Bill Authorizes Use of Unmanned Drones in U.S. Airspace
Old February 9th 12, 07:33 AM posted to rec.aviation.soaring
Darryl Ramm
Default Bill Authorizes Use of Unmanned Drones in U.S. Airspace
The government cannot pull the plug on the SSR radar system if its replaced by current ADS-B technology that is insecure/spoofable/easily attacked by terrorists. I expect some to be decommissioned but grand plans to do away with SSR are a fantasy. The fundamental insecure design of ADS-B is a terrible mistake, this technology needed to have encryption built into it from day one.
A large problem with the USA ADS-B infrastructure for GA and sports aviation is the dual link layer silliness. There are likely to be many areas where say drones operating at low altitudes would be outside ADS-B GBT (ground based transceiver, the ground stations that do the ADS-R relay between UAT and 1090ES link layers) coverage so if a drone is on UAT then a GA aircraft say with a Trig ADS-B receiver won't see it, or a glider with a PowerFLARM won't see it, and so on. One possible thing would be to require all drones to transmit and receive (and relay that traffic data to the operator) on both UAT and 1090ES link layers. Seems too late to mandate dual-link receivers and/or transmitters for GA etc. within the proposed time frames. I expect the required area of carriage for at least ADS-B data-out for GA etc. to be increased, no way they can avoid that long term if you want drones to avoid aircraft. No idea if this will lead to mandatory ADS-B data-in carriage for GA.
Meanwhile you still cannot even install ADS-B data-out in a (certified) glider or GA aircraft without a STC and an expensive TSO'ed GPS. All a complete mess...
Darryl
Old February 11th 12, 11:24 AM posted to rec.aviation.soaring
Ian[_2_]
On Wed, 8 Feb 2012 23:33:29 -0800 (PST), Darryl Ramm
drones =
operator) on bo=
receiver=
Why not mandate all drones to carry Flarm? That would help full the
gaps left by all the "professional" technology.
Old February 11th 12, 12:33 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
drones =
operator) on bo=
receiver=
Why not mandate all drones to carry Flarm? That would help full the gaps
FWIW a longish paper just came out in the UK, written from the Army's
POV. They've looked carefully at the problems of operating UAVs in
uncontrolled airspace and decided that large scale adoption isn't on
within at least the next decade - if then. The main issues a
- collision avoidance: they can't see any technology that could handle
that, especially for small/lightweight/very hard to see UAVs that is
even on the horizon.
- bandwidth. Control bandwidth is trivial (an 8 channel digital RC
system uses about 32Kb/sec) but the sensor download stream is very
significant. 256 MB/sec was quoted for the big surveillance UAVs
in Afghanistan and apparently the population of UAVs there are
causing frequency allocation problems when the non-UAV bandwidth
needed by modern forces in the absence of adequate comms
infrastructure is considered.
OK, we have plenty of fibre bandwidth so fixed base comms goes away,
but the UAV dowenlink remains a big problem, especially when you
consider that so many uses, e.g. traffic and fire surveillance,
police,etc. need real-time downlinking to either a computer or an
operator. Radio bandwidth is getting crowded without a few hundred
or thousand UAVs trying to use it.
Fancy giving up your mobile phone so a UAV can operate? No? Didn't
think so.
Here's a link to the piece.
http://www.mod.uk/NR/rdonlyres/F9335CB2-73FC-4761-A428-
DB7DF4BEC02C/0/20110505JDN_211_UAS_v2U.pdf
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Drones T8 Soaring 11 February 10th 12 05:30 PM
What about flying unmanned drones.. i.e. The Predator KAE Piloting 6 October 27th 07 02:04 AM
Wichita Airspace Question and overlapping airspace Owen[_4_] Piloting 1 February 14th 07 09:35 PM
FAA authorizes Predators to seek survivors Dave S Piloting 0 August 3rd 06 03:38 PM
ww2 training drones tongaloa Home Built 6 September 6th 03 05:55 PM
