On Nov 15, 6:17*pm, John Cochrane
wrote: On Nov 15, 3:57*pm, JohnDeRosa wrote: On Nov 15, 10:54*am, Bill D wrote: Qualcom's Mirasol display looks like a magazine cover in direct sunlight. And at 1/10th the power requirements. *Important for gliders but this will also really impact battery life for everything from laptops, tablets to cell phones. I hate to break it to you guys, but there is a gorgeous sunlight readable display on the market, the clear-nav. SN10 is pretty easy to read too, but offers less stuff on the screen, which Dave might argue is an advantage. No need to wait... John Cochrane Don't think so. Current engineering specs say 1500 nits brightness is required for 'good' readability in direct sunlight. CCFL's backlights delivering that brightness would pull amps, not mili-amps. LED backlights are better but current draw and heating are still problems. If you did somehow create a screen with 1500 nits brightness, it would be like looking into a car headlight. I can't find the specs, but I'm guessing the best glider displays are in the 500 - 1000 nit brightness range and pull around .8 amps. Far easier on the eyes and battery would be a high-contrast, high color saturation REFLECTIVE display like the Mirasol technology. |
On Nov 16, 11:44*am, Bill D wrote:
On Nov 15, 6:17*pm, John Cochrane wrote: On Nov 15, 3:57*pm, JohnDeRosa wrote: On Nov 15, 10:54*am, Bill D wrote: Qualcom's Mirasol display looks like a magazine cover in direct sunlight. And at 1/10th the power requirements. *Important for gliders but this will also really impact battery life for everything from laptops, tablets to cell phones. I hate to break it to you guys, but there is a gorgeous sunlight readable display on the market, the clear-nav. SN10 is pretty easy to read too, but offers less stuff on the screen, which Dave might argue is an advantage. No need to wait... John Cochrane Don't think so. Current engineering specs say 1500 nits brightness is required for 'good' readability in direct sunlight. *CCFL's backlights delivering that brightness would pull amps, not mili-amps. *LED backlights are better but current draw and heating are still problems. *If you did somehow create a screen with 1500 nits brightness, it would be like looking into a car headlight. I can't find the specs, but I'm guessing the best glider displays are in the 500 - 1000 nit brightness range and pull around .8 amps. Far easier on the eyes and battery would be a high-contrast, high color saturation REFLECTIVE display like the Mirasol technology. I have no experience with competing displays so can't speak for them, but have flown ClearNav for three seasons and it is as "sunlight- readable" as it needs to be. No problem viewing it on bright days while wearing sunglasses. My problem is fine print in any light condition so I keep glasses handy for that, but if you set it up correctly before flight there is little need to read fine print. No need to flip through multiple pages, either. Control inputs are through a simple controller that you don't have to look at to use - particularly if it's mounted on the stick. Power management is built into the system so that isn't a problem. |
On Nov 16, 8:44*am, Bill D wrote:
On Nov 15, 6:17*pm, John Cochrane wrote: On Nov 15, 3:57*pm, JohnDeRosa wrote: On Nov 15, 10:54*am, Bill D wrote: Qualcom's Mirasol display looks like a magazine cover in direct sunlight. And at 1/10th the power requirements. *Important for gliders but this will also really impact battery life for everything from laptops, tablets to cell phones. I hate to break it to you guys, but there is a gorgeous sunlight readable display on the market, the clear-nav. SN10 is pretty easy to read too, but offers less stuff on the screen, which Dave might argue is an advantage. No need to wait... John Cochrane Don't think so. Current engineering specs say 1500 nits brightness is required for 'good' readability in direct sunlight. *CCFL's backlights delivering that brightness would pull amps, not mili-amps. *LED backlights are better but current draw and heating are still problems. *If you did somehow create a screen with 1500 nits brightness, it would be like looking into a car headlight. I can't find the specs, but I'm guessing the best glider displays are in the 500 - 1000 nit brightness range and pull around .8 amps. Far easier on the eyes and battery would be a high-contrast, high color saturation REFLECTIVE display like the Mirasol technology. Bill, I am not sure where you got your engineering specifications. But I have found that display brightness in an aircraft quality display has little to do with sunlight readability. The key factors are the coatings and the contrast ratio. The Ultimate Le has two specialized coatings and an extremely high contrast ratio, it is as readable in the sun at the low backlight settings as in the high backlight. The sun has no noticable effect on the Ultimate Le display. The Ultimate Le with LED backlight has no heat problems. In fact the first Ultimates with a CFFL backlight got warm but did not have any issues. Displays with low contrast ratios need unusaully high backlight to be seen. This is typical of most low cost low qualtiy displays. The Ultimate Le at full backlight has 1400 nits and draws about .7 to .8 Amps. At lower backlight settings of .3 to .4 amps the display is very sunlight viewable with vibrant colors. All the above information comes from testing in direct sunlight from a varitey of angles and first hand experience in flight. Richard www.craggyaero.com |
Trying again: Collings Foundation B-17 at Newcastle Airport inDelaware - B-17 cockpit.jpg - B-17 cockpit.jpg (1/5) | Jim Breckenridge | Aviation Photos | 1 | August 30th 08 07:36 PM |
Trying again: Collings Foundation B-17 at Newcastle Airport in Delaware - B-17 cockpit.jpg - B-17 cockpit.jpg (0/5) | Go-dot | Aviation Photos | 0 | August 28th 08 11:39 PM |
Wings of Freedom B-17 Wilmington, DE - B-17 cockpit.jpg - B-17 cockpit.jpg (1/5) | Waldo.Pepper[_2_] | Aviation Photos | 0 | August 28th 08 10:31 PM |
Cockpit weather display question | Chip Jones | Instrument Flight Rules | 6 | July 21st 04 01:07 PM |
Cockpit weather display question | Chip Jones | Piloting | 6 | July 21st 04 01:07 PM |
