... Unless you were previously filling your tires with helium, there isn't much to be gained on diffusion by this change. But using helium filled tires ensures squeaky landings! I suppose you can use grease filled tires too, but it's a lot heavier and not good for the rubber. =D Eric |
Manifold pressure gauge problem | Dave Russell | Aerobatics | 3 | January 29th 04 03:46 AM |
Nosewheel Shimmy and Scalloped Tire Redux, Plus | Larry Smith | Home Built | 2 | September 15th 03 04:03 PM |
Scalloped Nosewheel Tire | Larry Smith | Home Built | 7 | September 12th 03 09:16 PM |
Fuel pressure Problems | smf | Home Built | 3 | September 7th 03 08:25 PM |
Pressure Differential in heat Exchangers | Bruce A. Frank | Home Built | 4 | July 3rd 03 05:18 AM |
