VHF Aviation FBO Antenna
Old January 23rd 12, 06:31 AM posted to rec.aviation.homebuilt
Default VHF Aviation FBO Antenna
"Phil" wrote in message ...
Hello , am looking for advise on a VHF Omni directional antenna for a
small fixed base operation , looked at a commercial ant. and the price is
a little high for a 1/4 wave vertical , am sure the quality is there but
am wondering if I could modify a Ringo or something else to work just as
good , would have it resonate on 123.000 as this is our Unicom freq., a
little gain would be OK .
Thanks
Phil L.
W8KLK
Phil,
Why don't you build a J-Bar?
http://www.soaridaho.com/Antenna/J-Bar_Antenna.htm
Or even simpler, sting the following antenna in side a vertical piece of PVC
pipe.
W7ADK
Com Antenna Tony Condon[_2_] Soaring 2 May 5th 09 03:11 AM
antenna et Home Built 7 June 29th 08 04:00 PM
GPS Antenna 150flivver Owning 14 December 11th 05 05:38 AM
Using Wideband Aviation Antenna for TV Reception? CHANGE USERNAME TO westes General Aviation 1 July 7th 04 12:32 AM
where's the THRILL is flying, rec.aviation.balloon,   rec.aviation.hang-gliding, rec.aviation.powerchutes, rec.aviation.soaring BW Rotorcraft 0 October 15th 03 11:42 AM
