bleeding Duo Discus brakes
Old January 17th 12, 03:39 AM posted to rec.aviation.soaring
Karl Striedieck[_2_]
Default bleeding Duo Discus brakes
On Jan 16, 6:05*pm, JJ Sinclair wrote:
On Jan 16, 1:56*pm, Morgan wrote:
This pretty much nails what ended up working for me. *I ended up
removing the whole system from the ship and flushing it forwards and
backwards to make sure there wasn't any old fluid or particles in the
system. *Popped the piston out and inspected it and the cylinder wall
for corrosion and pitting. *Overall things looked pretty good, but it
got a good cleaning while I was in there.
Funny, you'll jump through all sorts of hoops and delays to avoid
doing it the "hard way" and in the end that was the least traumatic
and fastest way to get it to work. *It took me way longer than it
should have, but the upside is that I know my braking system inside an
out now and it is time for new pads as well.
Thanks for the tips.
Morgan
On Jan 16, 9:23*am, rhwoody wrote:
On Jan 11, 12:30*am, Morgan wrote:
Looking for advice on bleeding the brakes on my Duo with the tost 30-9
caliper. *I replaced a shot bleeder valve with a new stahlbus valve,
but after futzing with the system for over an hour, I can't get the
brake to firm up to an acceptable level.
I've tried using a suction device to pull fluid (Dot 4 in the Duo)
down through the line. *I've also gone with my normal old standby of
pushing fluid up through the brake using a syringe. *The Stahlbus
valve is not working as advertised or rather the brake isn't. *The
brake doesn't seem to be creating enough pressure to overcome the
spring tension on the check valve.
The best I've been able to get to so far is a fairly spongy grip on
the rotor. Enough that turning by hand isn't possible, but it doesn't
feel like it would slow you down much when you needed it.
Basically it just doesn't feel like the master cylinder is drawing
fluid in or maybe there is a hidden air bubble.
Any thoughts from the internet hive on the quirks of this beast?
It's certainly been a much greater hassle than I expected. *I'm
guessing at this point that either there is a trick that I don't know
about or something is malfunctioning.
Thanks,
Morgan
Hi All, *I have owned a lot of SH gliders and have had success doing
the following -
unbolt the brake cylinder and raise it up so there is no "loop" in the
brake line -
so the path from the brake calipers to the brake cylinder goes only
uphill -
first try to actuate the brake cylinder lever - sometimes this will
"burp" the air
bubble up into the brake cylinder - otherwise fill fluid from the
bottom nipple
until the air bubble goes into the brake cylinder reservoir - *most
times the
air bubble will burp into the reservoir and no filling is necessary -
good luck,
Ralph Woodward- Hide quoted text -
- Show quoted text -
Changing the fluid every 6 or 8 years is a very good idea. I checked
my system last year by having a helper (wife) pump the master cylinder
a few strokes and then hold the pressure as I bled out the pressure at
the brake.............just like we did in the 1934 Ford. You wouldn't
believe what came out, thick gooey stuff that wasn't even red anymore!
I had to repeat this for several cycles before the bled fluid started
showing red fluid. I also replace my pads when they show less than
1/8" which can be easuly seen with a flashlight and mirror.
Cheers,
JJ
I've been unable to get the Duo wheel brake to work as it should. This
includes removing the entire system (caliper, lines, master cylinder)
and operating it on the bench with a piece of metal to simulate the
disc. In this configuration it works great - rock hard "brake pedal."
But it has to be disassembled to go back in the glider, and there it
is spongy again, no matter how much or how you bleed it. I thought the
problem might be partial retraction of the pucks due to temperature
changes, "potato chipped" disc, or vibration, so installed small
springs behind the pucks to keep them lightly against the disc. No
improvement.
It helps to pump up the brake with the stick mounted brake lever if
you have one, while in the landing pattern. Or cycle the air brakes
fully if you don't have the stick grip.
Another wheel brake problem with the Duo is a fundamental mechanical
issue. The force required to cycle the speed brakes all the way open
to the wheel brake actuation point gets higher as you slow down. While
flying at pattern speed the spoilers stay open by air pressure, but as
you slow down on the ground they get heavier as air speed no longer
helps keep the handle back. With little or no airspeed the amount of
force required to pull the handle all the way back is considerable,
with little left over to apply brake.
One solution I've employed for the latter is a long bungee cord that
pulls back on the spoiler handle. But this has a couple significant
safety issues that must be addressed. It must not be hooked up until
landing, and the pilot must then keep his/her hand on the spoiler
handle. A better procedure is to have the back seater help with the
pull.
Old January 17th 12, 01:58 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
On Jan 16, 7:39*pm, Karl Striedieck
Morgan
Thanks,
Morgan
the following -
brake line -
uphill -
"burp" the air
bottom nipple
times the
good luck,
Cheers,
JJ
improvement.
pull.- Hide quoted text -
I have had similar problems with the Grob 103, just couldn't get the
air bubble to break loose. You might try tilting the fuselage as far
as possible (away from the brake side), then bleed the brakes. This
might allow the bubble to rise up to the master cylinder.
See you at Parowan,
JJ
brake bleeding Pintlar Home Built 15 April 7th 10 03:01 AM
bleeding brake help Pintlar Home Built 8 November 7th 09 12:41 PM
Engine bleeding [email protected] Piloting 4 December 9th 04 04:38 AM
Engine bleeding [email protected] Piloting 0 December 8th 04 09:22 AM
Bleeding brakes on Tripacer Corky Scott Piloting 2 July 30th 03 08:11 PM
