Glider rental for the WGC....where to find?
Old December 29th 11, 11:04 PM posted to rec.aviation.soaring
wladkummer76
Default Glider rental for the WGC....where to find?
Hi guys,
The Brazilian team is looking for a couple of similar 15m gliders for
rent, but having a hard time finding someone willing to even talk
about. What am I doing wrong?
Wladimir Kummer
Ventus A - ZF
Old December 30th 11, 06:09 PM posted to rec.aviation.soaring
Gary[_5_]
On Dec 29, 6:04*pm, wladkummer76 wrote:
Hi guys,
Wladimir Kummer
Ventus A - ZF
I advised another group looking for a glider for the WGC. Consider
searching the FAA public records for the type of glider they wish to
rent. The FAA registry has a public listing and contact info listing
owners.
http://registry.faa.gov/aircraftinquiry/
Worth a shot.
Gary Adams GB
Old December 30th 11, 07:46 PM posted to rec.aviation.soaring
wladkummer76
I'll do that...anyone has an idea of how much to offer for the rent? I
was thinking about 5% the glider's value. Opinions?
Old December 31st 11, 03:49 PM posted to rec.aviation.soaring
JS
Or...
Post links to some of the great Brazilian soaring videos and offer use
of Brazilian gliders in exchange.
Old January 1st 12, 04:20 AM posted to rec.aviation.soaring
Frank Paynter[_2_]
Hi guys,
Wladimir Kummer
Ventus A - ZF
You probably aren't doing anything wrong - it's probably a combination
of too few glider pilots, too many lawyers, and an ever-friendly
FAA ;-)
Frank (TA)
Old January 1st 12, 04:08 PM posted to rec.aviation.soaring
wladkummer76
Or...
Great Idea!!!! Nice way to make some friends
Wlad
Old January 2nd 12, 03:35 AM posted to rec.aviation.soaring
Jerzy
Or...
Wlad
You can consider shipping 3 gliders and one trailer in 40' High Cube
container
cost one way around $5000
Jerzy
Old January 2nd 12, 04:07 AM posted to rec.aviation.soaring
Dan[_4_]
Or...
Wlad
container
Jerzy
And you get the added benefit of not having to jump through the hoops
of getting a US licence in order to fly a US aircraft (you should
start now...).
Old January 2nd 12, 04:15 PM posted to rec.aviation.soaring
Burt Compton - Marfa
Foreign pilots flying as PIC in a US "N" numbered glider in the USA
should consider the requirements:
CFR 61.3(a) states that a foreign pilot flying a civil aircraft of the
United States must have some level of FAA Pilot Certificate.
Option 1. You could earn a "real" US Pilot Certificate by taking
ground and flight training and take the written knowledge test and a
flight test for Private Glider.
Option 2. You could apply to the FAA for a "Restricted" Private pilot
certificate.with glider category rating.
The process for the "Restricted" certificate “based on the foreign
license” has changed and requires a "Verification of Foreign License"
by the FAA. Application should be made to the FAA at least three
months before flying in the USA.
FAA webpage: http://www.faa.gov/licenses_certific..._verification/
The “Special Purpose Authorization” of CFR 61.77 is meant to apply to
commercial aircraft operations.
TSA (Homeland Security) issued a waiver that excludes glider pilots
from background checks and fingerprinting before training for the US
glider pilot certificate.
A Flight Review may be required under CFR 61.56 and 61.2(b).
CFR 91.307 will apply to your 180 day parachute repack used in a US
aircraft.
There was some speculation for the 2012 Worlds at Uvalde that a waiver
from the FAA might be requested by the organizers. I do not know if
this was approved.
Note that the owner of the US glider should check with their insurance
broker to assure coverage is in effect for loaning or leasing of the
glider to properly certificated foreign pilots.
The owner should prepare the glider for a FAA “Ramp Check” items
including aircraft airworthiness and registration certificates, weight
and balance, flight manual (if required by the TCDS), placards,
airspeed markings, seat belt tags, etc.
Sometimes the FAA wants to review the aircraft logbook for the annual
inspection and compliance with all Airworthiness Directives,
especially the repetitive AD’s. This request is supposed to be in
writing but I understand that logbooks were requested for the
towplanes at a recent glider event.
Best to have all of your pilot and aircraft paperwork available and up
to date.
I’m not happy about all of these regulations so please don't shoot the
messenger.
Glider Rental Insurance: Tony V Soaring 1 August 18th 10 05:06 PM
Glider Rental Insurance: BTiz Soaring 0 August 18th 10 04:53 AM
Glider Rental Insurance: Walt Connelly Soaring 5 August 18th 10 02:03 AM
O2 Rental.. Dan Piloting 1 September 15th 06 07:14 PM
Glider Insurance and Rental/Borrowed Ships ContestID67 Soaring 6 March 7th 05 06:34 PM
