Info on Mosquito
Old February 27th 12, 09:09 PM posted to rec.aviation.soaring
Mike[_37_]
Default Info on Mosquito
On Feb 27, 12:06*pm, Walt Connelly Walt.Connelly.
Okay folks, help me out here. *How about some of you old timers weigh in
on the Mosquito. *Handling? *One man rigging? *Possible dollar range?
Let me know what you think, I don't know squat.
Walt
Walt Connelly
Hi Walt
Have you checked with the swarm?
http://groups.yahoo.com/group/Mosquitos/
Old February 27th 12, 09:45 PM posted to rec.aviation.soaring
Dan Marotta
You're never too high in a Mosquito. With that trailing edge, you can fly
straight down without exceeding the redline. I've done it. As for lacking
performance, here's a flight I did last summer in a borrowed ship:
http://www.onlinecontest.org/olc-2.0...l?dsId=2054684
"Mike" wrote in message
On Feb 27, 12:06 pm, Walt Connelly Walt.Connelly.
Okay folks, help me out here. How about some of you old timers weigh in
on the Mosquito. Handling? One man rigging? Possible dollar range?
Walt
Walt Connelly
Hi Walt
Old February 27th 12, 10:11 PM posted to rec.aviation.soaring
Mark Jardini[_2_]
I used to own the one tested by Dick Johnson. What every one else
said, great ship. They are a bit heavy being polyester epoxy ships and
stoutly built, about 7+ lbs wing loading unballasted, and not the best
light air climbers. Never flew it with water. I never heard of someone
not liking the handling.
mj
Old February 28th 12, 01:25 AM posted to rec.aviation.soaring
BobW
mj
Being either precise or anal, "polyester epoxy"? My understanding is Mosquitos
are epoxy resin, "all fiberglass" ships (i.e. no carbon or Kevlar/polyamide),
which is to say, their construction materials are typical of many first/2nd
generation "glass gliders."
The only polyester resin glider I was ever (vaguely) aware of was the (never
actually produced, so far as I'm aware) Torva.
Never flown a Mosquito, was wingtip grunt for one many times, ditto all prior
rigging comments. Never noticed any of its owners having to "fuss with" the
canopy mechanism. I believe (didn't check prior to posting) Mosquitos also
have the parallellogram stick, do they not? Always seemed like a good idea to
me (as compared to either an "S-curve" or sharply angled back one).
Other than the untimely death of Eugen Hanle and Glasflugel
not-long-thereafter being purchased-by/absorbed-into Schempp-Hirth, I've long
thought the innovative (and used for a while by Schempp-Hirth...and also
Slingsby on the Vega) trailing edge flap/dive brake was the only "fly in the
ointment" somewhat balking the Mosquito's more general acceptance. We glider
pilots tend to be SO conservative in our "what's acceptable in a glider"
views. :-)
Have Fun!
Bob W.
Old February 28th 12, 01:55 AM posted to rec.aviation.soaring
Mike[_37_]
mj
views. :-)
Have Fun!
Bob W.
The Finish Utu used polyester resin-I think.
Old February 28th 12, 11:37 AM posted to rec.aviation.soaring
Nigel Pocock[_2_]
I flew one for 2 seasons having previously flown mainly standard class
gliders.
A lot of bang for the buck. Easy rigging especially with the tool to pull
the wings together that last half inch.
One gotcha though. I was used to opening full airbrakes once I had touched
down to keep me firmly planted. First time I tried this with the Mossy i
found myself 2 ft back up in the air. a combination of slightly too fast
touchdown and trailing edge airbrakes providing lift as well as drag in
ground effect.
I found the roll rate soggy at thermalling speeds but once established in a
thermal and with some flap it went round on rails
The gell coat seems to last better than a lot of gliders although most of
them will have been refinished at least once by now.
same performance as a discus at half the price.
Nigel
Old February 27th 12, 10:31 PM posted to rec.aviation.soaring
Simon France
Big cockpit, good handling, good brakes, push-button trimming,
parallelogram stick(not twitchy even at VNE). I rig it single-
handed with two trestles and a wing root dolly.
Si
you can fly
for lacking
ship:
http://www.onlinecontest.org/olc-2.0...ightinfo.html?
dsId=2054684
news:0b6b5541-407d-4ec5-bae5-
timers weigh in
range?
Walt
Walt Connelly
Hi Walt
R-22 vs Mosquito Stuart & Kathryn Fields Rotorcraft 15 May 12th 08 04:25 PM
Mosquito Pjmac35 Aviation Photos 0 July 21st 07 07:47 PM
I Want a Mosquito..... Shiver Rotorcraft 5 January 30th 06 05:27 AM
POSA Carb Info and HAPI Engine Info Bill Home Built 0 March 8th 04 08:23 PM
Starting new info site need info from the pros MRQB Piloting 7 January 5th 04 03:20 AM
