Hi,
I stand corrected. Paul Remde "ZL" wrote in message m... The 302 manual (pg 25) says pin 4 of the RJ11 is "+5V = Device power – fuse-limited to 0.9 Amp" pin 6 and 8 of the DB-9 connector are "+5 volt power from 302 to connected device; fuse-limited to 0.9 Amp" I've used the DB-9 connector on my 302 to provide +5V power to an iPAQ for 7 years now. Cambridge and others have sold connectors for that purpose for a long time. I also have a 303 hooked up to the RJ11 plug. Manual is available at the Cambridge website. -Dave On 11/1/2011 6:33 PM, Paul Remde wrote: Hi Dan, That is a very bad idea! The RJ connector on the back of the 302 is for connection to the 303 LCD display. The 303 is a low voltage device. Your Mio is not. I'm not certain, but I fear you will fry something in the 302. Best Regards, Paul Remde "Dan Marotta" wrote in message ... While I had my panel apart the other day, I noticed the RJ jack in the back of the 302. Since I had half a Cambridge cable, I plugged it in, powered up, and measured voltage across the red and black leads - 5v! I took a standard USB cable that fits the Mio, cut it, and measured the red and black leads - again, 5v! Tomorrow, I'll connect the two cables together and run the Mio of the ship's batteries. Dan |
Why are my posts red (color, at least on my laptop)?
Thanks, Paul - I did not consider looking up the specs, which I will do. Dave, I read in the 302 manual about the 0.9A internal fusing in the 302. The cigarette lighter power cord that comes with the Mio is terminated with a mini USB connector so there should be no power/data issues. The data lines are not connected in this case. I will try to find the power requirements of the Mio online. I opened it up and it has a small (physically) battery so I suspect its power needs aren't too big. I could wire a 12v power cord into the main bus of the glider, but that's large and there's not a lot of room inside the LAK's panel. Besides, simply plugging in is so much easier! I'll report back what (if anything) I find. "Paul Remde" wrote in message ... Hi, I stand corrected. Paul Remde "ZL" wrote in message m... The 302 manual (pg 25) says pin 4 of the RJ11 is "+5V = Device power – fuse-limited to 0.9 Amp" pin 6 and 8 of the DB-9 connector are "+5 volt power from 302 to connected device; fuse-limited to 0.9 Amp" I've used the DB-9 connector on my 302 to provide +5V power to an iPAQ for 7 years now. Cambridge and others have sold connectors for that purpose for a long time. I also have a 303 hooked up to the RJ11 plug. Manual is available at the Cambridge website. -Dave On 11/1/2011 6:33 PM, Paul Remde wrote: Hi Dan, That is a very bad idea! The RJ connector on the back of the 302 is for connection to the 303 LCD display. The 303 is a low voltage device. Your Mio is not. I'm not certain, but I fear you will fry something in the 302. Best Regards, Paul Remde "Dan Marotta" wrote in message ... While I had my panel apart the other day, I noticed the RJ jack in the back of the 302. Since I had half a Cambridge cable, I plugged it in, powered up, and measured voltage across the red and black leads - 5v! I took a standard USB cable that fits the Mio, cut it, and measured the red and black leads - again, 5v! Tomorrow, I'll connect the two cables together and run the Mio of the ship's batteries. Dan |
Well... All the Mio specs I could find are that it has a 750 mAH battery
which should last for 2.5 hours (and I know from experience that that is about right). At 5 volts that would indicate a current draw of 288 mA. I called Mio tech support and they confirmed that number so running the Mio from a 900 mA port on the 302 should be no problem at all. Thanks to Paul, for raising a red flag, and to Dave for describing his setup. "Dan Marotta" wrote in message ... Why are my posts red (color, at least on my laptop)? Thanks, Paul - I did not consider looking up the specs, which I will do. Dave, I read in the 302 manual about the 0.9A internal fusing in the 302. The cigarette lighter power cord that comes with the Mio is terminated with a mini USB connector so there should be no power/data issues. The data lines are not connected in this case. I will try to find the power requirements of the Mio online. I opened it up and it has a small (physically) battery so I suspect its power needs aren't too big. I could wire a 12v power cord into the main bus of the glider, but that's large and there's not a lot of room inside the LAK's panel. Besides, simply plugging in is so much easier! I'll report back what (if anything) I find. "Paul Remde" wrote in message ... Hi, I stand corrected. Paul Remde "ZL" wrote in message m... The 302 manual (pg 25) says pin 4 of the RJ11 is "+5V = Device power – fuse-limited to 0.9 Amp" pin 6 and 8 of the DB-9 connector are "+5 volt power from 302 to connected device; fuse-limited to 0.9 Amp" I've used the DB-9 connector on my 302 to provide +5V power to an iPAQ for 7 years now. Cambridge and others have sold connectors for that purpose for a long time. I also have a 303 hooked up to the RJ11 plug. Manual is available at the Cambridge website. -Dave On 11/1/2011 6:33 PM, Paul Remde wrote: Hi Dan, That is a very bad idea! The RJ connector on the back of the 302 is for connection to the 303 LCD display. The 303 is a low voltage device. Your Mio is not. I'm not certain, but I fear you will fry something in the 302. Best Regards, Paul Remde "Dan Marotta" wrote in message ... While I had my panel apart the other day, I noticed the RJ jack in the back of the 302. Since I had half a Cambridge cable, I plugged it in, powered up, and measured voltage across the red and black leads - 5v! I took a standard USB cable that fits the Mio, cut it, and measured the red and black leads - again, 5v! Tomorrow, I'll connect the two cables together and run the Mio of the ship's batteries. Dan |
![]() I called Mio tech support and they confirmed that number so running the Mio from a 900 mA port on the 302 should be no problem at all. - Not sure if the internal fuse of .9A is internally wired to this particular 5V output. When I tried using my HX4700 with the C302 via the serial cable, that was wired to provide the 5V out of the 302, the 302 would not function properly. The vario would black out and it seemed that the ipaq is drawing all the power out if, even though the input to the C302 had plenty of power. In a nutshell, I did not damage the C302, but I don’t believe there is a fuse inside - I measured later that the half charged HX4700 was drawing about 1.5 Amps and C302 would only work with fully charged HX4700 because the lower amp consumption. Considering MIO tech support is probably located where it is I would not put too much faith in them especially since you can damage the C302. Safe soaring, GK |
Hi GK,
I suspect that the iPAQ's battery was low. The hx4700 draws only about 300 to 400 mA when the battery is fully charged. But it can draw well over 1 A when the battery is low. The 302 would probably work fine if you connected the hx4700 to it when the battery was fully or nearly fully charged. I've used hx4700 units with 302s many times with no problems. Best Regards, Paul Remde Cumulus Soaring, Inc. "GK" wrote in message ... I called Mio tech support and they confirmed that number so running the Mio from a 900 mA port on the 302 should be no problem at all. - Not sure if the internal fuse of .9A is internally wired to this particular 5V output. When I tried using my HX4700 with the C302 via the serial cable, that was wired to provide the 5V out of the 302, the 302 would not function properly. The vario would black out and it seemed that the ipaq is drawing all the power out if, even though the input to the C302 had plenty of power. In a nutshell, I did not damage the C302, but I don’t believe there is a fuse inside - I measured later that the half charged HX4700 was drawing about 1.5 Amps and C302 would only work with fully charged HX4700 because the lower amp consumption. Considering MIO tech support is probably located where it is I would not put too much faith in them especially since you can damage the C302. Safe soaring, GK |
On Wed, 02 Nov 2011 13:18:20 -0500, Paul Remde wrote:
I suspect that the iPAQ's battery was low. The hx4700 draws only about 300 to 400 mA when the battery is fully charged. But it can draw well over 1 A when the battery is low. The 302 would probably work fine if you connected the hx4700 to it when the battery was fully or nearly fully charged. I'd agree. I have an ancient iPAQ 3630 which specifies that its 5v connection can draw up to 1.4 amps from a charger or whatever. As it is supposed to run for 3 hours from a full charge and has an 800 mAh battery, that implies that it uses around 270 mA during normal operation. Its also worth remembering that the USB 2.0 spec says a connection should be rated for 800 mA - and there are some devices that will try to draw more than that. However, it would be wise to size the Mio power supply for at least 1.5 amps[1] rather than 0.4 amps because at some point Murphy guarantees you *will* connect the Mio with with an almost fully discharged battery. For what its worth, I bought a cheap 12v charging cable off eBay for my iPAQ and took it apart. The cigar-lighter end contains a very small 12v - 5v converter rated at 1.5 amps. I installed it in a small metal box (these small switch-mode voltage converters may stick out a lot of RF hash) and permanently wired its 12v side to the glider battery. I have lots of bad experiences with those cigar lighter plugs leaping out of the socket for no apparent reason, so wasn't going to risk using one: besides they are very bulky. The iPAQ is long retired, but I'm still using the voltage adapter, which has to date powered the iPAQ 3630, a Garmin GPSII+ and, currently, my Binatone B.350 PNA. [1] or the Mio's rated max input current, whichever is largest. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Disregarding Murphy, the Mio will always be connected to external power, so
no low battery. I hooked it up yesterday and spent a half hour or so sitting in the cockpit making glider noises. Everything looks good. I appreciate the advice about the 302 acting up and, should I see that sort of behavior, will simply switch batteries or shut off the Mio and see if there's any change. It's hard to imagine the Mio using much more than 300 mA. "Martin Gregorie" wrote in message ... On Wed, 02 Nov 2011 13:18:20 -0500, Paul Remde wrote: I suspect that the iPAQ's battery was low. The hx4700 draws only about 300 to 400 mA when the battery is fully charged. But it can draw well over 1 A when the battery is low. The 302 would probably work fine if you connected the hx4700 to it when the battery was fully or nearly fully charged. I'd agree. I have an ancient iPAQ 3630 which specifies that its 5v connection can draw up to 1.4 amps from a charger or whatever. As it is supposed to run for 3 hours from a full charge and has an 800 mAh battery, that implies that it uses around 270 mA during normal operation. Its also worth remembering that the USB 2.0 spec says a connection should be rated for 800 mA - and there are some devices that will try to draw more than that. However, it would be wise to size the Mio power supply for at least 1.5 amps[1] rather than 0.4 amps because at some point Murphy guarantees you *will* connect the Mio with with an almost fully discharged battery. For what its worth, I bought a cheap 12v charging cable off eBay for my iPAQ and took it apart. The cigar-lighter end contains a very small 12v - 5v converter rated at 1.5 amps. I installed it in a small metal box (these small switch-mode voltage converters may stick out a lot of RF hash) and permanently wired its 12v side to the glider battery. I have lots of bad experiences with those cigar lighter plugs leaping out of the socket for no apparent reason, so wasn't going to risk using one: besides they are very bulky. The iPAQ is long retired, but I'm still using the voltage adapter, which has to date powered the iPAQ 3630, a Garmin GPSII+ and, currently, my Binatone B.350 PNA. [1] or the Mio's rated max input current, whichever is largest. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Trying again: Collings Foundation B-17 at Newcastle Airport inDelaware - B-17 cockpit.jpg - B-17 cockpit.jpg (1/5) | Jim Breckenridge | Aviation Photos | 1 | August 30th 08 07:36 PM |
Trying again: Collings Foundation B-17 at Newcastle Airport in Delaware - B-17 cockpit.jpg - B-17 cockpit.jpg (0/5) | Go-dot | Aviation Photos | 0 | August 28th 08 11:39 PM |
Wings of Freedom B-17 Wilmington, DE - B-17 cockpit.jpg - B-17 cockpit.jpg (1/5) | Waldo.Pepper[_2_] | Aviation Photos | 0 | August 28th 08 10:31 PM |
Wings of Freedom B-17 Wilmington, DE - B-17 cockpit.jpg - B-17 cockpit.jpg (0/5) | Go-dot | Aviation Photos | 0 | August 28th 08 09:37 PM |
Powering JSF: One Engine Is Enough. | Mike[_7_] | Naval Aviation | 42 | February 14th 08 09:53 PM |
