LK8000 Portrait mode in PC sim mode
Old December 27th 11, 12:51 AM posted to rec.aviation.soaring
Dave Nadler
Default LK8000 Portrait mode in PC sim mode
On Monday, December 26, 2011 7:07:26 PM UTC-5, kirk.stant wrote:
On Dec 26, 11:40*am, "PCool" wrote:
To me (and I used to navigate planes for a living so I'm a bit biased)
the only orientation that really makes sense is Heading up -
especially if there is a lot of crosswind. I want the map to mirror
what is outside the cockpit, and with track up and a crosswind, it's
possible for a feature in the distance (mountain, for example) to be
on one side of the map centerline, but on the other side of the
canopy, due to the glider's crab angle.
"Heading Up" does not match what you see out the cockpit with crosswind.
That is why ILEC SN10 does "nose up", matching your view...
Hope that's clear !
Best Regards, Dave "YO electric"
Old December 27th 11, 01:21 AM posted to rec.aviation.soaring
PCool
I use Trackup with north up above 7km zoom. This is like SYM is working, and
I did it the same.
In landscape mode most people prefer to use north smart, with LK.
North smart is like north up, but the glider is repositioned automatically
to make more space in front of it on the moving map.
But I guess it is a matter of personal preference, and if you are used to
portrait mode you can use it in LK too, in fact it is fully supported of
course.
best
paolo
"kirk.stant" ha scritto nel messaggio
Paolo, north up makes even less sense most of the time!
For this to be useful, of course, you need a good indication of the
actual ground track, so you can adjust your heading accordingly.
This, naturally, is how I have SYM configured in my glider.
Old December 24th 11, 11:28 PM posted to rec.aviation.soaring
kirk.stant
On Dec 24, 4:33*pm, jcarlyle wrote:
Kirk,
Hmmm - I'm running v2.2e (the last stable release) under Win XP Pro,
and the -480x640 resolution works fine.
480x800 is definitely one of the selectable resolutions, according to
this site:http://lk8000.it/faq/62-running-lk-o...how-to-run-lk-...
Maybe selecting one of the other 3 resolutions listed will help on
your machine?
The other possibility is that they eliminated this resolution feature
in v2.3, which are development versions.
-John
On Dec 24, 5:21 pm, "kirk.stant" wrote:
John, that doesn't work on my Win7 shortcut - I get an error message
saying that "The name 'C:Users\...\LK8000\LK8000-PC.exe -480x800'
specified in the Target box is not valid. Make sure the path and file
name are correct."
There are double quotes in the file name in the Target box, single
quotes in the error box.
The shortcut works just fine, otherwise.
Any ideas?
Kirk
I ended up using the 272x480 size and it looks correct on my PC.
Kirk
Old December 25th 11, 04:12 AM posted to rec.aviation.soaring
This is what works for me.
The short cut target is "C:\ ....\LK8000\LK8000-PC.exe" -480x800
The Start in directory is "C:\...\LK8000\
The ... is the path to the LK8000 directory where the application with all
its' associated subdirectories and files are installed.
http://www.soaridaho.com/
"jcarlyle" wrote in message
Kirk,
this site:
http://lk8000.it/faq/62-running-lk-o...reen-size.html
your machine?
-John
name are correct."
Any ideas?
Kirk
Transponder: Mode-C or Mode-S? Morteza Ansari Soaring 27 April 17th 19 05:02 AM
Mode S overload cfinn Soaring 4 September 30th 09 09:07 AM
mode c intermittent skyav8r Owning 0 September 4th 08 01:32 AM
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 07:40 AM
Mode S questoin JerryK Instrument Flight Rules 1 July 17th 03 09:56 PM
