Disclosure Imminent? Eight + Underground NWO Bases Destroyed?
Old October 12th 11, 12:00 AM posted to rec.aviation.military,rec.aviation.piloting
Thor Kuntelin
Default Pyramidiots Emerge
On Tue, 11 Oct 2011 11:43:56 -0400, Tom wrote:
rofl
Pyramidiots fail to see that these "primitive" stone and chisel users
were somehow master mathematicians with highly advanced geometrical
capabilities. To wit:
The mathematic value of Pi defines the ratio of the circumference to the
diameter of a circle found in the pyramid math.
pi can be found taking twice the base length of the pyramid divided by
its height:
pi = 2 * 440/280 = 880/280 = 22/7 approximating
pi = 3.14159.
Perhaps pi was never specifically calculated, but its value became
incorporated to a very high degree of accuracy for and by future
generations to discover.
Of course, after "chiseling" to perfection the blocks of granite (nary a
human hair can fit in a joint), they would wipe of their sweat, take a
dip in the Nile and resume mathematical excellence.
Of course.
One of the first archaeologists to carry out a thorough survey of the
Pyramid was Petrie, who was particularly struck by the granite coffer
in the King˘s Chamber. The precision with which the coffer had been
carved out of a /single block of extremely hard granite/ struck him as
quite remarkable.
Petrie estimated that diamond-tipped drills would need to have been
applied with a pressure of two tons, in order to hollow out the granite
box. It was not a serious suggestion as to the method actually used but
simply his way of expressing the *impossibility* of creating that
artifact using nineteenth century technology.
It is still a difficult challenge, even with twentieth century
technology. And yet we are supposed to believe that Khufu achieved this
at a time when the Egyptians possessed only the most basic copper hand
tools?
Or well before hand tools were even used?
Thor Kuntelin
http://www.anta.com/
Old October 12th 11, 12:15 AM posted to rec.aviation.military,rec.aviation.piloting
Tom[_15_]
rofl
its height:
pi = 3.14159.
Of course.
in the King˙s Chamber. The precision with which the coffer had been
quite remarkable.
tools?
Also in Egypt tens of thousands of diorite bowls have been found with
hieroglyphs engraved. Diorite is one of the hardest stones on the
planet, harder than iron, yet intricate inscriptions have been made,
not through the use of chisels or scraping but some unknown ancient
technology.
Whatever it was, was capable of etching lines 1/150th of an inch wide,
often in sets of parallel lines separated by a mere 1/30th of an inch.
The same kind of workmanship has been found in vases, urns, and other
pottery unearthed at the Pyramid of Zoser.
Graham Hancock says: ´There was no technology known to have been
available to the Ancient Egyptians capable of achieving such results.
Nor, for that matter, would any stone-carver today be able to match
them, even if he were working with the best tungsten-carbide tools. The
implication, therefore, is that an unknown or secret technology had
been put to use in Ancient Egypt.ˇ
Old October 12th 11, 12:58 AM posted to rec.aviation.military,rec.aviation.piloting
Jim Wilkins[_2_]
"Tom" wrote in message
...The
The Romans built with granite on the same massive scale that we do. Who
helped them?
Old October 12th 11, 01:23 AM posted to rec.aviation.military,rec.aviation.piloting
Dan[_15_]
On 10/11/2011 6:58 PM, Jim Wilkins wrote:
...The
helped them?
The ancient Egyptians sold the space aliens to the Romans.
Dan, U.S. Air Force, retired
Old October 12th 11, 04:36 AM posted to rec.aviation.military,rec.aviation.piloting
Thor Kuntelin
technology.
My concern is over the Black Pyramid and the 12+ underground ones.
Thor Kuntelin
Old October 12th 11, 04:53 AM posted to rec.aviation.military,rec.aviation.piloting
Tom[_15_]
technology.
Twelve up to 17 or more. I question whether we will ever get to see them
before they are finished being looted by ???????? including the
Atlantean Hall of Records.
None of this became an issue until The Geomatrix plan was been cracked
by Bill Brown. Evidence from its code is validated by past
archaeological activity on the Plateau. It will be furhter validated
*if* and when it is discloses where and why unannounced excavations are
taking place now.
Will You Sign The White House ET Disclosure Petition ? Quaalude Piloting 6 October 7th 11 03:38 PM
LISTEN UP MI5 ... FLOOD IMMINENT Michael Baldwin, Bruce Products 12 January 2nd 07 06:31 AM
Balham Underground Station - London, 15 Oct '40 Dave Kearton Aviation Photos 1 November 9th 06 02:17 AM
A Public Domain Disclosure- A Passive Counter-rotating Auxillary Propellor. [email protected] Piloting 11 March 26th 04 02:44 AM
Swedish underground hangars, photos patrick savoie Military Aviation 20 July 7th 03 12:09 PM
