Connecting a GNS 430/530 to a PC
Old September 23rd 04, 08:33 AM
PA34 F-GFTF
Default Connecting a GNS 430/530 to a PC
Hi,
It seems most handheld GPS can be connected to a computer (through a serial
cable, IIRC).
That allows some cool features, like preparing your flightplan in advance on
your PC, or downloading to the PC the actual positions of your aircraft in
order to obtain a chart of the actual flight path.
Now, do you know if panel-mounted GPS can also be connected to a PC ? Namely
for Garmin's GNS 530 ?
I can't see any reference to this on the 530 reference manual, and I would
be surprise that handheld GPS can do thing that Garmin's top tier GPS can't.
fu2 rec.aviation.marketplace
YAG
Old September 23rd 04, 04:34 PM
Jack McAdams
I do not believe there is anyway to connect the panel-mount products
to a PC. I also went from a ahndheld GPS to a panel-mount version
(430) nad sure do miss the functionality of uploading a flightplan.
There is a second, but unused, data port on the 430 that could perhaps
provide the avenue to do this. I have talked to others and have heard
- not confirmed - that there may be a certification issue in
permitting uploading of data to a certified device.
Jack
Sundowner- N6363U
"PA34 F-GFTF" wrote in message ...
Hi,
cable, IIRC).
Old September 23rd 04, 04:42 PM
Maik
Hi,
really a new idea :-)
It is possible to use the NMEA output of the Garmin 430/530 as an input
for a PC.
It is NOT possible to up-/download flightplans or waypoints.
This is NOT a technical problem.
It seems that it is not allowed for IFR or installed GPS-systems to get
Flightplans or waypoints via an external device.
There is only one chance to feed a Garmin 430/530 legally... with
another Garmin 430/530 via Crossfill.
Solution would be: write a program that simulates the communication
between two Garmins 430/530 and feed this program with flightplans and
waypoints from a flightplaning program or handheld GPS-systems.
Than you could up-/download flightplans and waypoints.
I would be happy to get such a software but writing it it is not a way
to get rich :-)
Another solution is a VFR only GPS like the KMD150. Here you can
up-/downlaod waypoints and flightplans.
Regards
Maik
PS: If I wrote anything stupid please correct me asap. thx.
PA34 F-GFTF wrote:
Hi,
serial
cable, IIRC).
advance on
aircraft in
Namely
would
can't.
Old September 23rd 04, 08:53 PM
Pokeymon
Hi,
for a PC.
No, because NMEA format is not one of the options.
Connecting a GNS 430/530 to a PC PA34 F-GFTF Instrument Flight Rules 5 September 26th 04 07:09 PM
Connecting a GNS 430/530 to a PC PA34 F-GFTF Aviation Marketplace 7 September 25th 04 04:38 AM
CNX-80 vs Garmin 430/530 Paul DeSmet Instrument Flight Rules 44 November 29th 03 02:31 PM
Connecting Rod Specifications Cambridge_Flyer Home Built 4 November 18th 03 11:54 AM
piston connecting rod bolt replacement Dick Home Built 5 October 7th 03 02:34 PM
