Source of RJ-45 cables for connecting FLARM, K6 Mux, etc.
I'm curious about the type of RJ-45 cable needed to connect
various .icg-compliant glider instruments, such as a PowerFLARM, K6 Mux, PNA, etc.. First, are the RJ-45 cables (assuming no special connectors or requirements, just power and data) straight through or crossed? Second, can regular Cat 6 Ethernet cables be used, or do they have to be shielded? Some of the prices I've seen for what appear to be straight RJ-45 patch cables at glider equipment dealers are a bit breathtaking compared to computer cable stores so I'm wondering if I've missed something! Any advice would be appreciated. Kirk 66 |
On Dec 9, 4:25*pm, "kirk.stant" wrote:
I'm curious about the type of RJ-45 cable needed to connect various .icg-compliant glider instruments, such as a PowerFLARM, K6 Mux, PNA, etc.. First, are the RJ-45 cables (assuming no special connectors or requirements, just power and data) straight through or crossed? Second, can regular Cat 6 Ethernet cables be used, or do they have to be shielded? Some of the prices I've seen for what appear to be straight RJ-45 patch cables at glider equipment dealers are a bit breathtaking compared to computer cable stores so I'm wondering if I've missed something! Any advice would be appreciated. Kirk 66 Kirk, here is some info I shared on the xcsoar mailing list for connecting 302 to Dell Streak via K6Bt. You may find some answers the Parts: Outerbox impact cover (optional) http://www.amazon.com/OtterBox-Dell-.../dp/B004MG3OTW ($10) Slipgrip Mount (few options to choose from) - http://www.slipgripcarmounts.com/Usi...e_c_21746.html ($40) K6BT - http://www.cumulus-soaring.com/k6.htm ($175) DB9 Male to RJ45 Modular Adapter - http://www.amazon.com/gp/product/B0016RO20U ($4) Extra Dell Streak cable - http://www.amazon.com/gp/product/B005AL36SW ($9 incl shipping) 2 x Network Cable - http://www.amazon.com/gp/product/B000V0ET92 ($2 each) Instructions: 1 - Insert the RJ45 pins into the DB9 modular adapter according to the following: Red to pin2 Black to pin3 blue to pin5 brown to pin6 white to pin8 (the rest can go anywhere) 2 - Connect a netwrok cable between the K6Bt and the above DB9 adapter. This will provide power and communication to the K6Bt. 3 - Velcro the K6Bt to the 302, and follow the instructions that came with the K6Bt to pair with the Streak, then select the K6Bt device in XCSoar and the CAI 302 driver. 4 - The above should be sufficient for up to 5 hours flight. If you need longer than that, follow the instructions below to connect the 5v to charge the Streak. 5 - Cut the Streak Cable and the other network cable. 6 - Carefully solder pin 1 from network cable (White/orange) to the Streak cable black wire (GND) , and pin 8 from the network cable (brown) to the Streak red wire (+5). 7 - Connect this cable between the other K6Bt connector and the Streak to charge the Streak in flight. Hope this helps, Ramy |
On 10 Dez., 01:25, "kirk.stant" wrote:
I'm curious about the type of RJ-45 cable needed to connect various .icg-compliant glider instruments, such as a PowerFLARM, K6 Mux, PNA, etc.. First, are the RJ-45 cables (assuming no special connectors or requirements, just power and data) straight through or crossed? Second, can regular Cat 6 Ethernet cables be used, or do they have to be shielded? Some of the prices I've seen for what appear to be straight RJ-45 patch cables at glider equipment dealers are a bit breathtaking compared to computer cable stores so I'm wondering if I've missed something! Any advice would be appreciated. Kirk 66 You can basically use any RJ-45 patch kabel except for the crossed ones. As far as my experience goes it is not necessary to get a shielded kabel (CAT 5 and 6). |
The problem with using "computer" cables is that they would be much
too long for most soaring applications - not to mention that putting the connectors on with the wires in the right order is a pain in the @# $%. Making your own flat cables is simple and inexpensive - not to mention that you can make it exactly the length that you need. 1) "silver satin" 8 conductor flat cable http://www.amazon.com/IEC-Gauge-Cond...838509&sr=8-17 2) 8 conductor RJ-45 connector http://www.radioshack.com/product/in...ductId=2292431 3) RJ-45 Crimping/stripping tool http://www.radioshack.com/product/in...ductId=2255112 The sources I show above are ones that are likely to be viewable in the months ahead. But you can find all of this on eBay for cheap. NOTE: Every soaring cable I have seen is "straight through" - that is, if you hold the two ends next to one another the colored wires are in the same order. YMMV. - John |
On Dec 13, 11:07*pm, JohnDeRosa wrote:
The problem with using "computer" cables is that they would be much too long for most soaring applications - not to mention that putting the connectors on with the wires in the right order is a pain in the @# $%. Making your own flat cables is simple and inexpensive - not to mention that you can make it exactly the length that you need. 1) "silver satin" 8 conductor flat cablehttp://www.amazon.com/IEC-Gauge-Conductor-Silver-Satin/dp/B003U42NPS/... 2) 8 conductor RJ-45 connectorhttp://www.radioshack.com/product/index.jsp?productId=2292431 3) RJ-45 Crimping/stripping toolhttp://www.radioshack.com/product/index.jsp?productId=2255112 The sources I show above are ones that are likely to be viewable in the months ahead. *But you can find all of this on eBay for cheap. NOTE: Every soaring cable I have seen is "straight through" - that is, if you hold the two ends next to one another the colored wires are in the same order. YMMV. - John One last question - and I'm showing my complete ignorance here - are all the pins on a "standard" RJ45 cable hot? And is there any problem sending 12v across them to power a K6 Mux and a PowerFLARM, for example? Kirk 66 |
On Dec 15, 7:39*pm, "kirk.stant" wrote:
On Dec 13, 11:07*pm, JohnDeRosa wrote: NOTE: Every soaring cable I have seen is "straight through" - that is, if you hold the two ends next to one another the colored wires are in the same order. YMMV. - John One last question - and I'm showing my complete ignorance here - are all the pins on a "standard" RJ45 cable hot? And is there any problem sending 12v across them to power a K6 Mux and a PowerFLARM, for example? Actually you had two questions 1) Hot usually indicates that they have a voltage on them that isn't zero. Is that what you mean? Or do you just mean if all the pins are connected one end to the other? The answer to the last question is yes for a flat cable and almost always yes for a computer networking cable. 2) Sending 12v across this cable isn't really what you need to understand. The question is how much current you need to run across the wires in the cable. Do you know? (hint: read the equipment specs) Current carrying capacity depends on the gauge of the wire - and the larger the gauge the more current carrying capacity the wire can handle. Too much current for the gauge and the wire gets hot and the insulation melts - not good. These flat telephone cables are in all probability 26ga which is about as small as you are likely to encounter short of the wiring inside a pair of ear buds. There is a chart which explains everything in FAA AC 43.12-1B, Chapter 11, Section 5, Page 11-30 and 31 - but it only goes down to 24ga (bigger number = smaller gauge). Here is the link; http://rgl.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGADVISORYCIRCULAR.NSF/0/99c827db9baac81b86256b4500596c4e/$FILE/Chapter%2011.pdf If I read the chart correctly 24ga is good to 5amps at 14V for 8 ft with a 1Vdc drop. Someone check my math. But would I run power through itty-bitty 26ga wire, let alone several amps? Nope. Signals yes, power no. Stick with tefzel. My $0.02. - John |
Similar Threads | ||||
Connecting lap top to CAI 302 | apsoars | Soaring | 10 | June 8th 11 03:24 PM |
Flarm collision avoidance protocol or an 'open source' one? | [email protected] | Soaring | 2 | January 24th 08 09:59 PM |
Connecting a GNS 430/530 to a PC | PA34 F-GFTF | Instrument Flight Rules | 5 | September 26th 04 07:09 PM |
Connecting a GNS 430/530 to a PC | PA34 F-GFTF | General Aviation | 4 | September 26th 04 07:09 PM |
Connecting a GNS 430/530 to a PC | PA34 F-GFTF | Aviation Marketplace | 7 | September 25th 04 04:38 AM |
