Cable vs rope pulling glider from field
Old October 12th 11, 06:28 PM posted to rec.aviation.soaring
Bill D
Default Cable vs rope pulling glider from field
On Oct 12, 9:34*am, Auxvache wrote:
I'd like to make a stout wire cable or rope with proper TOST ring, to
have on hand should I have to tow my 15m glider from mud/soft dirt/
guano.
Is a metal cable necessary/preferable, or would high breaking-strength
rope be sufficient?
My only experience here (Chester loam, Pegase, and stick-shift BMW)
did not end well.
Thanks in advance,
Erik
Steel cable is nasty - use Dyneema rope instead so it can be neatly
rolled up. Use the Tost weak link called out in your glider's manual
to protect the hook and glider from overloads. If that won't get you
out, you're REALLY stuck.
If this is a regular occurrence, consider a small portable 12V
electric winch from a vendor like Warn temporarily fitted to the
receiver hitch on your BMW so the glider can be slowly and gently
pulled out of the muck without stressing the car's clutch. Replace
the steel cable with Dyneema rope.
http://www.amazon.com/Warn-68531-WAR.../dp/B000CQBMMW
http://www.warn.com/truck/winches/VR8000_winch.shtml
Pulling Avionics Boxes. brian whatcott General Aviation 0 November 8th 09 04:42 PM
Short field glider ops [email protected] Soaring 5 June 5th 09 03:21 PM
bicycle wire - glider cable [email protected] Soaring 4 April 6th 08 05:53 AM
Accepting cable/rope at start. Bill Daniels Soaring 26 September 6th 07 01:03 AM
59% increase in pulling power is claimed for an unusual new rotor propeller for airplanes Larry Dighera Piloting 5 November 21st 03 02:13 AM
