Worn Cobra rear-door hinges (both pin and hole)
Old December 24th 11, 04:31 AM posted to rec.aviation.soaring
Dave Nadler
Default Worn Cobra rear-door hinges (both pin and hole)
I'm going to use bushings in the corner channels and
a steel (ideally stainless) hinge pin. The pin won't
wear out, and if the bushings wear they're just a
few minutes to replace.
Anybody up for making replacement pin kits ?
Here's a rough (I know, very rough) sketch:
http://www.nadler.com/Antares/CobraRearDoorHinge_4.pdf
Joe ? Steve ?
Alternatively, can anyone recommend a favorite
internet machine shop ?
Happy Holidays,
Best Regards, Dave "YO electric"
PS: Wear on pins is only on one side: door moving
downwards when closed, or upwards when open. I think
most likely I've caused this by cranking trailer nose
up against door opened on ground to steady rear of
trailer(instead of using the cranky rear jack stands)...
Worm Hole no Need for Black Hole Michael Baldwin, Bruce Products 2 May 8th 07 11:04 AM
Beat up / worn out Arrow valuation Chuck Owning 20 May 11th 05 11:01 PM
worn injector? [email protected] Owning 4 February 17th 05 06:16 AM
T-hangar's bi-fold door: Convert to a motorized opening door? Peter R. Piloting 16 August 21st 04 01:06 AM
172 door hinges: right way, wrong way, my way??? Mike Z. Owning 4 April 6th 04 08:07 PM
