You're fortunate that you live in the U.K.; a tiny country with a lot
of gliders. This means you have a lot more choice and it'll be pretty easy to go look at quite a few gliders. If you're primary interest is winning club class competitions then you should look at what glider most commonly wins and buy one of those (yes, I know that handicapping theoretically means every glider should be equal but..) After that you can read Derek Piggott's recommendations and Dick Johnson's Flight Test Evaluations for some guidance ( they're all on the SSA website but you need a membership to access them, the Standard Cirrus B test is available at standardcirrus.org) Find out which ships you fit in comfortably. As I said above this should be easy for you as examples of every type you listed will likely be present at a club not too far away from you. One of the reasons I didn't buy a Libelle was that I found it too cramped across the shoulders. A lot of people in my club wouldn't fly the Standard Jantar we had because they found it too uncomfortable. You never really know until you try one on for size. The condition of the glider, particularly the finish is really important. This applies both to the actual performance (as opposed to the performance measured when new) and to future maintenance and resale costs. As to specific gliders I can speak about the Standard Jantar, ASW-15B and ASW19/19B from personal experience. Standard Jantar: The cockpit is long but not too wide (having long arms is a plus for Jantar pilots). It has a fairly high wing loading even without water ballast. The landing gear handle can be awkward to operate as it has to be moved quite far back and your elbow may have trouble fitting between your ribcage and the cockpit side if you're average height. It stalls and spins quite sharply but recovers quickly (at least our Standard 1 did and it's the only one I've flown). Visibility is alright but not great. The large panel and forward canopy frame restrict things a bit (doesn't apply to the 3 of course). Airbrakes are more than adequate. Rigging is not too bad. They were smart enough to provide pins on top of the spars and a lever to fit on them and pull the wings together just like a Libelle. As far as I'm concerned EVERY glider that uses a single main pin and cantilevered pins on the spar ends which fit into bearings in the opposing wing roots should have this. I curse Grob's engineers every time I have to deal with one of the club Astirs because they didn't do this and it makes things much much harder than they should be. ASW-15B: (what I currently own and fly) Adequately roomy cockpit for me (5 ft. 10 and 170lbs.) but not as roomy as the ASW-19 or Cirrus. Very docile stall spin characteristics, extremely strong airbrakes (flying at a gross weight of 730 lbs., full airbrakes and a 50 degree dive doesn't even get me to maneuvering speed) and it can come down fast using a forward slip (I routinely do spot landings without using the airbrakes at all). Climbs really well but won't penetrate like a 19 or Jantar unless it's loaded with water. With the forward hook and large rudder aerotow is easy. I've never used the offset C of G hook. Rigging is easy. The aileron and airbrake connections are easily accessed and SEEN through the top hatch and the elevator is automatic. The all flying tail is well designed and doesn't make the glider twitchy at all. Nice, light and responsive ailerons with little friction. Technical and parts support has been good too. The large single piece removable canopy is a bit of a pain though. I live in Canada so a huge factor in my deciding what to buy was the location of the glider. The fact that the 15 I bought wasn't 3000 miles away or in another country was a major point in it's favor. There's only about 600 gliders in the whole country and the majority of them are on the other side of the continent from me. That's not a problem you're going to have though. If I were in your place I'd probably go for an ASW-19 or 19B. Most of the good points of the 15 plus a bigger cockpit, better penetration and more convenient canopy opening mechanism. The airbrakes aren't as strong (even with the double blades), the control access hatch is a bit smaller and the elevator isn't automatic but that's about it for downsides. It looks beautiful and flies beautiful. |
On Dec 14, 6:08*am, Hagbard Celine wrote:
You're fortunate that you live in the U.K.; a tiny country with a lot of gliders. This means you have a lot more choice and it'll be pretty easy to go look at quite a few gliders. If you're primary interest is winning club class competitions then you should look at what glider most commonly wins and buy one of those (yes, I know that handicapping theoretically means every glider should be equal but..) snip In the UK that would probably mean flying whatever G Dale flies! You might find some of Derek Pigott's reports online: http://www.lakesgc.co.uk/mainwebpage...gmagazines.htm However I don't think the archive is indexed, so it might take a lot of time and dedication to find them. |
At 18:15 14 December 2011, Cats wrote:
On Dec 14, 6:08=A0am, Hagbard Celine wrote: You're fortunate that you live in the U.K.; a tiny country with a lot of gliders. This means you have a lot more choice and it'll be pretty easy to go look at quite a few gliders. If you're primary interest is winning club class competitions then you should look at what glider most commonly wins and buy one of those (yes, I know that handicapping theoretically means every glider should be equal but..) In the UK that would probably mean flying whatever G Dale flies! You might find some of Derek Pigott's reports online: http://www.lakesgc.co.uk/mainwebpage...gmagazines.htm However I don't think the archive is indexed, so it might take a lot of time and dedication to find them. Gee Dale flies a DG100/101? -sold his ASW24 for it has stated at the start of this thread! Wish we could leave all this advice trailers ect and focus on the strength and weaknesses of the individual ships mentioned for CLUB CLASS competition! Thanks for those that have done so. |
Some of the older (101) Pegs have a self-connecting elevator, which is
a feature that's well worth having. AFAIK it was a feature added towards the date when they switching to the 90. It also never surprises me that I fit them (5'3") as does a friend who is 12" taller. I don't have the seat back right forward, he takes it out and wears light-weight shoes. At my height with slightly short legs poportionately, I get a great view - the back of the canopy is after of my head, and I can just about make out the tailplane of the glider. However I've helped enough people with dodgy trailers and rigging aids to agree that the condition of the trailer comes first. You can make rigging aids if necessary - for example the chap with an Asir and no wing root dolly made one as soon as we had used mine to help rig his glider. He was a very tall guy so without one was having to stoop to avoid banging the trailing edge on the top of the trailer door frame, and yes - I think he had a bad back! |
Trailer? 20-30 minutes to rig and 5-6 hours to fly. I'd rather have a
comfortable glider! (Fortunately, I have both... LAK-17a and LAK T5 trailer) ;-) "Cats" wrote in message ... Some of the older (101) Pegs have a self-connecting elevator, which is a feature that's well worth having. AFAIK it was a feature added towards the date when they switching to the 90. It also never surprises me that I fit them (5'3") as does a friend who is 12" taller. I don't have the seat back right forward, he takes it out and wears light-weight shoes. At my height with slightly short legs poportionately, I get a great view - the back of the canopy is after of my head, and I can just about make out the tailplane of the glider. However I've helped enough people with dodgy trailers and rigging aids to agree that the condition of the trailer comes first. You can make rigging aids if necessary - for example the chap with an Asir and no wing root dolly made one as soon as we had used mine to help rig his glider. He was a very tall guy so without one was having to stoop to avoid banging the trailing edge on the top of the trailer door frame, and yes - I think he had a bad back! |
Potential Club Class (US Sports Class) World Team Selection Policy Changes | John Godfrey (QT)[_2_] | Soaring | 84 | September 27th 10 08:03 PM |
Potential Club Class (US Sports Class) World Team SelectionPolicy Changes | JS | Soaring | 4 | September 22nd 10 04:55 PM |
Potential Club Class (US Sports Class) World Team SelectionPolicy Changes | Andy[_10_] | Soaring | 0 | September 19th 10 10:33 PM |
Club Class vs. Sports Class | noel.wade | Soaring | 28 | September 25th 08 02:52 AM |
UK Open Class and Club Class Nationals - Lasham | Steve Dutton | Soaring | 0 | August 6th 03 10:07 PM |
