#11
Hi Steve - What do you think of the Cobra (aluminum)
pin into a bushing: http://www.mcmaster.com/#5448T18 I was planning to do as you did, but it would be much quicker to just add a bushing and replace the pins. Thanks in advance, Best Regards, Dave "YO electric" |
Dave-
Those bushings are intended to be pressed into solid material. I ruled out trying to rely on the aluminum channel for the structure as that was proven by me (and now you) not to work. I think you would find it difficult to attach the bushing to the relatively thin aluminum wall and have it stay put. Regarding your aluminum pin... its obviously trashed like mine was and not usable in a bushing. If you are going to have to replace the pin, steel would be a much better choice. I recommend the scheme that I described previously. Steve Koerner www.wingrigger.com |
Sorry, I wasn't clear...
I have new non-trashed (aluminum) pins from Spindelberger. If I press bushings into channel, they can't move and will stay in place in the channel, rubbing area on pin is greatly increased, hopefully pin will not abrade as it will against channel. Your thoughts ? Thanks, Best Regards, Dave |
Steve, would love to see some pictures of your mod it sounds ideal.
I have always thought that small pin fitting into a thin wall aluminum channel was very poor way of getting the job done. I would also like to see what the "new" cobra setup looks like. I have a machine shop and could possibly manufacture a few low cost DIY kits for others. |
Either Joe or Steve - I (and likely others)
would be interested in a kit; ideally new pin plus insert that can be glued/riveted inside the existing corner channel with minimal surgery... Let us know your thoughts, Thanks, Best Regards, Dave |
Joe -- making some kits sounds like a great idea. Please make one for
YO so he doesn't try to stick a bushing in that aluminum channel. For a long time I had intended to do a write-up on this mod but I never got to it. I wish I had. I didn't locate any pictures but I did locate my dimensioned sketch that I made at the time of fabrication. From the date on the page,I did this in '06. Th sketch is crude but it should be all you need to make the block that goes into the channel. The block is 1.00" X .74" X 4.00". It has 3 M8 tapped holes in the bottom and the reamed .501" hole in the side. I suppose there is the possibility that the skids are located at different longitudinal locations on various trailers -- so that would need to be checked first. It looks like I didn't make any sketch of the part that goes on the door -- I'm thinking it was just an obvious duplication of the existing part there but with the .500" steel pin in place of the aluminum metric size pin. If anyone makes one of these, you should put some grease on the pin or in the hole when you put it together. I have posted the sketch he http://www.box.com/shared/3ul281v6y0aek31gmva5 Steve Koerner www.wingrigger.com |
On Saturday, December 17, 2011 12:51:02 PM UTC-5, Dave Nadler wrote:
Hi Folks - Anybody else had this problem ? http://www.nadler.com/Antares/Cobra_...ge_closeup.JPG I've got replacement pins from Spindelberger and replacement rear corner channels, but I'm thinking about an insert so all the loads aren't taken in a thin bit of channel... Thanks, Best Regards, Dave "YO electric" PS: ~55k miles on the trailer. OK, lets recap, from thread here and private emails. As it says above: I have NEW REPLACEMENT aluminum pins and NEW REPLACEMENT (undrilled) corner channels from Spindelberger. I do not want to repeat the problem by using these as used originally. The structure (pins/channel) is STRONG enough, but the aluminum pin on the thin aluminum corner channel wears excessively. Aluminum-on-aluminum is NOT GOOD. Suggestions so far via email and in this thread: A bushing (as suggested by T8 and others) reduces wear with a better fit and materials that wear less; anything is better than aluminum-on-aluminum. A replacement pin of steel (drill stock or cut bolt with a couple holes through it for mounting; no complicated machining required) will not wear out so easily. A steel insert, block or 1/4" plate bolted to inside of channel, will give better wear and more surface. A tube insert (all the way through the corner channel) can do likewise. Add a plastic cap on the outside to keep the dirt out. Easy to make and install (before riveting in replacement corner channel); no complicated machining required. Notes on more modern Cobra trailers: The bottom of the existing corner channel is not open; the sidewall extrusion is cut leaving this area blocked. You cannot just slide a reinforcement part in from the bottom; you have to remove the corner channel (bunch of rivets). The skids are mounted forward of the rear corner channel. Further thoughts ? Thanks in advance, Best Regards, Dave "YO electric" http://www.onlinecontest.org/olc-2.0...l?dsId=2176944 |
On Dec 18, 8:07*pm, Steve Koerner wrote:
Joe -- making some kits sounds like a great idea. *Please make one for YO so he doesn't try to stick a bushing in that aluminum channel. For a long time I had intended to do a write-up on this mod but I never got to it. *I wish I had. *I didn't locate any pictures but I did locate my dimensioned sketch that I made at the time of fabrication. *From the date on the page,I did this in '06. *Th sketch is crude but it should be all you need to make the block that goes into the channel. * The block is 1.00" X .74" X 4.00". *It has 3 M8 tapped holes in the bottom and the reamed .501" hole in the side. *I suppose there is the possibility that the skids are located at different longitudinal locations on various trailers -- so that would need to be checked first. *It looks like I didn't make any sketch of the part that goes on the door -- I'm thinking it was just an obvious duplication of the existing part there but with the .500" steel pin in place of the aluminum metric size pin. If anyone makes one of these, you should put some grease on the pin or in the hole when you put it together. I have posted the sketch hehttp://www.box.com/shared/3ul281v6y0aek31gmva5 Steve Koernerwww.wingrigger.com Back to the 'why' is the rear door hinge getting all chewed up? I'm thinking the culprit is the heavy ramp (with jack ('s). The rear door locks the ramp in place with a bolt that extends into the door when it is closed. I have found (and fixed) the hole in the door that holds the ramp, to be severely elongated, why? The ramp & jack are bumping up and down causing the elongation. This becomes a jack-hammer and the destructive action doesn't stop with elongating the ramp to door lock. I believe it is undoubtedly causing the door hinge galling. Recommend a 1/16 wall, steel plate with bolt hole drilled in center, be pop- riveted over the elongated hole. Set the new plate so it holds the ramp & jack firmly against the floor. Then fix the hinge pins ala Steve & Joe's recommendation. A good winter project, JJ |
Dave- Removing the rivets on the corner channel and reinstalling it
with new rivets is not a big deal. That only took a few minutes to accomplish. |
JJ, I think you are right on as to the root cause of this, I estimate
my trailer to have less than 25k miles on it and the hole in the gate that secures the jack is butchered from slapping around. Almost always even after a short road trip I open my trailer top and the gate just falls to the ground from the securing pin bouncing loose. |
Worm Hole no Need for Black Hole | Michael Baldwin, Bruce | Products | 2 | May 8th 07 11:04 AM |
Beat up / worn out Arrow valuation | Chuck | Owning | 20 | May 11th 05 11:01 PM |
worn injector? | [email protected] | Owning | 4 | February 17th 05 06:16 AM |
T-hangar's bi-fold door: Convert to a motorized opening door? | Peter R. | Piloting | 16 | August 21st 04 01:06 AM |
172 door hinges: right way, wrong way, my way??? | Mike Z. | Owning | 4 | April 6th 04 08:07 PM |
