Pawnee front seal leak
Old January 3rd 12, 03:28 PM posted to rec.aviation.soaring
kirk.stant
Default Pawnee front seal leak
On Jan 2, 8:14*pm, aerodyne wrote:
On Jan 2, 6:53*am, Andy wrote:
Thanks to those that replied to my post in September. *One Pawnee was
fixed by changing the crank seal, the other was fixed by snugging down
the governor plate nuts. * It took a while to hear about this as I
don't see the mechanics that often.
I was not able to reply on that old thread.
Andy
Andy;
Glad you fixed the problem. *I check the nuts and safety wire on the
plate on every preflight - *It can be a recurring problem,, and I have
seen the wire broken.
Aerodyne
Does anyone have a GOOD Pawnee preflight checklist they could share,
or a link to one?
Kirk
66
Old January 3rd 12, 05:32 PM posted to rec.aviation.soaring
Dan Marotta
I've never seen a flight manual or checklist for a Pawnee. In their absence
I simply:
1. Check Master and Mags - OFF
2. Left wing
a. Flap secure, spring loaded up, no binding
b. Aileron secure, hinges, nuts and bolts, safety wire in good order, no
binding
c. Wing tip, shake, no looseness in the wing
d. Fuel level - CHECK
e. Wing struts - condition, security, tightness
3. Left landing gear
a. Brake - condition, no leaks
b. Tire - condition
4. Engine
Oil - CHECK, minimum 9 qt.
Propeller - CHECK condition
Prop governor (or cover plate) secure, no leaks
Right landing gear
b. Tire - condition
Right Wing
a. Wing struts - condition, security, tightness
b. Fuel level - CHECK
d. Aileron secure, hinges, nuts and bolts, safety wire in good order, no
binding
e. Flap secure, spring loaded up, no binding
Tail Group
a. Horizontal stabilizers - Secure, flying wires tight and of even
tension
b. Elevators - Hinge pins secure, no slop, free movement, cables in good
condition
c. Rudder - Hinge pins secure, no slop, free movement, cables in good
condition
d. Tow release - Condition, operation, and security (also check the tow
release mechanism).
I probably overlooked something in writing above, but it's basically a good
look at a very basic airplane.
"kirk.stant" wrote in message
On Jan 2, 8:14 pm, aerodyne wrote:
On Jan 2, 6:53 am, Andy wrote:
Thanks to those that replied to my post in September. One Pawnee was
the governor plate nuts. It took a while to hear about this as I
Andy
Andy;
Glad you fixed the problem. I check the nuts and safety wire on the
plate on every preflight - It can be a recurring problem,, and I have
Aerodyne
or a link to one?
Kirk
66
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 56 March 24th 14 06:21 AM
Pawnee front seal leak Andy[_1_] Soaring 7 September 30th 11 02:04 AM
Cobra Trailer leak, front end gasket, fix? SF Soaring 1 December 20th 10 07:30 PM
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 4 October 17th 07 01:31 PM
Pawnee fuel system leak Rod Pool Soaring 0 August 12th 04 04:29 AM
