#51
OLC and Cambridge 10/20/25 support ending
On Dec 11, 11:11*pm, Max Kellermann wrote:
You're right by saying it's an illusion, but I strongly disagree that a server-side service is a viable solution. What if you don't have internet access? What if the server is down? What if the server is commercial (like the OLC), and I object to use that? Please note that this thread is entitled "OLC and Cambridge 10/20/25 support ending", and that it is quite hard to use the OLC without at least occasional access to the internet, and some amount of willingness to put up with OLC policies. This problem is not something that should put Cambridge owners in a dependency situation on one entity. *This problem can be solved with a free tool that does not require internet connection, and that does not require this kind of dependency. *If such a solution is possible, it should be done that way. The owners of every approved flight recorder, so far, are each dependent on the manufacturer of their flight recorder, nothing is different here. Validation source code has never been publicly released for any approved flight recorder, although that might well change some day. In any case, usable validation source code for the GPS-NAV can never be released, as it does not use public key cryptography. If this can technically only be achieved by storing the whole verbatim Cambridge file (including the verbatim signature; using base64?) in the IGC file, then be it so. *It's not 1995 anymore, and inflating the IGC files is the lesser evil. That can be done, and then what? At the other end, you'd need to extract the embedded CAI file, and run VALI-CAM.exe followed by CONV- CAM.exe to be certain of getting the valid IGC file. It would be simpler to submit the original CAI file in the first place... Marc |
#52
Marc wrote:
The owners of every approved flight recorder, so far, are each dependent on the manufacturer of their flight recorder, nothing is different here. The difference is that Cambridge cannot revoke my rights to use my logger, but an online service can do that at any time. I have to permanently agree to the server's terms of service to use it, while I don't have to agree to anything to use my logger. This is a huge difference. Maybe not for you, but I care a lot about such things that may potentially limit my freedom. Validation source code has never been publicly released for any approved flight recorder, although that might well change some day. In any case, usable validation source code for the GPS-NAV can never be released, as it does not use public key cryptography. Which means that a key that can generate "valid" CAM files is already disclosed to the public. How will your proposed server-side solution address that problem? How will your server identify tampered CAM files? That can be done, and then what? At the other end, you'd need to extract the embedded CAI file, and run VALI-CAM.exe followed by CONV- CAM.exe to be certain of getting the valid IGC file. I was looking forward to a solution that may include a free VALI-CAM program which could be embedded in my own software, but sadly that is a pipe dream. I hope this dream comes true one day for a logger. For this to come true, pilots should express this wish, which I hereby do (or, better, I try to convince other pilots of the advantages of free validation procedures). It would be simpler to submit the original CAI file in the first place... The CAI-inside-IGC approach has the advantage that any software may evaluate the flight without having to implement another (proprietary) file format. But yes, uploading the verbatim CAI binary file instead of IGC is another interesting approach that could be considered. Again, that would require that this proprietary format is made open. Max |
#53
On Dec 12, 12:59*am, Max Kellermann wrote:
Westbender wrote: I haven't gotten that far yet. I don't think there's any reason why the source code can't be released, although I don't know why that would be important. For people who don't run 32 bit Windows on an Intel CPU. For people who don't to run "untrusted" closed-source software. Practical example: I want to download and verify the flight from the Cambridge with my Streak running Android. *The Streak has an ARM CPU, so even if I wanted and even if Windows would run on it, there would be no chance to use your DLL. *None of my computers runs Windows, anyway. The majority of devices sold currently have an Intel CPU, and the majority of devices sold currently don't run Windows. If you're not convinced that disclosing and freeing the source code is important, I can elaborate more. Max Downloading a flight from a Cambridge 10/20/25 has nothing to do with this effort. I am not proposing that, nor am I trying to solution that. If you're talking about the cai 2 igc conversion process, that is being done by leveraging the existing vali-cam and conv-cam utilities from Cambridge. They are currently limited as to what OS they will run on. I also am not trying to solution any alternatives for that. I am only trying to provide a solution for 10/20/25 owners to be able to continue posting their flights on the OLC....period! If that means it's bound by the same OS limitations that has been in place up to today for these loggers, then so be it. A limited means is better than no means. Let's not try to make a mountain out of a mole hill. |
#54
Westbender wrote: I haven't gotten that far yet. I don't think there's any reason why the source code can't be released, although I don't know why that would be important. For people who don't run 32 bit Windows on an Intel CPU. For people who don't to run "untrusted" closed-source software. Practical example: I want to download and verify the flight from the Cambridge with my Streak running Android. *The Streak has an ARM CPU, so even if I wanted and even if Windows would run on it, there would be no chance to use your DLL. *None of my computers runs Windows, anyway. The majority of devices sold currently have an Intel CPU, and the majority of devices sold currently don't run Windows. If you're not convinced that disclosing and freeing the source code is important, I can elaborate more. Max I'm willing to bet that a vast majority of 10/20/25 owners would be happy to have a new (free) windows-based utility to enable them to continue posting their flights on the OLC. Untrusted? Sure, you could say that. Would a flood of apps built by every Tom, Dick and Harry from open source be any more trusted? Absolutely not! |
#55
On Dec 11, 8:43*pm, Marc wrote:
*Personally, I don't understand why the OLC even bothers validating the files, it's extra work for them, and it's not like anyone is winning anything except some bragging rights. Better that all involved understand that it is possible to produce fake IGC files, and shun those who are caught doing so. I think we all agree on that. It is unclear to me why OLC still insisting on the security record. After all, unsecure loggers such as PDA are allowed, so it is not like they are protecting logger manufactures. And the security is obvioulsy an illusion, there are many ways to fake scores on OLC if someone care so much about their bragging rights. Flights are scored wrongly all the time, usually unintentionally. If the OLC team does not realize this, it is time to pull their heads out of their ass. Problem is, they probably don't care to follow complains on RAS, so I would expect perhaps the US-OLC Committee to step up to address OLC issues. The SSA web site is listing one person in the OLC committee but I haven't seen any OLC related comments from him. As for the Cambridge issue, the only pilots I know which were still downloading flights from model 20 loggers are flying selflaunchers which can not use PDA generated igc file due to missing ENL record. So my question is why PDAs do not record ENL, either using the ENL data from the logger if transmitted, or using the PDA mic? Ramy |
#56
Westbender wrote:
I'm willing to bet that a vast majority of 10/20/25 owners would be happy to have a new (free) windows-based utility to enable them to continue posting their flights on the OLC. The vast majority of owners want a solution now, but choosing the best technical solution often isn't a popularity contest. You would win that bet, but your bet doesn't matter - Cambridge owners now want a solution that works now, and today they do not care about the problems they will face in a few years. Just like in 1996 they didn't care yet about the problems they face today. I see it as our responsibility (we = hackers like you and me) to ensure that the next time, the problem doesn't exist. Untrusted? Sure, you could say that. Would a flood of apps built by every Tom, Dick and Harry from open source be any more trusted? Absolutely not! That kind of suggestive rhethoric is dull. What does Tom, Dick and Harry have to do with this? From your point of view, you are the most trustworthy person in the world. But that is just your point of view. From my point of view, you are not, because I don't know you. From my point of view, all open source developers are more trustworthy than you, because I can verify that their programs are free of malware. And I often do. Max |
Similar Threads | ||||
NK Now Offering Support for Legacy Cambridge Products | Paul Remde | Soaring | 1 | July 16th 08 10:12 PM |
Bushite soldiers beat to death innocent Children to 'let offsteam' - Support Our Demands For Open Communications - Unraveling the Mystery- you can not find a single soldier on Earth to publicly support GeorgeW Bush without immediately being re | Tiger | Naval Aviation | 0 | April 10th 08 01:20 AM |
OLC-Posting flights ending after 2400UT | Go | Soaring | 1 | April 2nd 06 12:32 PM |
Yokota airmen deployment ending | Otis Willie | Military Aviation | 0 | September 2nd 04 09:45 PM |
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 | Nathan Whelchel | Soaring | 4 | July 5th 04 11:22 PM |
