Soaring Accident in Washington State
Old October 17th 11, 04:46 PM posted to rec.aviation.soaring
2G
Default Soaring Accident in Washington State
On Oct 17, 12:41*am, Harold Katinszky wrote:
On Oct 16, 9:35*am, 2G wrote:
On Oct 16, 6:33*am, Michael Dewitt Allen
Florida Guy here... Commenting on the "Great North West Caper" in
Washington State
Seems like this Boggs Guy has it "Right On" again...
If the "Plan" was to do a 180... AFTER a "Launch"
on a tooo short rope...
on a tooo short Runway...
The *Genius that had suggested a "180 degree Return to Runway"
Had to be smokin something serious.
This "Plan" seems to have been "Doomed to Failure" from inception.
While the "plan" seems to be seriously flawed, and contributed to the
accident, it may not be the direct cause. Photos and videos clearly
show the right airbrake extended and the left retracted. This points
to a failure of the airbrake controls, which would be consistent with
what most witnesses reported (he veered off to the right after doing a
pull-up). There is an AD out on the DG-1000 airbrake control circuit.
These controls hookup automatically, so an assembly error is not
likely.
One does a positive control check on this sort of stuff several times
It is my theory the spoliers popped out from the force of the accident
not prematurely as you may suggest. It is nice to blame the
manufacturer
on this sort of stuff however, I have my doubts and the sailplane
should
still be able to manuever with one open.
VI
Nobody is "blaming the manufacturer"; the existence of the AD is a
matter of fact, not fiction.
The wings and the portion of the fuselage aft of the cockpit are
intact, absent of any crushing. In any event, inspection of the
wreckage will confirm or deny the theory, and has probably already
been done.
The ability to fly with one airbrake out in level flight does not
imply the same in a high G pullup. The unexpected deployment of a
single airbrake in this attitude may be beyond the yaw authority of
the rudder. In any event, the pilot could have been confused long
enough that the glider got into an irrecoverable attitude before he
realized what was happening.
Tom
Old October 17th 11, 10:02 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Washington State
likely.
manufacturer
should
VI
been done.
Tom- Hide quoted text -
- Show quoted text -
I wouldn't read too much into one spoiler open after the crash. The
whole structure can move several inches during the crash, then spring
back to near normal position. I can envision a side load in the wing
root area that could unlock one spoiler, then during spring back, the
push-rod bends or some other control linkage brakes and you get the
photo showing one open and the other closed. I remember the near
normal looking G-103 wing, but when I opened up the wing I found the
aileron push-rod had a 30 degree bend in it.........indicating just
how far the wing had bent before springing back.
If the DG-1000 uses the same hokey torque-tube that they used in the
DG-300 to drive the spoilers with the over-center lock mounted on a
thin root-rib, that flexed easily under load...............the one
open, one closed would be near normal situation.
Cheers,
JJ
Old October 17th 11, 11:01 PM posted to rec.aviation.soaring
Harold Katinszky
Washington State
This "Plan" seems to have been "Doomed to Failure" from inception..
Old October 18th 11, 09:59 AM posted to rec.aviation.soaring
Bruce Hoult
Hmm. I've rigged and derigged DG1000 a number of times and never had
to do anything special with the airbrake lever and the brakes stay
locked with the wing off the plane so, yeah, the overcenter lock must
be inside each wing. Never thought about that.
Both airbrakes and ailerons are definitely driven (at least initially)
by torque tubes with self-aligning V-shaped slots.
Old October 17th 11, 11:02 PM posted to rec.aviation.soaring
Harold Katinszky
Washington State
likely.
manufacturer
should
VI
been done.
Old October 18th 11, 07:01 PM posted to rec.aviation.soaring
Mitch Polinsky
Default looking for new/used stick remote control unit for LX 8000/9000
Does anyone have, or know where I could find, the remote control unit for
an LX 8000 or 9000 that gets mounted on the stick? I'm interested in a new
or used one. Thanks.
Mitch Polinsky
[for private replies]
Old October 18th 11, 10:35 PM posted to rec.aviation.soaring
Andy[_1_]
an LX 8000 or 9000 that gets mounted on the stick? *I'm interested in a new
or used one. *Thanks.
Mitch Polinsky
*[for private replies]
Tornado in Washington state gatt[_2_] Piloting 8 January 12th 08 05:23 PM
421C down in Washington State Bob Gardner Piloting 53 January 31st 06 02:12 PM
For Sale : PIK-20B (Washington State) [email protected] Soaring 0 September 21st 05 03:54 AM
Flying from Washington state to Canada Ross Oliver Piloting 33 June 24th 04 07:03 PM
Iowa to Washington State? Jay Honeck Piloting 40 April 29th 04 09:03 PM
