Glasflugel AD
Old November 7th 11, 10:08 AM posted to rec.aviation.soaring
stephanevdv
Default Glasflugel AD
On Nov 6, 1:51*pm, Martin Gregorie
On Sat, 05 Nov 2011 22:02:21 -0500, Bob Gibbons wrote:
Again, based on the EASA note and the Schempp-Hirth experience, this
should only effect ships with a top mounted elevator and a vertical
pushrod in the tail (T-tail designs).
Agreed, which makes its applicability to the one Std. Libelle, H.201b,
s/n 169 particularly intriguing.
martin@ * | Martin Gregorie
gregorie. | Essex, UK
org * * * |
S/n 169 was a one-of-a-kind Libelle with T-tail, made for Eugen
Aeberli, one of the three "fathers" of the Libelle (Hänle, Hütter,
Aeberli).
Changes compared to H201: - rounded fuselage beam - T-tail - 5 cm
broader cockpit - contoured wing/fuselage transition - flat canopy, as
for H301 "open class" Libelle. Water ballast and winglets added later.
The glider was built in 1970 as a kind of prototype for the H 205/206.
Flies in Ettenheim in Baden-Württemberg. Source: http://libelle.bugwiper..com/freaks.htm
Old November 8th 11, 12:06 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Mon, 07 Nov 2011 02:08:04 -0800, stephanevdv wrote:
S/n 169 was a one-of-a-kind Libelle with T-tail, made for Eugen Aeberli,
Aeberli).
http://libelle.bugwiper.com/freaks.htm .
Thanks for the information.
Were its airbrakes improved at all? I'd think that would be a good idea
since it probably doesn't shed height in a slip as well without the
teardrop boom cross section.
martin@ | Martin Gregorie
org |
Glasflugel 303 canopy Wayne Paul Soaring 4 December 12th 09 07:00 PM
Glasflugel 303 canopy Wayne Paul Home Built 0 December 12th 09 05:42 AM
FS:Original Glasflugel 304 Pete Russell Soaring 0 March 5th 06 11:58 PM
Looking for the old Glasflugel Logo fcuk'n Soaring 4 January 1st 05 04:29 AM
FS: Glasflugel 304c tvlawyer Soaring 0 February 28th 04 02:56 AM
