On Oct 27, 9:28*pm, Steve Leonard wrote:
What else about their “intentions” were you hoping the NTSB would state in a preliminary accident report? *Were you expecting them to detail the entire planned flight path, launch sequence, acceleration rate, tow car speed for the climb, film crew briefings? *Not gonna happen with with the NTSB. *They provided some eye-witness information which may or may not be misleading, and some facts about the airport, the registered owner of the plane, etc. *We have been told what their intentions were. * We have been told they were filming a commercial for Cadillac. *We have been told they used the vehicle for the ground launch. *We have been told they planned to tow the DG up with their rope (which the NTSB reports as 234 feet long, made from 5/16th nylon. *Although, I suspect it is polypropylene.), do a 180, and land back the other direction. *As for the rest of the sequence, I was not there, but am presenting what I believe is a plausible explanation of how the events may have transpired. We can assume that the rope was intact after the launch, as the NTSB report reports the length of the rope, and makes no comments about it being broken, or rings found in the glider, etc. *They would have stated the rope was broken it if had been. *So, this does not appear to be any sort of rope overload, as some were presuming. The witnesses stated that the takeoff appeared normal. *There is enough confusing information after this if you start putting the math to it about distance down the runway, altitude, etc to make one suspicious of the distance and height observations. *The witnesses reported that the plane "pitched to a steep nose high attitude." *We know that at some point in the climb (estimated to be 100 to 125 feet), the rope “slackend”. *Three ways the rope can "slacken". *Tow vehicle slows down, glider pushes over, or rope disconnects. *They say the glider continued to ascend to about 200 feet of altitude and leveled off. *Based on what they say happened next, I believe the rope disconnected and the pilot pushed over. In an auto tow launch, you lift off, bring the nose up *a little, get some altitude, then bring the nose on up. *As you near the top of the climb, the nose comes back down to pretty close to level. *Watch any video of a winch launch on YouTube. *Very similar, but on car tow, you don't accelerate as rapidly. *Depending on how the launch is conducted, you will be rotating to full climb between 100 and 200 feet. *Unfortunately, if you try for the same profile with a 234 foot rope as you would with a 2000 foot rope (be rotating to full climb angle at 100 feet AGL), the rope to hitch angle will likely hit the "back release" angle at somewhere between 100 and 150 feet AGL. *So, if you try to fly a "normal" launch profile on a short rope, you will likely get a low altitude back release, as the pilot in this accident probably got. So, here you are, about 100 to 150 or so feet AGL, 35-40 degrees or so nose up, about right on speed for the climb, and the release does its backrelease thing. *You are surprised, but put the stick on the forward stop as you are trained. *The plane keeps going up and keeps slowing down as you are going over the top. *By the time you go over the top at about 200 feet or so, and have the nose back down to normal gliding attitude, your airspeed is pretty well gone. *Do the math to see how much altitude you will gain in slowing from 60 to 30 knots or so, no drag losses. *Unless you keep the stick forward to get the nose well below the normal gliding attitude to get flying speed back (and give up what precious little altitude you have), you will stall. Pilot probably came across the top at about two hundred or so feet after this, less than one g and slower than 1 g stall speed. *He then likely attempted to initiate the turn, as things were "back to normal, per the plan." *Meaning, he was near the far end of the runway, at about 200 feet, ready to turn around. *Trouble is, he was below stall speed. *Attempted to turn and entered a spin. As to the max speed the towcar attained, I would be very surprised if they were attempting other than a "normal" ground launch sequnce, but with a very short rope. *"Normal" being accelerate the car to flying speed for the plane plus safety margin (no wind, say 65 MPH or so for the DG? *Remember, his airspeed would go up as soon as he starts to climb, and the intention was to climb), hold that speed, drive to near the end, and stop. A very sad and tragic accident. Respectfully, Steve Leonard What else about their “intentions” were you hoping the NTSB would state in a preliminary accident report? This is precisely the problem with NTSB reports, they don't provide enough facts to make any conclusion. The final report usually come a year later and often does not have much more information than the preliminary reports. So so much for the requests to "wait for the NTSB report". We waited, and now we need the facts so we can draw our own conclusions and learn the lessons. And I am pretty sure that some of the readers know more. As for the plan to do a 180 to land, there is no mention of it in the NTSB report, only from Gary's comment. I think this is the key to be able to categorize this accident as "something went terribly wrong" vs "someone made a terrible decision" or did not know what they were doing. There is no much we can do to prevent the "something went terribly wrong" type of accidnets, but there is much we can do to prevent the later and learn the lessons. Perhaps someone reading this will, as a result, think twice before attempting an auto tow with a short rope on a short runway with limited straight ahead options. Incidentally, I recently visited such an airport were they attempted an autolaunch on a short runway, slightly uphill with no straight ahead option, and quickly learned they will be better off finding a tow plane. Ramy |
On Oct 28, 10:23*am, Ramy wrote:
On Oct 27, 9:28*pm, Steve Leonard wrote: What else about their “intentions” were you hoping the NTSB would state in a preliminary accident report? *Were you expecting them to detail the entire planned flight path, launch sequence, acceleration rate, tow car speed for the climb, film crew briefings? *Not gonna happen with with the NTSB. *They provided some eye-witness information which may or may not be misleading, and some facts about the airport, the registered owner of the plane, etc. *We have been told what their intentions were. * We have been told they were filming a commercial for Cadillac. *We have been told they used the vehicle for the ground launch. *We have been told they planned to tow the DG up with their rope (which the NTSB reports as 234 feet long, made from 5/16th nylon. *Although, I suspect it is polypropylene.), do a 180, and land back the other direction. *As for the rest of the sequence, I was not there, but am presenting what I believe is a plausible explanation of how the events may have transpired. We can assume that the rope was intact after the launch, as the NTSB report reports the length of the rope, and makes no comments about it being broken, or rings found in the glider, etc. *They would have stated the rope was broken it if had been. *So, this does not appear to be any sort of rope overload, as some were presuming. The witnesses stated that the takeoff appeared normal. *There is enough confusing information after this if you start putting the math to it about distance down the runway, altitude, etc to make one suspicious of the distance and height observations. *The witnesses reported that the plane "pitched to a steep nose high attitude." *We know that at some point in the climb (estimated to be 100 to 125 feet), the rope “slackend”. *Three ways the rope can "slacken". *Tow vehicle slows down, glider pushes over, or rope disconnects. *They say the glider continued to ascend to about 200 feet of altitude and leveled off. *Based on what they say happened next, I believe the rope disconnected and the pilot pushed over. In an auto tow launch, you lift off, bring the nose up *a little, get some altitude, then bring the nose on up. *As you near the top of the climb, the nose comes back down to pretty close to level. *Watch any video of a winch launch on YouTube. *Very similar, but on car tow, you don't accelerate as rapidly. *Depending on how the launch is conducted, you will be rotating to full climb between 100 and 200 feet. *Unfortunately, if you try for the same profile with a 234 foot rope as you would with a 2000 foot rope (be rotating to full climb angle at 100 feet AGL), the rope to hitch angle will likely hit the "back release" angle at somewhere between 100 and 150 feet AGL. *So, if you try to fly a "normal" launch profile on a short rope, you will likely get a low altitude back release, as the pilot in this accident probably got. So, here you are, about 100 to 150 or so feet AGL, 35-40 degrees or so nose up, about right on speed for the climb, and the release does its backrelease thing. *You are surprised, but put the stick on the forward stop as you are trained. *The plane keeps going up and keeps slowing down as you are going over the top. *By the time you go over the top at about 200 feet or so, and have the nose back down to normal gliding attitude, your airspeed is pretty well gone. *Do the math to see how much altitude you will gain in slowing from 60 to 30 knots or so, no drag losses. *Unless you keep the stick forward to get the nose well below the normal gliding attitude to get flying speed back (and give up what precious little altitude you have), you will stall. Pilot probably came across the top at about two hundred or so feet after this, less than one g and slower than 1 g stall speed. *He then likely attempted to initiate the turn, as things were "back to normal, per the plan." *Meaning, he was near the far end of the runway, at about 200 feet, ready to turn around. *Trouble is, he was below stall speed. *Attempted to turn and entered a spin. As to the max speed the towcar attained, I would be very surprised if they were attempting other than a "normal" ground launch sequnce, but with a very short rope. *"Normal" being accelerate the car to flying speed for the plane plus safety margin (no wind, say 65 MPH or so for the DG? *Remember, his airspeed would go up as soon as he starts to climb, and the intention was to climb), hold that speed, drive to near the end, and stop. A very sad and tragic accident. Respectfully, Steve Leonard What else about their “intentions” were you hoping the NTSB would state in a preliminary accident report? This is precisely the problem with NTSB reports, they don't provide enough facts to make any conclusion. The final report usually come a year later and often does not have much more information than the preliminary reports. So so much for the requests to "wait for the NTSB report". We waited, and now we need the facts so we can draw our own conclusions and learn the lessons. And I am pretty sure that some of the readers know more. As for the plan to do a 180 to land, there is no mention of it in the NTSB report, only from Gary's comment. I think this is the key to be able to categorize this accident as "something went terribly wrong" vs "someone made a terrible decision" or did not know what they were doing. There is no much we can do to prevent the "something went terribly wrong" type of accidnets, *but there is much we can do to prevent the later and learn the lessons. Perhaps someone reading this will, as a result, *think twice before attempting an auto tow with a short rope on a short runway with limited straight ahead options. Incidentally, I recently visited such an airport were they attempted an autolaunch on a short runway, slightly uphill with no straight ahead option, and quickly learned they will be better off finding a tow plane. Ramy Ramy, Being very close to this and in the information stream has not been a lot of fun. The first glider I ever flew in was this DG1000 and the pilot was this pilot, Lynn, who became my primary CFIG. I have 50 flights in the glider and soloed in it and my logbook is full of sign- offs from Lynn who was a very careful pilot and seemed very risk adverse. As the current president of the club he was part of (and a CFIG for) I have been copied on most of the information and if there is a smoking gun I am not aware of it. If this occurred because of a defect or problem with the glider we won't know until the final NTSB report comes out. Even when you are close to the details there is a lot of confusion. I was told several times that the tow row was 1" nylon 200' long, the NTSB says it was 230' and 5/16". From eyewitnesses to the accident and to the 4 video feeds that the NTSB has the rope broke before it released (or was released) from the glider. Multiple accounts also describe a complete cycle prior to the accident where the glider was launched and landed ahead of the SUV and that this was another take. The information from the witness on the youtube video appears to be describing the previous days shooting in which the glider was areo-towed so it could be filmed with a helicopter, and the idea that there was a plan to turn around and land back I have only seen or heard about here on RAS, although there could have been such a plan. This weekend I was talking to a glider pilot who was there that day and his comment was that this probably will not be an accident where some mysterious aerodynamic factor or aircraft defect is discovered. The lesson will most likely be found in so many examples where complex human factors having nothing to do with aviation influenced highly skilled and trained professionals to start cutting the margins closer and closer. The book "Into Thin Air" comes to mind. When I first got into gliding I was surprised by how many accidents involved high time pilots, but it seems that at some point pilots stop being scared and start accepting more risks. Sort of like russian roulette where you pull the trigger 5 times and start to feel like it isn't very dangerous after all. Or, maybe it will turn out that something in the glider broke at the worst possible moment. In any case, one thing I would change about the set up going in is: Lynn should not have been the one to get all the credit, take all the blame, make all the decisions, and fly all the tasks. That was just too much workload. There should have been one or two other people making the go/nogo decisions free of ego and careless of blame or any outcome other than a living pilot at the end of the day. There was no shortage of people with vast auto tow and aerodynamic knowledge to choose from. I hope this doesn't come off as trying to lecture or pontificate, but after this year and all the accidents, maybe all it comes down to is trying to increase the margin of safety of every part of flying. Please fly safe, Brian |
On Oct 28, 2:29*pm, brianDG303 wrote:
On Oct 28, 10:23*am, Ramy wrote: On Oct 27, 9:28*pm, Steve Leonard wrote: What else about their “intentions” were you hoping the NTSB would state in a preliminary accident report? *Were you expecting them to detail the entire planned flight path, launch sequence, acceleration rate, tow car speed for the climb, film crew briefings? *Not gonna happen with with the NTSB. *They provided some eye-witness information which may or may not be misleading, and some facts about the airport, the registered owner of the plane, etc. *We have been told what their intentions were. * We have been told they were filming a commercial for Cadillac. *We have been told they used the vehicle for the ground launch. *We have been told they planned to tow the DG up with their rope (which the NTSB reports as 234 feet long, made from 5/16th nylon. *Although, I suspect it is polypropylene.), do a 180, and land back the other direction. *As for the rest of the sequence, I was not there, but am presenting what I believe is a plausible explanation of how the events may have transpired. We can assume that the rope was intact after the launch, as the NTSB report reports the length of the rope, and makes no comments about it being broken, or rings found in the glider, etc. *They would have stated the rope was broken it if had been. *So, this does not appear to be any sort of rope overload, as some were presuming. The witnesses stated that the takeoff appeared normal. *There is enough confusing information after this if you start putting the math to it about distance down the runway, altitude, etc to make one suspicious of the distance and height observations. *The witnesses reported that the plane "pitched to a steep nose high attitude." *We know that at some point in the climb (estimated to be 100 to 125 feet), the rope “slackend”. *Three ways the rope can "slacken". *Tow vehicle slows down, glider pushes over, or rope disconnects. *They say the glider continued to ascend to about 200 feet of altitude and leveled off. *Based on what they say happened next, I believe the rope disconnected and the pilot pushed over. In an auto tow launch, you lift off, bring the nose up *a little, get some altitude, then bring the nose on up. *As you near the top of the climb, the nose comes back down to pretty close to level. *Watch any video of a winch launch on YouTube. *Very similar, but on car tow, you don't accelerate as rapidly. *Depending on how the launch is conducted, you will be rotating to full climb between 100 and 200 feet. *Unfortunately, if you try for the same profile with a 234 foot rope as you would with a 2000 foot rope (be rotating to full climb angle at 100 feet AGL), the rope to hitch angle will likely hit the "back release" angle at somewhere between 100 and 150 feet AGL. *So, if you try to fly a "normal" launch profile on a short rope, you will likely get a low altitude back release, as the pilot in this accident probably got. So, here you are, about 100 to 150 or so feet AGL, 35-40 degrees or so nose up, about right on speed for the climb, and the release does its backrelease thing. *You are surprised, but put the stick on the forward stop as you are trained. *The plane keeps going up and keeps slowing down as you are going over the top. *By the time you go over the top at about 200 feet or so, and have the nose back down to normal gliding attitude, your airspeed is pretty well gone. *Do the math to see how much altitude you will gain in slowing from 60 to 30 knots or so, no drag losses. *Unless you keep the stick forward to get the nose well below the normal gliding attitude to get flying speed back (and give up what precious little altitude you have), you will stall. Pilot probably came across the top at about two hundred or so feet after this, less than one g and slower than 1 g stall speed. *He then likely attempted to initiate the turn, as things were "back to normal, per the plan." *Meaning, he was near the far end of the runway, at about 200 feet, ready to turn around. *Trouble is, he was below stall speed. *Attempted to turn and entered a spin. As to the max speed the towcar attained, I would be very surprised if they were attempting other than a "normal" ground launch sequnce, but with a very short rope. *"Normal" being accelerate the car to flying speed for the plane plus safety margin (no wind, say 65 MPH or so for the DG? *Remember, his airspeed would go up as soon as he starts to climb, and the intention was to climb), hold that speed, drive to near the end, and stop. A very sad and tragic accident. Respectfully, Steve Leonard What else about their “intentions” were you hoping the NTSB would state in a preliminary accident report? This is precisely the problem with NTSB reports, they don't provide enough facts to make any conclusion. The final report usually come a year later and often does not have much more information than the preliminary reports. So so much for the requests to "wait for the NTSB report". We waited, and now we need the facts so we can draw our own conclusions and learn the lessons. And I am pretty sure that some of the readers know more. As for the plan to do a 180 to land, there is no mention of it in the NTSB report, only from Gary's comment. I think this is the key to be able to categorize this accident as "something went terribly wrong" vs "someone made a terrible decision" or did not know what they were doing. There is no much we can do to prevent the "something went terribly wrong" type of accidnets, *but there is much we can do to prevent the later and learn the lessons. Perhaps someone reading this will, as a result, *think twice before attempting an auto tow with a short rope on a short runway with limited straight ahead options. Incidentally, I recently visited such an airport were they attempted an autolaunch on a short runway, slightly uphill with no straight ahead option, and quickly learned they will be better off finding a tow plane. Ramy Ramy, Being very close to this and in the information stream has not been a lot of fun. *The first glider I ever flew in was this DG1000 and the pilot was this pilot, Lynn, who became my primary CFIG. *I have 50 flights in the glider and soloed in it and my logbook is full of sign- offs from Lynn who was a very careful pilot and seemed very risk adverse. *As the current president of the club he was part of (and a CFIG for) I have been copied on most of the information and if there is a smoking gun I am not aware of it. If this occurred because of a defect or problem with the glider we won't know until the final NTSB report comes out. *Even when you are close to the details there is a lot of confusion. *I was told several times that the tow row was 1" nylon 200' long, the NTSB says it was 230' and 5/16". *From eyewitnesses to the accident and to the 4 video feeds that the NTSB has the rope broke before it released (or was released) from the glider. *Multiple accounts also describe a complete cycle prior to the accident where the glider was launched and landed ahead of the SUV and that this was another take. *The information from the witness on the youtube video appears to be describing the previous days shooting in which the glider was areo-towed so it could be filmed with a helicopter, and the idea that there was a plan to turn around and land back I have only seen or heard about here on RAS, although there could have been such a plan. This weekend I was talking to a glider pilot who was there that day and his comment was that this probably will not be an accident where some mysterious aerodynamic factor or aircraft defect is discovered. The lesson will most likely be found in so many examples where complex human factors having nothing to do with aviation influenced highly skilled and trained professionals *to start cutting the margins closer and closer. *The book "Into Thin Air" comes to mind. *When I first got into gliding I was surprised by how many accidents involved high time pilots, but it seems that at some point pilots stop being scared and start accepting more risks. *Sort of like russian roulette where you pull the trigger 5 times and start to feel like it isn't very dangerous after all. Or, maybe it will turn out that something in the glider broke at the worst possible moment. *In any case, one thing I would change about the set up going in is: *Lynn should not have been the one to get all the credit, take all the blame, make all the decisions, and fly all the tasks. *That was just too much workload. *There should have been one or two other people making the go/nogo decisions free of ego and careless of blame or any outcome other than a living pilot at the end of the day. *There was no shortage of people with vast auto tow and aerodynamic knowledge to choose from. I hope this doesn't come off as trying to lecture or pontificate, but after this year and all the accidents, maybe all it comes down to is trying to increase the margin of safety of every part of flying. Please fly safe, Brian- Hide quoted text - - Show quoted text - Brian, thanks for your comments and your thoughts, which are perhaps the most relevant and most informative about this accident so far (far more than the NTSB report will likely ever be) and I am glad you came forward and shared it with us. As you say, chances are that this is a classic case of "human factors having nothing to do with aviation influenced highly skilled and trained professionals to start cutting the margins closer and closer." This is what I believe most of us suspected. And the lesson learned for all of us is not to cut margins, but instead, as you said, increase the margin of safety. Ramy |
On Oct 28, 4:29*pm, brianDG303 wrote:
On Oct 28, 10:23*am, Ramy wrote: On Oct 27, 9:28*pm, Steve Leonard wrote: What else about their “intentions” were you hoping the NTSB would state in a preliminary accident report? *Were you expecting them to detail the entire planned flight path, launch sequence, acceleration rate, tow car speed for the climb, film crew briefings? *Not gonna happen with with the NTSB. *They provided some eye-witness information which may or may not be misleading, and some facts about the airport, the registered owner of the plane, etc. *We have been told what their intentions were. * We have been told they were filming a commercial for Cadillac. *We have been told they used the vehicle for the ground launch. *We have been told they planned to tow the DG up with their rope (which the NTSB reports as 234 feet long, made from 5/16th nylon. *Although, I suspect it is polypropylene.), do a 180, and land back the other direction. *As for the rest of the sequence, I was not there, but am presenting what I believe is a plausible explanation of how the events may have transpired. We can assume that the rope was intact after the launch, as the NTSB report reports the length of the rope, and makes no comments about it being broken, or rings found in the glider, etc. *They would have stated the rope was broken it if had been. *So, this does not appear to be any sort of rope overload, as some were presuming. The witnesses stated that the takeoff appeared normal. *There is enough confusing information after this if you start putting the math to it about distance down the runway, altitude, etc to make one suspicious of the distance and height observations. *The witnesses reported that the plane "pitched to a steep nose high attitude." *We know that at some point in the climb (estimated to be 100 to 125 feet), the rope “slackend”. *Three ways the rope can "slacken". *Tow vehicle slows down, glider pushes over, or rope disconnects. *They say the glider continued to ascend to about 200 feet of altitude and leveled off. *Based on what they say happened next, I believe the rope disconnected and the pilot pushed over. In an auto tow launch, you lift off, bring the nose up *a little, get some altitude, then bring the nose on up. *As you near the top of the climb, the nose comes back down to pretty close to level. *Watch any video of a winch launch on YouTube. *Very similar, but on car tow, you don't accelerate as rapidly. *Depending on how the launch is conducted, you will be rotating to full climb between 100 and 200 feet. *Unfortunately, if you try for the same profile with a 234 foot rope as you would with a 2000 foot rope (be rotating to full climb angle at 100 feet AGL), the rope to hitch angle will likely hit the "back release" angle at somewhere between 100 and 150 feet AGL. *So, if you try to fly a "normal" launch profile on a short rope, you will likely get a low altitude back release, as the pilot in this accident probably got. So, here you are, about 100 to 150 or so feet AGL, 35-40 degrees or so nose up, about right on speed for the climb, and the release does its backrelease thing. *You are surprised, but put the stick on the forward stop as you are trained. *The plane keeps going up and keeps slowing down as you are going over the top. *By the time you go over the top at about 200 feet or so, and have the nose back down to normal gliding attitude, your airspeed is pretty well gone. *Do the math to see how much altitude you will gain in slowing from 60 to 30 knots or so, no drag losses. *Unless you keep the stick forward to get the nose well below the normal gliding attitude to get flying speed back (and give up what precious little altitude you have), you will stall. Pilot probably came across the top at about two hundred or so feet after this, less than one g and slower than 1 g stall speed. *He then likely attempted to initiate the turn, as things were "back to normal, per the plan." *Meaning, he was near the far end of the runway, at about 200 feet, ready to turn around. *Trouble is, he was below stall speed. *Attempted to turn and entered a spin. As to the max speed the towcar attained, I would be very surprised if they were attempting other than a "normal" ground launch sequnce, but with a very short rope. *"Normal" being accelerate the car to flying speed for the plane plus safety margin (no wind, say 65 MPH or so for the DG? *Remember, his airspeed would go up as soon as he starts to climb, and the intention was to climb), hold that speed, drive to near the end, and stop. A very sad and tragic accident. Respectfully, Steve Leonard What else about their “intentions” were you hoping the NTSB would state in a preliminary accident report? This is precisely the problem with NTSB reports, they don't provide enough facts to make any conclusion. The final report usually come a year later and often does not have much more information than the preliminary reports. So so much for the requests to "wait for the NTSB report". We waited, and now we need the facts so we can draw our own conclusions and learn the lessons. And I am pretty sure that some of the readers know more. As for the plan to do a 180 to land, there is no mention of it in the NTSB report, only from Gary's comment. I think this is the key to be able to categorize this accident as "something went terribly wrong" vs "someone made a terrible decision" or did not know what they were doing. There is no much we can do to prevent the "something went terribly wrong" type of accidnets, *but there is much we can do to prevent the later and learn the lessons. Perhaps someone reading this will, as a result, *think twice before attempting an auto tow with a short rope on a short runway with limited straight ahead options. Incidentally, I recently visited such an airport were they attempted an autolaunch on a short runway, slightly uphill with no straight ahead option, and quickly learned they will be better off finding a tow plane. Ramy Ramy, Being very close to this and in the information stream has not been a lot of fun. *The first glider I ever flew in was this DG1000 and the pilot was this pilot, Lynn, who became my primary CFIG. *I have 50 flights in the glider and soloed in it and my logbook is full of sign- offs from Lynn who was a very careful pilot and seemed very risk adverse. *As the current president of the club he was part of (and a CFIG for) I have been copied on most of the information and if there is a smoking gun I am not aware of it. If this occurred because of a defect or problem with the glider we won't know until the final NTSB report comes out. *Even when you are close to the details there is a lot of confusion. *I was told several times that the tow row was 1" nylon 200' long, the NTSB says it was 230' and 5/16". *From eyewitnesses to the accident and to the 4 video feeds that the NTSB has the rope broke before it released (or was released) from the glider. *Multiple accounts also describe a complete cycle prior to the accident where the glider was launched and landed ahead of the SUV and that this was another take. *The information from the witness on the youtube video appears to be describing the previous days shooting in which the glider was areo-towed so it could be filmed with a helicopter, and the idea that there was a plan to turn around and land back I have only seen or heard about here on RAS, although there could have been such a plan. This weekend I was talking to a glider pilot who was there that day and his comment was that this probably will not be an accident where some mysterious aerodynamic factor or aircraft defect is discovered. The lesson will most likely be found in so many examples where complex human factors having nothing to do with aviation influenced highly skilled and trained professionals *to start cutting the margins closer and closer. *The book "Into Thin Air" comes to mind. *When I first got into gliding I was surprised by how many accidents involved high time pilots, but it seems that at some point pilots stop being scared and start accepting more risks. *Sort of like russian roulette where you pull the trigger 5 times and start to feel like it isn't very dangerous after all. Or, maybe it will turn out that something in the glider broke at the worst possible moment. *In any case, one thing I would change about the set up going in is: *Lynn should not have been the one to get all the credit, take all the blame, make all the decisions, and fly all the tasks. *That was just too much workload. *There should have been one or two other people making the go/nogo decisions free of ego and careless of blame or any outcome other than a living pilot at the end of the day. *There was no shortage of people with vast auto tow and aerodynamic knowledge to choose from. I hope this doesn't come off as trying to lecture or pontificate, but after this year and all the accidents, maybe all it comes down to is trying to increase the margin of safety of every part of flying. Please fly safe, Brian Brian mentioned INTO THIN AIR, a book glider pilots, or anyone who participates in activities that have a higher than average risks, ought to read. On Everest, the real pros didn’t make a push for the summit. They possessed unwavering safety principles. They did not put others at risk. In fact, they were in the position to save many people who put personal goals ahead of safety concerns. I do not draw any conclusions about the recent tragedies. Rather, I am suggesting that we goal- oriented pilots could use this book as a reminder that part of being an expert is knowing when to abandon high risk tasks. Most of us have felt moments when it's not easy to think safety when the goal is so very close. We have to rely on our own code of conduct and remember that sometimes there are higher rewards for not doing something instead of being “brave enough” to do it.. Val |
On 10/28/2011 3:29 PM, brianDG303 wrote:
On Oct 28, 10:23 am, wrote: Major snip of another's excellent 'possible accident contributors' analysis... This is precisely the problem with NTSB reports, they don't provide enough facts to make any conclusion. Additional valid grousing snipped... Ramy Ramy, Being very close to this and in the information stream has not been a lot of fun. The first glider I ever flew in was this DG1000 and the pilot was this pilot, Lynn, who became my primary CFIG. I have 50 flights in the glider and soloed in it and my logbook is full of sign- offs from Lynn who was a very careful pilot and seemed very risk adverse. As the current president of the club he was part of (and a CFIG for) I have been copied on most of the information and if there is a smoking gun I am not aware of it. If this occurred because of a defect or problem with the glider we won't know until the final NTSB report comes out. Even when you are close to the details there is a lot of confusion. I was told several times that the tow row was 1" nylon 200' long, the NTSB says it was 230' and 5/16". From eyewitnesses to the accident and to the 4 video feeds that the NTSB has the rope broke before it released (or was released) from the glider. Multiple accounts also describe a complete cycle prior to the accident where the glider was launched and landed ahead of the SUV and that this was another take. The information from the witness on the youtube video appears to be describing the previous days shooting in which the glider was areo-towed so it could be filmed with a helicopter, and the idea that there was a plan to turn around and land back I have only seen or heard about here on RAS, although there could have been such a plan. This weekend I was talking to a glider pilot who was there that day and his comment was that this probably will not be an accident where some mysterious aerodynamic factor or aircraft defect is discovered. The lesson will most likely be found in so many examples where complex human factors having nothing to do with aviation influenced highly skilled and trained professionals to start cutting the margins closer and closer. The book "Into Thin Air" comes to mind. When I first got into gliding I was surprised by how many accidents involved high time pilots, but it seems that at some point pilots stop being scared and start accepting more risks. Sort of like russian roulette where you pull the trigger 5 times and start to feel like it isn't very dangerous after all. Or, maybe it will turn out that something in the glider broke at the worst possible moment. In any case, one thing I would change about the set up going in is: Lynn should not have been the one to get all the credit, take all the blame, make all the decisions, and fly all the tasks. That was just too much workload. There should have been one or two other people making the go/nogo decisions free of ego and careless of blame or any outcome other than a living pilot at the end of the day. There was no shortage of people with vast auto tow and aerodynamic knowledge to choose from. I hope this doesn't come off as trying to lecture or pontificate, but after this year and all the accidents, maybe all it comes down to is trying to increase the margin of safety of every part of flying. Please fly safe, Brian Thank you for this (and all your) post(s) on this sad and painful accident, Brian. By way of psychological preparation...IME, future exposure to (fatal or otherwise) accidents involving your soaring friends and acquaintances won't get any easier... FWIW, I think you've touched above upon a couple of fundamental and crucial points worth bearing continually in mind (and - hopefully - presumably in related action) by all practicing soaring pilots, regardless of experience, currency or anything else: 1) (referencing your thoughts...) The lesson will most likely be found in so many examples where complex human factors having nothing to do with aviation influenced highly skilled and trained professionals to start cutting the margins closer and closer. The book "Into Thin Air" comes to mind. When I first got into gliding I was surprised by how many accidents involved high time pilots, but it seems that at some point pilots stop being scared and start accepting more risks. Sort of like russian roulette where you pull the trigger 5 times and start to feel like it isn't very dangerous after all. Indeed the acceptance of increasing risks is 'the natural progression' of increasing soaring pilot knowledge and activity. IMO, the "trick" (if there is one) is for Joe Growing Pilot to always/continually/actively remain *aware* that such a process and progression is occurring, and to recognize and act in ways respecting his/her ever-changing margins. Be vary aware/wary of any thoughts touching upon 'my growing experience is my protection.' Which leads to... 2) (also referencing your thoughts...) In any case, one thing I would change about the set up going in is: Lynn should not have been the one to get all the credit, take all the blame, make all the decisions, and fly all the tasks. That was just too much workload. There should have been one or two other people making the go/nogo decisions free of ego and careless of blame or any outcome other than a living pilot at the end of the day. There was no shortage of people with vast auto tow and aerodynamic knowledge to choose from. "Spot on!" (I'd *still* say the same thing even had everything turned out as-planned.) Knowing nothing of the particulars, but also knowing very few people (much less soaring pilots) with direct 'film industry experience,' I'd be statistically astounded if 'all of this situation' was NOT essentially new ground for the pilot involved. It sure would've been for me. If proposed to me, the whole 'dynamic' of a situation as this would have instantly raised multiple alarm bells in my mind, entirely for 'newness' - and therefore safety - reasons. Clint Eastwood was right: "A man's got to know his limitations." I like to imagine that - as a minimum - I'd've done as you suggest. Soaring is sufficiently demanding an activity withOUT complicating the situation with hopes and desires of folks experienced enough in their own fields, but (almost certainly) 100% ignorant about the things they'll be requesting of Joe Pilot. Respectfully and Sadly, Bob W. |
Final NTSB report on Fossett crash | danlj | Soaring | 0 | July 10th 09 06:32 AM |
NTSB Factual Walton Crash | ChuckSlusarczyk | Home Built | 29 | September 5th 06 06:59 PM |
NTSB Preliminary report on HPN crash | Peter R. | Instrument Flight Rules | 83 | May 10th 05 08:37 PM |
Hendricks Crash- NTSB Prelim | C Kingsbury | Instrument Flight Rules | 10 | November 14th 04 02:18 AM |
NTSB: Co-pilot error caused AA 587 crash | Bertie the Bunyip | Piloting | 4 | November 3rd 04 04:30 AM |
