original Poster Replies | Bill Berle | Aviation Marketplace | 8 | July 8th 04 07:01 AM |
More LED's | Veeduber | Home Built | 19 | June 9th 04 10:07 PM |
Replace fabric with glass | Ernest Christley | Home Built | 38 | April 17th 04 11:37 AM |
RAN to get new LSD class vessel to replace 5 logistic vessels ... | Aerophotos | Military Aviation | 10 | November 3rd 03 11:49 PM |
Air Force to replace enlisted historians with civilians | Otis Willie | Military Aviation | 1 | October 22nd 03 09:41 AM |
