At 22:26 02 March 2012, Karl Kunz wrote:
This device is also sold in China under the name Hanvon C18 and elsewhere in Asia as Bambook, KYOBO eReader, as well as Koobe Jin Yong reader. You can load Android apps in it but my question would be can you feed GPS into it? -karl The recommended wired solution for Android is the 'IOIO', a microprocessor-controlled board which can communicate with up to 4 serial devices completely independently (no need for the devices to use the same baud rates etc). All this data is sent over USB to the Android device. Pretty much every device from Android 1.5 (circa 2009) onwards is compatible with this system 'out of the box'. You just have to enable an Android setting called 'USB debugging'. If the manufacturer has disabled this function it can usually be enabled by 'rooting' the device. The flipside of this level of sophistication is that there have been teething problems. The IOIO was conceived as a hobbyist platform emphasising flexibility rather than absolute stability. Rob Dunning and Ytai Ben-Tsvi, the creator of the IOIO, have hopefully solved all these problems for XCSoar 6.3 onwards. The IOIO itself is an open source design, and the recently released DroidSoar board ( http://tvlnet.de/ , German text) is an interpretation designed for gliders, providing two serial ports with IGC-compatible pinouts and charging the Android device in use. There's other products on the way also. |
Android XC Soar | Paul Besing | Soaring | 3 | May 3rd 11 09:39 PM |
New "Android" Tablet | jsbrake[_2_] | Soaring | 4 | March 28th 11 06:39 PM |
Possible Android Tablet? | Sean Fidler | Soaring | 1 | February 8th 11 02:12 PM |
Android App | Mike[_36_] | Soaring | 8 | July 14th 10 10:53 AM |
"View Limiting Device" recommendations please | [email protected] | Instrument Flight Rules | 27 | February 4th 08 02:25 AM |
