Parachute Jump Areas in US Airspace Data
Old February 29th 12, 05:49 AM posted to rec.aviation.soaring
2KA
Default Parachute Jump Areas in US Airspace Data
At the suggestion of Ramy Yanetz and with the assistance of John
Leibacher, I've added Parachute Jump Areas (also known as Drop Zones)
to the US Airspace files published on my website at http://www.soaringdata.info.
These same files will be available soon on the Airspace section of the
Worldwide Soaring Turnpoint Exchange. The source of the data is the
NASR data published by the National Flight Data Center.
Most PJAs are specified as circles with a defined radius, but a fairly
large minority just list the center point. In such cases I use a
default of 3 NM.
I have encoded PJAs as "Danger" area ("AC Q" in the OpenAir format).
If, for some reason, you prefer not to see them, you will find them
grouped together in the file so that they can be conveniently removed
using a text editor.
If you're wondering about this change having any impact in contest
flying, there should be essentially none. In the US, "Danger" areas
are generally not closed to contests, so they are not included in the
site files that describe closed airspace that are published on the
Soaring Turnpoint Exchange. Of course in some specific case a CD
could elect to close a PJA.
Happy downloading!
Lynn Alley
"2KA"
Old February 29th 12, 11:27 AM posted to rec.aviation.soaring
kevin anderson
Great, Thanks so much.
Kevin
192
US Airspace and Airport Data Update 2KA Soaring 0 April 29th 11 06:18 PM
US Airspace and Airport Data Update 2KA Soaring 0 August 19th 10 03:39 AM
Update to US airspace data available on WTX 2KA Soaring 1 November 11th 08 06:05 PM
Parachute Jump Square Wheels[_7_] Aviation Photos 0 May 9th 08 08:01 AM
Digital airspace data question -- any FAA data gurus out there? Tuno Piloting 2 December 27th 07 05:06 PM
