![]() "VideoFlyer" wrote in message ... 45 lbs??? 55 lbs for the nose gear??? That seems awfully high. Those tires will be hard as a rock. I guess I'd prefer a little softer tire to land on. I rarely put in more than about 15 to 20 lbs. 5 lbs will "get the sidewall off the ground." It would depend on the all up weight of the aircraft, our Rallye 100 weighs in at a gross weight of 1700 lbs and the tire pressures are 21 in the nose wheel and 25 in the mains. -- .. -- Cheers, Jonathan Lowe whatever at antispam dot net No email address given because of spam. Antispam trap in place |
Manifold pressure gauge problem | Dave Russell | Aerobatics | 3 | January 29th 04 03:46 AM |
Nosewheel Shimmy and Scalloped Tire Redux, Plus | Larry Smith | Home Built | 2 | September 15th 03 04:03 PM |
Scalloped Nosewheel Tire | Larry Smith | Home Built | 7 | September 12th 03 09:16 PM |
Fuel pressure Problems | smf | Home Built | 3 | September 7th 03 08:25 PM |
Pressure Differential in heat Exchangers | Bruce A. Frank | Home Built | 4 | July 3rd 03 05:18 AM |
