Anyone using an Oudie with a CA302 ? Any comments on it? How do you
have it hooked up? Are you using the internal GPS or the 302 GPS? Would you buy one now or wait? Thanks, S9 |
On Oct 30, 4:19*pm, Stephen wrote:
Anyone using an Oudie with a CA302 ? Any comments on it? *How do you have it hooked up? * *Are you using the internal GPS or the 302 GPS? Would you buy one now or wait? Thanks, S9 Stephen, The oudie works well with the CAI 302. The Oudie is powered with the optional cable by the 302 . SeeYou is set up in the Hardware 302 screen and port is also set to COM 4 to use the CAI 302 GPS. This will give you direct winds instead of the circling winds with the internal GPS. http://www.craggyaero.com/oudie.htm http://www.craggyaero.com/CAI.htm Richard www.craggyaero.com |
Hi Stephen,
I'm biased since I sell both 302s and Oudies, but I think they make a great combination. I flew with an Oudie connected to a 302A at a soaring contest last year and was very happy with the pair. It would have been better to have the Oudie connected to a 302 so it could receive vario, wind and airspeed data from the 302. I used the Oudie and ConnectMe software to download flight logs from the 302A to a microSD memory card. The Oudie can also send task declarations to the 302 or 302A. I have tested it - it works great. The Oudie is supplied with a power/data cable that has an RJ45 connector, and an RJ45 to DB-9 connector. The RJ45 to DB-9 connector can be configured to work with the 302. It is a simple and free solution. The Oudie's power/data cable must be powered with 12V. Another option is the Oudie-PS5a-1 cable. It can be powered with 5V from the 302 and also pass 5V power to the Oudie. You can see details he http://www.cumulus-soaring.com/goddard.htm#Oudie-PS5a-1 I highly recommend connecting the 302 to the Oudie so the 302 can send vario, wind and airspeed data to the Oudie. If the connect to the 302 fails, or the 302 fails, the Oudie will automatically switch over to using its internal GPS. That makes for a nice, redundant system. I've sold over 340 Oudies so far. Obviously there must be many happy customers that are telling their friends about the Oudie. Best Regards, Paul Remde Cumulus Soaring, Inc. "Stephen" wrote in message ... Anyone using an Oudie with a CA302 ? Any comments on it? How do you have it hooked up? Are you using the internal GPS or the 302 GPS? Would you buy one now or wait? Thanks, S9 |
![]() Curious .. 1) Does the Oudie create a separate .igc file even when using the 302 gps? 2) If the 302 gps fails and the Oudie switches to internal gps, will the .igc file be intact? S9 |
Hi,
Both the 302 and the Oudie log the flight in separate files. Only the 302 file is accepted for badges and records. If the 302 fails the Oudie would still log the flight, but it couldn't be used for badges or records. Paul Remde "Stephen" wrote in message ... Curious .. 1) Does the Oudie create a separate .igc file even when using the 302 gps? 2) If the 302 gps fails and the Oudie switches to internal gps, will the .igc file be intact? S9 |
....But it *could* be used for OLC. At least the file generated by my hacked
Mio running XCSoar was accepted in a test. "Paul Remde" wrote in message ... Hi, Both the 302 and the Oudie log the flight in separate files. Only the 302 file is accepted for badges and records. If the 302 fails the Oudie would still log the flight, but it couldn't be used for badges or records. Paul Remde "Stephen" wrote in message ... Curious .. 1) Does the Oudie create a separate .igc file even when using the 302 gps? 2) If the 302 gps fails and the Oudie switches to internal gps, will the .igc file be intact? S9 |
On Nov 1, 1:27*pm, "Dan Marotta" wrote:
...But it *could* be used for OLC. *At least the file generated by my hacked Mio running XCSoar was accepted in a test. "Paul Remde" wrote in message ... Hi, Both the 302 and the Oudie log the flight in separate files. *Only the 302 file is accepted for badges and records. If the 302 fails the Oudie would still log the flight, but it couldn't be used for badges or records. Paul Remde "Stephen" wrote in message .... Curious .. 1) Does the Oudie create a separate .igc file even when using the 302 gps? 2) If the 302 gps fails and the Oudie switches to internal gps, will the .igc file be intact? S9 Oudie log file most definitely will be accepted by the OLC. Be careful to exit SeeYou Mobile before powering down the Oudie or it will result in an invalid IGC file giving the dreaded red circle of doom. Oudie logging its own separate file saved my butt on Day 1 of the Region 10 contest when the SD Card on the Nano somehow popped out during flight. I also had my FlywithCE running during the flight as a third backup but didn't have to resort to that. |
On Oct 30, 8:03*pm, "Paul Remde" wrote:
The Oudie is supplied with a power/data cable that has an RJ45 connector, and an RJ45 to DB-9 connector. *The RJ45 to DB-9 connector can be configured to work with the 302. *It is a simple and free solution. *The Oudie's power/data cable must be powered with 12V. Another option is the Oudie-PS5a-1 cable. *It can be powered with 5V from the 302 and also pass 5V power to the Oudie. *You can see details hehttp://www.cumulus-soaring.com/goddard.htm#Oudie-PS5a-1 Paul - How is the Oudie-PS5a-1 cable better than the supplied Naviter cable in the box? With the supplied Naviter cable you have this setup; 12VDC = 302 = Oudie supplied cable (serial) = Oudie 12VDC = same Oudie supplied cable (12VDC to 5VDC converter) = Oudie With the Oudie-PS5a-1 cable you would have this setup; 12VDC = 302 = Oudie-PS5a-1 (serial + 5VDC) = Oudie So the Oudie-PS5a-1 solution is cleaner/neater. Is it electrically better? Better 12VDC to 5VDC conversion? Better RS-232 signal converter? Thanks, John |
Hi John,
Please see my notes below. Paul Remde "JohnDeRosa" wrote in message ... On Oct 30, 8:03 pm, "Paul Remde" wrote: The Oudie is supplied with a power/data cable that has an RJ45 connector, and an RJ45 to DB-9 connector. The RJ45 to DB-9 connector can be configured to work with the 302. It is a simple and free solution. The Oudie's power/data cable must be powered with 12V. Another option is the Oudie-PS5a-1 cable. It can be powered with 5V from the 302 and also pass 5V power to the Oudie. You can see details hehttp://www.cumulus-soaring.com/goddard.htm#Oudie-PS5a-1 Paul - How is the Oudie-PS5a-1 cable better than the supplied Naviter cable in the box? *** The Oudie's power/data cable must be powered with 12V. The Oudie-PS5a-1 cable is powered with 5V from the 302. Once installed, there are no functional differences that I'm aware of. With the supplied Naviter cable you have this setup; 12VDC = 302 = Oudie supplied cable (serial) = Oudie 12VDC = same Oudie supplied cable (12VDC to 5VDC converter) = Oudie With the Oudie-PS5a-1 cable you would have this setup; 12VDC = 302 = Oudie-PS5a-1 (serial + 5VDC) = Oudie So the Oudie-PS5a-1 solution is cleaner/neater. Is it electrically better? Better 12VDC to 5VDC conversion? Better RS-232 signal converter? *** Good questions. The only advantage is the simple and clean setup. It eliminates the need to connect the Oudie's power/data cable to 12V. The Oudie-PS5a-1 cable has been quite popular. I guess many people prefer the simple and clean approach. Thanks, John |
One other point I'd like to offer concerning the PS-5a-1 Cable. The
early models of the cable apparently were prone to breakage in the mini-USB plug (Oudie end of the cable). Mine broke internally after more than a year and Paul Remde and Goddard Electronics provided excellent support and an updated cable in a very short time. I highly commend and recommend them for their great customer service. The cable costs more than a little, but it does work extremely well and is a no-brainer to set up. Connect it to the serial port on the 302, plug the other end into the Oudie, set up the Oudie communication menu, and you're off to the races! |
Oudie | Steve Hunt | Soaring | 2 | July 8th 11 12:19 AM |
oudie | Steve Hunt[_2_] | Soaring | 0 | July 7th 11 08:58 AM |
FS: Naviter Oudie | Jonathan Hughes | Soaring | 2 | May 26th 11 06:55 PM |
Oudie with a LX 5000 | Randy[_2_] | Soaring | 2 | May 24th 10 10:48 AM |
