In Flight HDR
Old June 10th 11, 06:30 AM posted to alt.binaries.pictures.aviation
Canuck[_10_]
Default In Flight HDR
This is a second attempt at producing an HDR image of an aircraft in flight.
As the saying goes....there's more than one way to...
I've "discovered" two techniques whereby it is possible to create an HDR
image of an aircraft in flight. The second of the two is much easier and
produces similar results to the first method.....
1 Take a photo of the aircraft in flight in RAW format. Make sure your
exposure is SPOT on.
2 Process it out as a JPG.
3 Process it out as a JPG with +1 exposure.
4 Process it out with -1 exposure.
5 OPTIONAL: you could create many different layers depending on your wish
to experiment simply by altering the exposure adjustment each time you
render it out as a JPG.
6 Use Photomatix to combine the layers. Since the software thinks that each
layer is identical, specify the exposure spacing between the layers.
7 Adjust the various options to create what suits you in an HDR and render
it out.
DONE!
Click image for larger version
Old June 11th 11, 01:44 AM posted to alt.binaries.pictures.aviation
Indrek[_2_]
"Canuck" wrote in message
flight.
each
render
it out.
DONE!
Interesting.
I wonder if one could achieve the same effect by boosting the highlights and
shadows separately in post processing.
Cheers,
Indrek Aavisto
Criticism is easy; achievement is difficult W.S. Churchill
Old June 11th 11, 02:33 AM posted to alt.binaries.pictures.aviation
Chris Richardson
This does nothing to increase the dynamic range. Oversaturated
highlights and underexposed shadows will remain exactly the same.
At the very best, this method could be called pseudo-hdr. In actuality,
it is pure malarkey.
Old June 11th 11, 02:57 AM posted to alt.binaries.pictures.aviation
the Legend of LAX[_2_]
On 6/10/2011 7:44 PM, Indrek wrote:
Interesting.
and shadows separately in post processing.
Cheers,
Indrek Aavisto
That's exactly what I do using Capture One. In fact, they have sliders
just for highlights & shadows.
Old June 11th 11, 03:12 AM posted to alt.binaries.pictures.aviation
Savageduck[_3_]
On 2011-06-10 18:33:51 -0700, Chris Richardson
For a single exposure pseudo-HDR, single exposure tone-mapping using a
piece of software such as NIK HDR Efex Pro to tone-map the single
exposure, rather than making the RAW ACR adjustments, would result in a
far more satisfying result.
My suggestion would be to download the demo copy of NIK HDR Efex Pro
and see for yourself.
https://www.niksoftware.com/hdrefexpro/usa/entry.php
Regards,
Savageduck
Old June 11th 11, 03:08 PM posted to alt.binaries.pictures.aviation
Canuck[_10_]
"Indrek" wrote in message
flight.
each
render
it out.
DONE!
Interesting.
Cheers,
Indrek Aavisto
No. The HDR software does something differently.....and depending on the
other settings you use, it can produce an image that is quite different than
just adjusting the shadows and highlights.
Nick
Old June 11th 11, 03:11 PM posted to alt.binaries.pictures.aviation
Canuck[_10_]
"Chris Richardson" wrote in message
news
Nope. If you have a look at the original image and compare it to the HDR
image, there is quite a difference. Yeah, it is pseudo - hdr......but doing
it the real way is a total pain in the arse because more often than not the
aircraft is not travelling in a very stable path and having to shoot with a
shutter speed of 2000 and above limits you to very bright days. Still....it
can be done the real way or this way. The results are not that dissimilar.
N.
New 18m Class ship - First Flight - The JS1 starts proving flight phase [email protected] Soaring 2 December 14th 06 02:06 AM
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown,New Jersey Dave Vioreanu Owning 0 April 22nd 05 02:55 AM
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown,New Jersey Dave Vioreanu Piloting 0 April 22nd 05 02:55 AM
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown, New Jersey Guy Elden Jr Piloting 0 April 21st 05 04:37 PM
Does anybody know a link to a real picture of the X-43 in flight sans Pegasus or better yet a video clip of the flight? Scott Ferrin Military Aviation 0 April 3rd 04 08:47 PM
