On Wed, 12 Oct 2011 19:38:24 +0000, Ben Watkins wrote:
At 17:43 12 October 2011, kirk.stant wrote: On Oct 12, 10:34=A0am, Auxvache wrote: I'd like to make a stout wire cable or rope with proper TOST ring, to have on hand should I have to tow my 15m glider from mud/soft dirt/ guano. Is a metal cable necessary/preferable, or would high breaking-strength rope be sufficient? My only experience here (Chester loam, Pegase, and stick-shift BMW) did not end well. Thanks in advance, Erik You might consider keeping a Tost ring set in your glider, as part of your landout kit. Nice to have when you want a local to help move your glider to a different location for derigging, etc. Rope of some sort is almost always available, but trying to use a rope loop in a Tost release is an exercise in futility! Kirk If you are putting strain on the tow rope make sure you lay something reasonably heavy (coat, car rug etc.) over the rope more than half from the car to the glider. That way if the rope does break the rings, weak link etc. won't end up flying through your back window! ....and use a rope with as little stretch, which means energy storage, as possible. A light weight cable is good too for the same reason. Steel cable is about the worst thing you could use because of the way it lashed round if it or a fixing breaks under load and, and is harder to wind up and store than it needs to be. OTOH plastic rope rope, particularly Dyneema or good quality climbing rope, both have minimal energy storage and are easy to handle. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Oct 12, 2:18*pm, Martin Gregorie
wrote: On Wed, 12 Oct 2011 19:38:24 +0000, Ben Watkins wrote: At 17:43 12 October 2011, kirk.stant wrote: On Oct 12, 10:34=A0am, Auxvache *wrote: I'd like to make a stout wire cable or rope with proper TOST ring, to have on hand should I have to tow my 15m glider from mud/soft dirt/ guano. Is a metal cable necessary/preferable, or would high breaking-strength rope be sufficient? My only experience here (Chester loam, Pegase, and stick-shift BMW) did not end well. Thanks in advance, Erik You might consider keeping a Tost ring set in your glider, as part of your landout kit. *Nice to have when you want a local to help move your glider to a different location for derigging, etc. *Rope of some sort is almost always available, but trying to use a rope loop in a Tost release is an exercise in futility! Kirk If you are putting strain on the tow rope make sure you lay something reasonably heavy (coat, car rug etc.) over the rope more than half from the car to the glider. That way if the rope does break the rings, weak link etc. won't end up flying through your back window! ...and use a rope with as little stretch, which means energy storage, as possible. A light weight cable is good too for the same reason. Steel cable is about the worst thing you could use because of the way it lashed round if it or a fixing breaks under load and, and is harder to wind up and store than it needs to be. OTOH plastic rope rope, particularly Dyneema or good quality climbing rope, both have minimal energy storage and are easy to handle. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Actually for the force required, 2mm Dyneema would be strong enough. The 12V winch linked above would likely hold 2000 feet or so. If you landed in a boggy field which wouldn't support a car and needed to get the glider to its trailer, this would be just the trick. Mount the winch at the front of a trailer and it could help get the glider onto its fuselage dolly, then pull the fuselage into the trailer. |
Thanks very much for your answers--sounds like Dyneema with a weak
link and Tost ring would be a good set-up. And, forewarned, I promise not to dehisce the nose of the glider with Farmer Brown's tractor. Or shatter the back window of mum's grocery-getter. And if it gets to be a regular occurrence, I'll find another hobby. Erik |
A landout every now and then isn't too bad. Luckily I've never gotten into such a muddy field that I couldn't get the glider moved out. Benefit of flying mostly in fairly dry climates I guess. There was one time where I avoided a very muddy mucky mess by landing on a clear unobstructed stretch of paved county road. I've only got 30ish landouts though and a mere 6 or 7 this season. |
On Thu, 13 Oct 2011 06:39:38 -0700, Auxvache wrote:
Thanks very much for your answers--sounds like Dyneema with a weak link and Tost ring would be a good set-up. Yes, I'd agree, but with one warning I should have mentioned: a naked Dyneema cord is not a good idea because the slightest handling abrasion tends to fluff it up into an unusable woolly caterpillar-like thing. I discovered this when trying to use a thin woven Dyneema (80 lb) line to control the VIT stop on a free flight power model - even expecting it to handle a 90 degree bend by sliding round a 3mm brass tube was too rough and caused it to fluff up and become unusable. What I've found to be excellent is a core of unwoven Dyneema inside a woven Dacron casing. I've used 100 lb kite bridle (about 0.7mm diameter) as model glider towline. This was very easy to handle and almost totally abrasion resistant. I believe you can get this type of line in up to at least 3mm diameter. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Oct 13, 7:31*pm, Martin Gregorie
wrote: On Thu, 13 Oct 2011 06:39:38 -0700, Auxvache wrote: Thanks very much for your answers--sounds like Dyneema with a weak link and Tost ring would be a good set-up. Yes, I'd agree, but with one warning I should have mentioned: a naked Dyneema cord is not a good idea because the slightest handling abrasion tends to fluff it up into an unusable woolly caterpillar-like thing. I discovered this when trying to use a thin woven Dyneema (80 lb) line to control the VIT stop on a free flight power model - even expecting it to handle a 90 degree bend by sliding round a 3mm brass tube was too rough and caused it to fluff up and become unusable. What I've found to be excellent is a core of unwoven Dyneema inside a woven Dacron casing. I've used 100 lb kite bridle (about 0.7mm diameter) as model glider towline. This was very easy to handle and almost totally abrasion resistant. I believe you can get this type of line in up to at least 3mm diameter. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Martin, you must have had some really crappy rope mislabeled as Dyneema . The 12 strand hollow braid we use has 15x the abrasion resistance of steel. The off road 4x4 guys use it on their bumper winches with it going over sharp rocks and trees. I've never seen the problems you describe. |
On Oct 13, 7:18*pm, Bill D wrote:
Martin, you must have had some really crappy rope mislabeled as Dyneema . *The 12 strand hollow braid we use has 15x the abrasion resistance of steel. *The off road 4x4 guys use it on their bumper winches with it going over sharp rocks and trees. *I've never seen the problems you describe. Yes, that sounds more like aramid (such as Kevlar (tm)) behavior. Thanks, Bob K. |
On Thu, 13 Oct 2011 19:18:12 -0700, Bill D wrote:
Martin, you must have had some really crappy rope mislabeled as Dyneema . The 12 strand hollow braid we use has 15x the abrasion resistance of steel. Well, it looked and felt like Dyneema/Spectra/whatever brand you prefer, i.e. dead slippery to handle. As I said it was naked - just a fairly loosely woven braid with a circular cross section that was sold as 80 lb fishing line - I've seen the same sort of line and thickness in Dacron but then, of course, it would have been around 18-20 lb line, say somewhere between 0.3 to 0.5mm in diameter. Since it felt so slick I was sure it would slide round the outside of something as relatively large and smooth as 3mm brass tube, but nooo - the stuff had fluffed up before I even got the model out of my workshop, so I replaced it immediately with Dacron, which worked as I'd expected the Dyneema to do. but The off road 4x4 guys use it on their bumper winches with it going over sharp rocks and trees. I've never seen the problems you describe. But is that stuff naked or has it got a woven Dacron tube as its outer layer? Obviously some of the stuff that was used as winch cable had such an outer shell or the splicing method I saw described (threading one end in and out of the casing with a big needle for 50cm or so) would never have worked. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Oct 14, 2:22Â*pm, Martin Gregorie
wrote: On Thu, 13 Oct 2011 19:18:12 -0700, Bill D wrote: Martin, you must have had some really crappy rope mislabeled as Dyneema . Â*The 12 strand hollow braid we use has 15x the abrasion resistance of steel. Well, it looked and felt like Dyneema/Spectra/whatever brand you prefer, i.e. dead slippery to handle. As I said it was naked - just a fairly loosely woven braid with a circular cross section that was sold as 80 lb fishing line - I've seen the same sort of line and thickness in Dacron but then, of course, it would have been around 18-20 lb line, say somewhere between 0.3 to 0.5mm in diameter. Since it felt so slick I was sure it would slide round the outside of something as relatively large and smooth as 3mm brass tube, but nooo Â*- the stuff had fluffed up before I even got the model out of my workshop, so I replaced it immediately with Dacron, which worked as I'd expected the Dyneema to do. but Â* The off road 4x4 guys use it on their bumper winches with it going over sharp rocks and trees. Â*I've never seen the problems you describe. But is that stuff naked or has it got a woven Dacron tube as its outer layer? Obviously some of the stuff that was used as winch cable had such an outer shell or the splicing method I saw described (threading one end in and out of the casing with a big needle for 50cm or so) would never have worked. -- martin@ Â* | Martin Gregorie gregorie. | Essex, UK org Â* Â* Â* | This is the stuff the 4x4 guys use - it has no sheath. http://www.okoffroad.com/stuff-winchrope-atv.htm Dyneema/Spectra/UHMWPE rope or whatever you call it has 15x steels abrasion resistance, 10x steel's strength per weight and a friction coefficient lower than Teflon plus a lot of other engineering superlatives. It simply can't be beat as winch rope for 4x4's or gliders. It does "fuzz up" as it wears but the fuzz actually protects the rest of the rope. Even this miracle material is being significantly improved. "Abstract: This paper reports the use of multiwalled carbon nanotubes (MWCNT) to reinforce and toughen gel-spun ultra high molecular weight polyethylene (UHMWPE) fibers. By adding 5 wt% MWCNT, ultra strong fibers with tensile strengths of 4.2 GPa and strain at break of ∼5% can be produced. In comparison with the pure UHMWPE fiber at the same draw ratios, these values represent increases of 18.8% in tensile strength and 15.4% in ductility. In addition, a 44.2% increase in energy to fracture has also been observed. The mechanism of reinforcement has been studied using a combination of high resolution scanning electron microscopy (SEM) and micro-Raman spectroscopy. Carbon nanotube alignment along the tensile draw direction has been observed at high elongation ratios. Such alignment induces strong interfacial load transfer both at small and large strains to enhance the stiffness and tensile strength of the composite fiber. Consequently, the mechanical properties of the composite fiber follow closely with the rule of mixtures. Our work also reveals potential for positive deviation from rule of mixtures if the CNT alignment can be further optimized." |
Pulling Avionics Boxes. | brian whatcott | General Aviation | 0 | November 8th 09 04:42 PM |
Short field glider ops | [email protected] | Soaring | 5 | June 5th 09 03:21 PM |
bicycle wire - glider cable | [email protected] | Soaring | 4 | April 6th 08 05:53 AM |
Accepting cable/rope at start. | Bill Daniels | Soaring | 26 | September 6th 07 01:03 AM |
59% increase in pulling power is claimed for an unusual new rotor propeller for airplanes | Larry Dighera | Piloting | 5 | November 21st 03 02:13 AM |
