fudog50 wrote
IIRC, the only indicator that had both pitot and static inputs was the VSI/Rate of climb indicator and the internal bellows in the gauge performed the differential action. Airspeed has pitot inputs only. Baro Alt. has static port input only. Wish I could draw you a diagram on here, it would explain everything. Ummmm.....I think that you definately DO NOT recall correctly! Static Pressure feeds Altimeter, Airspeed, and VSI. Pitot Pressure feeds only Airspeed. The Pitot Pressure from the Pitot Tube is a combination of Static and RAM pressure. The bellows inside the airspeed indicator uses the ambient static pressure from the static port to cancel out the static component from the Pitot Tube leaving only the RAM component to move the airspeed needle. Bob Moore |
![]() "Robert Moore" wrote in message . 7... fudog50 wrote IIRC, the only indicator that had both pitot and static inputs was the VSI/Rate of climb indicator and the internal bellows in the gauge performed the differential action. Airspeed has pitot inputs only. Baro Alt. has static port input only. Wish I could draw you a diagram on here, it would explain everything. Ummmm.....I think that you definately DO NOT recall correctly! Static Pressure feeds Altimeter, Airspeed, and VSI. Pitot Pressure feeds only Airspeed. The Pitot Pressure from the Pitot Tube is a combination of Static and RAM pressure. You remember wrong, as usual, Bob. IAS is one pressure subtracted from the other. Since the 1960s, large airliners have used a pitot port and a static port. The Bombardier GBX being a notable exception to modern pitot/static systems, with it's prominent nose boom and pitot tube. |
On Thu, 26 Feb 2004 13:23:52 -0800, "Tarver Engineering"
wrote: "Robert Moore" wrote in message .7... fudog50 wrote IIRC, the only indicator that had both pitot and static inputs was the VSI/Rate of climb indicator and the internal bellows in the gauge performed the differential action. Airspeed has pitot inputs only. Baro Alt. has static port input only. Wish I could draw you a diagram on here, it would explain everything. Ummmm.....I think that you definately DO NOT recall correctly! Static Pressure feeds Altimeter, Airspeed, and VSI. Pitot Pressure feeds only Airspeed. The Pitot Pressure from the Pitot Tube is a combination of Static and RAM pressure. You remember wrong, as usual, Bob. IAS is one pressure subtracted from the other. Which is exactly what Robert said in the bit you snipped. To wit: "The bellows inside the airspeed indicator uses the ambient static pressure from the static port to cancel out the static component from the Pitot Tube leaving only the RAM component to move the airspeed needle." Since the 1960s, large airliners have used a pitot port and a static port. Please provide one reference for this. The Bombardier GBX being a notable exception to modern pitot/static systems, with it's prominent nose boom and pitot tube. Ok...So a pitot tube only exists on a nose boom? And Bombardier GBX? Are you referring to the Bombardier Global Express? It's the closest I can find on their web site. If so I can't see a prominent nose boom in the pictures there. Car to enlighten me? Phil -- Great Tarverisms #7 Pitot: French word meaning tube. John alt.disasters.aviation 25 February 2002 |
![]() "Phil Miller" wrote in message ... Robert is being rediculess to claim that a pitot tube produces some total pressure and then the static port pressure is subtracted twice to make IAS. The whole point of using a static port is to be able to take the guts out of a pitot tube and produce only pitot pressure, thus increasing the reliability of the system. Perhaps this will help: "Tarver Engineering" wrote: "Gord Beaman" wrote in message .. . "Jim Knoyle" wrote: Hang on here a second now Jim, you still need two samples. As Dan says you need 'static pressure' to read the altitude from and you need 'pitot pressure' (ram air pressure) as well as the static pressure to derive the airspeed reading from. Sounds like you're saying that you can read 'both' from just the 'ram air pressure' alone. Or did I misunderstand you? Jim has finally figued out what a pitot tube is, but somehow he still wants to be correct in his archive troll. It is a great paradox. I know...ain't life a bitch John ![]() ![]() -- -Gord. |
On Thu, 26 Feb 2004 19:25:26 -0800, "Tarver Engineering"
wrote: "Phil Miller" wrote in message .. . Robert is being rediculess to claim that a pitot tube produces some total pressure and then the static port pressure is subtracted twice to make IAS. The whole point of using a static port is to be able to take the guts out of a pitot tube and produce only pitot pressure, thus increasing the reliability of the system. Perhaps this will help: Yes that does help, because what Robert said and what Gord said are practically identical. "Gord Beaman" wrote in message . .. Hang on here a second now Jim, you still need two samples. As Dan says you need 'static pressure' to read the altitude from and you need 'pitot pressure' (ram air pressure) as well as the static pressure to derive the airspeed reading from. On Thu, 26 Feb 2004 21:06:41 GMT, Robert Moore wrote: The Pitot Pressure from the Pitot Tube is a combination of Static and RAM pressure. The bellows inside the airspeed indicator uses the ambient static pressure from the static port to cancel out the static component from the Pitot Tube leaving only the RAM component to move the airspeed needle. Phil -- Great Tarverisms #2 What is the best selling beer in Oz? Budweiser. Another illusion shattered. John alt.disasters.aviation 18 August 2002 |
On Fri, 27 Feb 2004 14:33:43 +1100, Phil Miller
wrote: On Thu, 26 Feb 2004 19:25:26 -0800, "Tarver Engineering" wrote: "Phil Miller" wrote in message . .. Robert is being rediculess to claim that a pitot tube produces some total pressure and then the static port pressure is subtracted twice to make IAS. The whole point of using a static port is to be able to take the guts out of a pitot tube and produce only pitot pressure, thus increasing the reliability of the system. Perhaps this will help: Yes that does help, because what Robert said and what Gord said are practically identical. Oh! And you didn't enlighten me about the Bombardier GBX? Phil -- Great Tarverisms #1 The Air Speed Indicator (ASI) shows You made that up, didn't you? The IAS indicator says IAS, not ASI. Why do you come here pretending to know something when you don't even know the words? John |
Robert Moore wrote:
The Pitot Pressure from the Pitot Tube is a combination of Static and RAM pressure. The bellows inside the airspeed indicator uses the ambient static pressure from the static port to cancel out the static component from the Pitot Tube leaving only the RAM component to move the airspeed needle. Bob Moore Of course...exactly...not rocket science after all... -- -Gord. |
![]() "Gord Beaman" wrote in message ... Robert Moore wrote: The Pitot Pressure from the Pitot Tube is a combination of Static and RAM pressure. The bellows inside the airspeed indicator uses the ambient static pressure from the static port to cancel out the static component from the Pitot Tube leaving only the RAM component to move the airspeed needle. Of course...exactly...not rocket science after all... Not even close. Moore is making the same dumbass claim as Knoyle. The sole reason for using a static port is so the guts can be removed from the pitot tube, in order to improve reliability. A pitot port produces no static pressure datum. Perhaps this will help: "Tarver Engineering" wrote: "Gord Beaman" wrote in message .. . "Jim Knoyle" wrote: Hang on here a second now Jim, you still need two samples. As Dan says you need 'static pressure' to read the altitude from and you need 'pitot pressure' (ram air pressure) as well as the static pressure to derive the airspeed reading from. Sounds like you're saying that you can read 'both' from just the 'ram air pressure' alone. Or did I misunderstand you? Jim has finally figued out what a pitot tube is, but somehow he still wants to be correct in his archive troll. It is a great paradox. I know...ain't life a bitch John ![]() ![]() -- -Gord. |
Tarver Engineering wrote:
The sole reason for using a static port is so the guts can be removed from the pitot tube, in order to improve reliability. A pitot port produces no static pressure datum. Just as an example, when the aircraft is sitting still on the ground - airspeed = 0. Since the pitot and static ports are in the same state, doesn't that imply that static pressure is present at the pitot port? MAH |
mah wrote:
Tarver Engineering wrote: The sole reason for using a static port is so the guts can be removed from the pitot tube, in order to improve reliability. A pitot port produces no static pressure datum. Just as an example, when the aircraft is sitting still on the ground - airspeed = 0. Since the pitot and static ports are in the same state, doesn't that imply that static pressure is present at the pitot port? MAH Sure it's there, but it's there only until the a/c starts to move. It's then no longer 'static pressure' because it's been raised by the ram effect of the movement. That's why you now need a 'static port' to supply the static pressure to use as a reference. Is it really that difficult to see?!? -- -Gord. |
Fine example of Tarver Engineering release for service | running with scissors | Instrument Flight Rules | 64 | March 3rd 04 05:01 AM |
Fine example of Tarver Engineering release for service | running with scissors | Instrument Flight Rules | 7 | February 28th 04 05:07 PM |
To Tarver Engineering | fudog50 | Military Aviation | 2 | January 9th 04 07:15 PM |
About death threats and other Usenet potpourri :-) | Dudley Henriques | Military Aviation | 4 | December 23rd 03 07:16 AM |
FS: Aviation History Books | Neil Cournoyer | Military Aviation | 0 | August 26th 03 08:32 PM |
