anon wrote:
(VideoFlyer) wrote: 45 lbs??? 55 lbs for the nose gear??? That seems awfully high. Those tires will be hard as a rock. I guess I'd prefer a little softer tire to land on. I rarely put in more than about 15 to 20 lbs. 5 lbs will "get the sidewall off the ground." You obviously don't have experience with 5.00-5 tires on a 2,250 lb gross weight canard aircraft or you wouldn't be spewing such ignorance. The pressures I gave are correct for the tires, weight, and configuration. 15 to 20 psi 5.00-5 tires would be grossly under inflated on that airplane. The nose tire inflation of 55 psi is also correct. Think before you post, people. Consider that a pneumatic tire supports the weight by the air pressure that's in it - and that the contact patch of the tire is approximately the weight on the tire in pounds divided by the pressure in psi. That means on the hypothetical plane above (2,250 pounds, 15psi), the contact patch (total) for the three tires would be around 150 square inches. That's 50 square inches per tire, which on a 5.00 tire is otherwise known as "a flat". Mark Hickey |
Mark Hickey wrote:
Consider that a pneumatic tire supports the weight by the air pressure that's in it - and that the contact patch of the tire is approximately the weight on the tire in pounds divided by the pressure in psi. That means on the hypothetical plane above (2,250 pounds, 15psi), the contact patch (total) for the three tires would be around 150 square inches. That's 50 square inches per tire, which on a 5.00 tire is otherwise known as "a flat". Mark Hickey Agreed. More accurately, however, for this airplane there would be about 1000 lb on each main at gross weight which, as you note, would result in very flat 5.00-5 tires at 15 psi. The 45 psi recommendation is correct. - anon |
Well....you're right, -anon. I obviously have no experience with 5:00-5 tires
on a 2250 lb gross weight canard aircraft or I wouldn't be "spewing" such ignorance. But you might notice that I didn't say in my post that 15-20 lbs was the correct, or even recommended, pressure. I am sorry to have contaminated this group with an opinion, an observation and personal experience. Mea culpa, mea culpa. My experience with 5:00-5 tires is on much lighter aircraft. And while I didn't mean to be "spewing ignorance" my experience nonetheless is that pressures of 45-55 lbs makes the tires on my Rans pretty hard. If you would like to tell me that my experience is not valid somehow, feel free. To the original poster...if you want truly accurate information on this newsgroup, "anon" is the person you want to consult. If you're looking for feedback from other people interested in this hobby, better check with "-anon" as well...just so you don't get splattered with more "spewed ignorance." Flyer (foot firmly implanted in mouth) |
How about this that I learned from the Dodge Dakota newsgroup a while
back? Forget about tire pressure for now. Load up the plane to what you expect to be the normal operating weight. Pump up the tire untill you get full tread and no sidewall contact. Take the tire pressure and use that from then on. How do you know when you've got full tread contact? Pour some water just in front of the tire and pull the plane through it, letting the wheel turn completely over a couple of times. It'll leave an 'imprint' on the second time around that will be a mirror image of the tread pattern. If you can read sidewall numbers, you need more air. If it is just a thin strip, you need to remove some. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber Excellent!! Been doing it for years. Dont even need the water now. Warren |
Manifold pressure gauge problem | Dave Russell | Aerobatics | 3 | January 29th 04 03:46 AM |
Nosewheel Shimmy and Scalloped Tire Redux, Plus | Larry Smith | Home Built | 2 | September 15th 03 04:03 PM |
Scalloped Nosewheel Tire | Larry Smith | Home Built | 7 | September 12th 03 09:16 PM |
Fuel pressure Problems | smf | Home Built | 3 | September 7th 03 08:25 PM |
Pressure Differential in heat Exchangers | Bruce A. Frank | Home Built | 4 | July 3rd 03 05:18 AM |
