Dan, see your emails. Regards - Chris
Chris, I'm going to try to analyze the height trace using the graphical
functions in Microsoft Excel. I'll look for a sudden increase in rate of climb and make a guess from there. I might say in advance that I'm not hopeful, but this should be a fun exercise. Dan BTW, I received your IGC files. "Chris Nicholas" wrote in message ... Dan, see your emails. Regards - Chris |
Well, just going on a look-see, it looks like cloud base in one of the
traces was around 17,200 MSL with a top of climb of 24,740 MSL and, in the other, around 16,000 MSL with a top of climb of 34,480. So... How'd I do? I'm also thinking that your altitudes might be in meters and if that's the case, then it might be... Cloud Base: 1,720 meters, Top of climb: 2,447 meters for the first flight, and, for the second, Cloud Base: 1,600 meters, Top of climb: 3448 meters. Since I can't paste a picture in here, I sent you the Excel file with the traces included on Sheet 3. Please let us know if such a quick look came close. "Dan Marotta" wrote in message ... Chris, I'm going to try to analyze the height trace using the graphical functions in Microsoft Excel. I'll look for a sudden increase in rate of climb and make a guess from there. I might say in advance that I'm not hopeful, but this should be a fun exercise. Dan BTW, I received your IGC files. "Chris Nicholas" wrote in message ... Dan, see your emails. Regards - Chris |
Thanks to Chris who took the time to look up the IGC specification for the
log file. From his analysis, I was able to determine that the cloud base on one of the flights was around 5,200 ft (lower than my airport!). The trace looked the same, just the altitude scale was changed. And it's interesting what Jim said about reduced lift inside the cloud. I would have expected higher lift due to the heat release. Maybe that's all expended right at cloud base... It was a fun exercise! "Dan Marotta" wrote in message ... Well, just going on a look-see, it looks like cloud base in one of the traces was around 17,200 MSL with a top of climb of 24,740 MSL and, in the other, around 16,000 MSL with a top of climb of 34,480. So... How'd I do? I'm also thinking that your altitudes might be in meters and if that's the case, then it might be... Cloud Base: 1,720 meters, Top of climb: 2,447 meters for the first flight, and, for the second, Cloud Base: 1,600 meters, Top of climb: 3448 meters. Since I can't paste a picture in here, I sent you the Excel file with the traces included on Sheet 3. Please let us know if such a quick look came close. "Dan Marotta" wrote in message ... Chris, I'm going to try to analyze the height trace using the graphical functions in Microsoft Excel. I'll look for a sudden increase in rate of climb and make a guess from there. I might say in advance that I'm not hopeful, but this should be a fun exercise. Dan BTW, I received your IGC files. "Chris Nicholas" wrote in message ... Dan, see your emails. Regards - Chris |
In my experience lift in cloud is stronger only if the cloud has a lot
of vertical development – say several thousand feet, which of course developing CBs do have, and provided you can stay centred in the lift, which as Jim points out is harder if you can’t see the real horizon. I have found that expanding the GPS scale helps a lot in keeping in good lift, in VMC or in IMC. (I still do not advocate people teaching themselves to do the latter these days – if it goes wrong in a slippery glider, it can do so very quickly and very badly.) In the more usual “good” conditions in the UK when we get them, an inversion stops vertical cu development and they are often only a few hundred or 1-2000 feet deep. Then, as Jim says, it is usually faster to keep in the energy where you can see it, in VMC. With very shallow clouds, it is not even worth going up to cloud base – the lift weakens before getting there. Even if it does strengthen briefly at and into cloud, I usually lose more in the fumble of coming out on the wrong heading, or on the right one but into another cloud and in its sink, than staying below, if achieved speed is what you are after. Chris N |
On Feb 19, 10:12*am, Chris Nicholas wrote:
In my experience lift in cloud is stronger only if the cloud has a lot of vertical development – say several thousand feet, which of course developing CBs do have, and provided you can stay centred in the lift, which as Jim points out is harder if you can’t see the real horizon. I have found that expanding the GPS scale helps a lot in keeping in good lift, in VMC or in IMC. (I still do not advocate people teaching themselves to do the latter these days – if it goes wrong in a slippery glider, it can do so very quickly and very badly.) In the more usual “good” conditions in the UK when we get them, an inversion stops vertical cu development and they are often only a few hundred or 1-2000 feet deep. Then, as Jim says, it is usually faster to keep in the energy where you can see it, in VMC. With very shallow clouds, it is not even worth going up to cloud base – the lift weakens before getting there. Even if it does strengthen briefly at and into cloud, I usually lose more in the fumble of coming out on the wrong heading, or on the right one but into another cloud and in its sink, than staying below, if achieved speed is what you are after. Chris N It is very common in Arizona to have at least a slight inversion at or below cloud base. What happens in these cases is that the rising airmass in a strong thermal continues going up under its own momentum. It's not uncommon in these circumstance to find the lift cutting off a thousand feet below the clouds and very nice looking clouds have no lift under them. I sometimes refer to these clouds as resulting from the last dying gasp of a rising thermal! With instability of the atmosphere rising above cloud base, thermals will often increase with strength as you approach the cloud and this increase continues into the cloud. These are the circumstances when you might get too close to the cloud - it's not uncommon here to find a ten-knot thermal strengthening to 12 to 15 knots! At these vertical speeds, you can go from a safe distance below into cloud in about half a turn. It's very easy to do and a not uncommon experience out west. Mike |
At 16:15 18 February 2012, Dan Marotta wrote:
Chris, I'm going to try to analyze the height trace using the graphical functions in Microsoft Excel. I'll look for a sudden increase in rate of climb and make a guess from there. I might say in advance that I'm not hopeful, but this should be a fun exercise. Dan Dan, I do quite a lot of cloud flying mostly to keep current as cloud flying is allowed in UK competition and sometimes it is necessary to fly in cloud to stay up. However....it rarely is faster. I usually find that my climb rate drops as I enter cloud because the artificial horizon although good is not anything like as good as the real thing. In my experience if cloud base allows it is much faster to fly the energy below cloud. BTW I also find cloud flying fun which is after all the reason I go flying. J1M |
Dan was about right. Using metres is more like right – the plots Dan
sent me showed way too many feet on the left hand scale. My recollection is that cloudbase was a bit over 4000 feet and I climbed to about 11000 feet that day. By the way, to repeat part of what I sent Dan privately - I do not claim to be a very good IMC pilot. I had a bit of instruction at first, then a lot of self-learning in a Ka6E which is strong, draggy, has speed-limiting brakes/spoilers, and is fairly forgiving when things go wrong – which they often did when I was slowly acquiring the skill, using only a glider Turn and Slip (stronger spring, less sensitive than a Power T&S so it does not go onto the stop in a thermalling turn). I also advise other people not to cloud fly. Modern gliders are too slippery to self-teach safely, IMHO. I do it because I like it and accept the risk (which I think is minimal having learned the slow way). I also agree with Jim's comments. Chris N. |
Butterfly iGlide | Reed von Gal | Soaring | 4 | May 2nd 12 06:00 PM |
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario | ufmechanic | Soaring | 0 | March 24th 09 05:31 PM |
TE vario | G.A. Seguin | Soaring | 8 | June 8th 04 04:44 AM |
WTB LD-200 Vario | Romeo Delta | Soaring | 0 | June 4th 04 03:08 PM |
