Worn Cobra rear-door hinges (both pin and hole)
Old December 19th 11, 03:38 PM posted to rec.aviation.soaring
Steve Koerner
Default Worn Cobra rear-door hinges (both pin and hole)
Dave- Removing the rivets on the corner channel and reinstalling it
with new rivets is not a big deal. That only took a few minutes to
accomplish.
Old December 19th 11, 04:42 PM posted to rec.aviation.soaring
Craig[_2_]
with new rivets is not a big deal. *That only took a few minutes to
accomplish.
Keep in mind that aluminum and bronze aren't very compatible from a
corrosion standpoint. The aluminum is going to be sacrificial to the
bronze. Since you've got lots of aluminum and only a little bronze it
isn't horrible, but a stainless bushing is a better choice if you're
going to stay with the aluminum pins.
Cheers,
Craig
Worm Hole no Need for Black Hole Michael Baldwin, Bruce Products 2 May 8th 07 11:04 AM
Beat up / worn out Arrow valuation Chuck Owning 20 May 11th 05 11:01 PM
worn injector? [email protected] Owning 4 February 17th 05 06:16 AM
T-hangar's bi-fold door: Convert to a motorized opening door? Peter R. Piloting 16 August 21st 04 01:06 AM
172 door hinges: right way, wrong way, my way??? Mike Z. Owning 4 April 6th 04 08:07 PM
