#21
I was never confused until reading this thread...
The only valid use I can think of for using QFE is for low-level airshows, e.g., inverted robbon cut. "glidergeek" wrote in message ... On Jan 26, 4:33 am, Tom wrote: As a glider pilot, when are you allowed to use a zero altimeter setting? Back in July, I asked the FAA for a legal opinion regarding FAR 91.121. Yesterday, I finally received a response. There is reason for a continued dialog, and I am continuing the discussion with the FAA legal department. This Saturday, immediately prior to the third Glider Safety Webinar,I will provide subscribers to the webinar the exact wording of the FAA response. To join us in this discussion, please sign up for the third webinar on our web site:www.eglider.org Tom Knauff If there is confusion it's because of an instructor not teaching properly This letter is in response to your July 19,2011 request for a legal interpretation regarding altimeter settings required in 14 CFR § 91.121. In your letter, you state that there is confusion among local area glider pilots as to whether altimeters must be set to mean sea level (MSL) when not using a cruising altitude, such as when conducting student glider flight training. Additionally, you indicate that glider operators are unsure if the regulation requires altimeters to be set to mean sea level (MSL) or above ground level (AGL) during student training and local flying. The cruising altitude of an aircraft below 18,000 feet MSL shall be maintained by reference to an altimeter that is set to the current reported altimeter setting of a station located along the route of flight and within 100 nautical miles of the aircraft. If there is no such station, the current reported altimeter setting of an appropriate available station shall be used. In an aircraft having no radio, the altimeter shall be set to the elevation of the departure airport or an appropriate altimeter setting available before departure. 14 CFR § 91.121(a)(1). The cruising altitude is the MSL altitude or flight level maintained during en route level flight. For aircraft such as gliders, transient periods oftime at a particular altitude do not relieve pilots from the requirements to operate the aircraft in reference to an altimeter that is set according to the requirements of § 91.121(a). Thus, local area glider pilots must set their altimeters to MSL, not AGL, during glider operations, including student glider training flights. Further FAA guidance on altimeter settings for glider operations can be found in the Glider Flying Handbook, FAA-H-8083-13, Chapter 4 (available online at http://www .faa. gov/library/manuals/ aircraft! glider handbook/media/ faa-h-8083-13. pdf |
The one situation where setting the altimeter to "zero' before flight
makes sense is flying a purely aerobatic flight. You will never be towed high enough to bust airspace rules. You must be totally focused on how high you are above the ground and to make sure you do not bust the 1,500 floor for aerobatic flight. With so much going on in the cockpit, setting the altimeter to zero makes the scan of the panel very simple. |
At 05:25 29 January 2012, guy wrote:
The one situation where setting the altimeter to "zero' before flight makes sense is flying a purely aerobatic flight. You will never be towed high enough to bust airspace rules. You must be totally focused on how high you are above the ground and to make sure you do not bust the 1,500 floor for aerobatic flight. With so much going on in the cockpit, setting the altimeter to zero makes the scan of the panel very simple. I am coming to this thread late , but when I started we set QFE because we only winch launched to 800ft and timed the flight in minutes and seconds,you new where you were going to land and when. Every thing has changed for me ,I now won,t rig if it is not soar able and always fly QNH ,but I still like QFE set for the first 3or4minutes till I am sure the rope isn't going to break.But then it,s a different world now the LX has QNH and AGL on the screen and All you need to do is re-set off tow.It is still nice to have QFE set for your competition finish and I will re-set especially if control is giving it as you call 5 minutes. |
On Sat, 28 Jan 2012 21:25:13 -0800, guy wrote:
The one situation where setting the altimeter to "zero' before flight makes sense is flying a purely aerobatic flight. You will never be towed high enough to bust airspace rules. You must be totally focused on how high you are above the ground and to make sure you do not bust the 1,500 floor for aerobatic flight. With so much going on in the cockpit, setting the altimeter to zero makes the scan of the panel very simple. Its also quite comforting if you're a flat-land flier and visiting a hill- top site for a spot of ridge soaring. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
competition finish and I will re-set especially if control is giving it as you call 5 minutes. I don't get this at all. What is the advantage? Aerobatics and local winch ops have the common feature that one doesn't expect to be sharing airspace with other users. In this case, it doesn't matter to others what you use for an altimeter setting. When sharing airspace with others -- which is most of recreational and virtually all of competition soaring -- it's stupid not to have everyone on a common standard. This is just as true when local soaring around a public use airport as it is for cross country. -Evan Ludeman / T8 |
On Jan 29, 4:44*am, T8 wrote:
It is still nice to have QFE set for your competition finish and I will re-set especially if control is giving it as you call *5 minutes. I don't get this at all. *What is the advantage? Aerobatics and local winch ops have the common feature that one doesn't expect to be sharing airspace with other users. *In this case, it doesn't matter to others what you use for an altimeter setting. When sharing airspace with others -- which is most of recreational and virtually all of competition soaring -- it's stupid not to have everyone on a common standard. *This is just as true when local soaring around a public use airport as it is for cross country. -Evan Ludeman / T8 Now that the webinar is over. What is Tom's take on all this? Tom, do you set to zero, or actual field elevation prior to launch? And why continue the discussion with the FAA. 91.121 is the rule with no exceptions. We should be teaching our students the proper way and get them ingrained to do the mental math to compute AGL from an MSL altimeter from day one! T |
WestJet B-737 With The Sun Setting | Canuck[_10_] | Aviation Photos | 0 | September 4th 10 05:07 PM |
Altimeter Setting | Rolf | Soaring | 82 | August 11th 10 06:15 PM |
WTB: used 57mm Altimeter OR swap for 80mm Altimeter | joesimmers | Soaring | 0 | November 3rd 09 11:59 AM |
Altimeter setting != Sea Level Pressure - Why? | JT Wright | Piloting | 5 | April 5th 04 01:04 AM |
Setting QNH | BTIZ | Piloting | 31 | March 12th 04 04:29 PM |
