CIA Vietnam war controlled USAF aircraft missions
Old February 28th 04, 01:43 PM
BUFDRVR
Those Vark pilots would have a heck of a time operating the weapons panel on
the right.
How about the Phantom pilot operating the *rear seat* equipment?
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips
everyone on Bear Creek"
Old February 28th 04, 02:13 PM
Yeff
the right.
You know, if I wanted to covertly spy on someone's house, the first thing
I'd do is paint my car black. If I wanted to covertly hide out from the US
government I'd paint my house black. Apparently, if you're going to do
something covertly the first thing you do is paint everything black so no
one has any illusions that you aren't covert.
-Jeff B.
yeff at erols dot com
Old February 28th 04, 02:55 PM
Smartace11
the right.
In 1972, I flew night triple turn missions out of Tahkli - one sortie out of
Tahkli in Laos, N and S Vietnam recover at Danang, reload/rearm, do it again,
recover at Danang and do it again then go home. Occaisionally we recovered at
Udorn because it was closer than Danang when we were operating in nothern Laos
around the PDJ.
I saw an black F-4s once at Udorn taxi past the dearm area when I recovered
there one night. Couldn't tell how many crew members. Maybe not black but one
dark color all over - the camo paint scheme was visible at night in that
scenario once you got some night vision and had the fuselage belly lights on
for the weapoins guys to pin you back up. The F-4 could be operated by one
crewmember - the INS just had to be aligned before taxi. Dropping nukes was
about the only thing that supposedly couldn't be done alone though I guess one
could enable the PAL stuff on the ground before TO.
There were also rumors floating around of the existance of the black F-4s but
few had actually seen them. Never heard anything about F-111s though the
F-111As out of Nellis that replaced us could have flown that mission.
When we worked at night in Laos we were usually under the control of a Nightowl
FAC, an F-4 Fast FAC with Loran and plenty of flares. Once in a while we
worked with a Raven but I have no idea what type of aircraft, their usual O-1
or something else. Sometimes a Specter on the trails would control us. Very
few times, Moonbeam the ABCCC ship wold turn us over to the Combat Skyspot guys
to drop from their ground radar.
Working in Laos at night was spooky. Like flying inside an ink bottle as there
was just a campfire here and there and few if any other lights on the ground.
Little or no horizon under the haze. The FAC would lay down a "log" that
burned on the ground for a while and we would attempt to use it as an aiming
point. Hard enough to gage "100 meters north of my smoke" in the daytime but a
real trick at night.
Definitely enjoyed night flying as there was little or no adult supervision
around. Plus it was a helluva lot cooler. Doubtless, the missions were in
support of the Lima recon sites there and possibly the BMT TACAN though it had
been overrun when I was there..
Steve
Old February 28th 04, 03:41 PM
Howard Berkowitz
Yhere certainly were covert military flights in Southeast Asia, but the
were not necessarily controlled by CIA. For the cases we know that were
controlled by CIA, such as Air America, there's no indication that the
crews were reduced.
Black aircraft aren't implausible for agent dropping and such, but these
would be most likely to be under the operational control of MACSOG.
Transports, of course, would be the likely aircraft in this role.
There were covert operations such as the bombing of Laos, or the weather
modification flights of Operation Popeye, but, while classified (perhaps
improperly), they were performed by the regular military chain of
command.
My reading of the Pentagon Papers suggests no combat aircraft were under
direct CIA control, although CIA operational people could certainly ask
for, and get support. Sedgwick Tourson's book on agent infiltration in
the north clearly speaks of the aircraft being military.
Old February 28th 04, 05:15 PM
Smartace11
I think it would be called under operational control by the military in support
of CIA ops.
Per a friend who flew A-26s early on and did a few drops of agents in the North
out of the bomb bay. His flight plan showed a slight delay in the arming area
with the bay doors open while a little guy in a black suit and chute climbed
into the bomb bay, then a place on the map were the doors were to be opened
enroute then closed, while over indian country.
command.
Old February 28th 04, 04:40 PM
Aerophotos
bingo you are spot on see it has happened...everyhting you said below
reminds me of the story the guy told me, he said i rember now INS was
set but thats all that was needed...
the right.
around the PDJ.
Steve
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
